How to send log messages to RTT and stdio to UART in mesh sdk?
I am experimenting with light_switch server example from mesh SDK 2.1.1 . I want to add UART functionality to this example.
I referred to the ble_app_uart example from sdk15.0.0 and I have successfully merged the UART part into light_switch server example. My code get compiled and I am able to flash it to my nrf52 dev board but printf() and __LOG both are send to RTT.
I want to push the debug logs to RTT and printf() to UART. I know it can be done as it is already implemented in the ble_app_uart example but I dont know what is needed to achieve this?
  • I know it can be done as it is already implemented in the ble_app_uart example but I dont know what is needed to achieve this?
    So look at how that example does it - and just do that!
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_evt       Nordic UART Service event.
    /**@snippet [Handling the data received over BLE] */
            uint32_t err_code;
            for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
                do
                    err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                    if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                        NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
                } while (err_code == NRF_ERROR_BUSY);
            if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
                while (app_uart_put('\n') == NRF_ERROR_BUSY);
  • I dont require the NUS service... I am not receiving data from BLE. All I want is the printf() should be sent to UART and the NRF_LOG_INFO() should be sent to RTT.
        // Start execution.
        advertising_start();
    In mesh examples NRF_LOG_INFO is not used, instead __LOG() is used. In my case printf() and __LOG() both are appearing on RTT. Read the title of this question again, I want "stdio" to be redirected to UART. In the code that you have posted, where is printf() being used?
  • I didn't suggest that you use the NUS service!
    I said just look at how the ble_app_uart example does its output to the UART - and do the same!
  • I have gone through ble_app_uart code there are two apis that it uses to output code to UART. printf() and app_uart_put(). I have no issue with app_uart_put(), I mean using app_uart_put() I am able to send data to UART. But not with printf(). So my question is what should be done to achieve this? I am not able to figure it out looking at the code of ble_app_uart.
    It would be good if you could point me to that specific code which sends printf() to uart in ble_app_uart example.
  • What I am suggesting is to just use app_uart_put().
    That's what I would do. It seems like the simplest way forward ...
