PWM Update_function
Dear Nordic Team
I have changed pwm driver example as you see in bellow . i also observed the codes which you linked for pwm. Bellow code works without the effect of update_pwm and working well. But the problem is that i can not control the duty cycle by void update_pwm function. Kindly please help me.
#include <stdio.h>
#include <string.h>
#include "nrf_drv_pwm.h"
#include "app_error.h"
#include "boards.h"
#include "bsp.h"
#include "app_timer.h"
#include "nrf_drv_clock.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_delay.h"
static nrf_drv_pwm_t m_pwm0 = NRF_DRV_PWM_INSTANCE(0);
static uint16_t const              m_demo1_top  = 20000;
static uint16_t const              m_demo1_step = 200;
static uint8_t                     m_demo1_phase;
static nrf_pwm_values_individual_t m_demo1_seq_values;
static nrf_pwm_sequence_t const    m_demo1_seq =
    .values.p_individual = &m_demo1_seq_values,
    .length              = NRF_PWM_VALUES_LENGTH(m_demo1_seq_values),
    .repeats             = 0,
    .end_delay           = 0
static void demo1_handler(nrf_drv_pwm_evt_type_t event_type)
    if (event_type == NRF_DRV_PWM_EVT_FINISHED)
        uint8_t channel    = m_demo1_phase >> 1;
        bool    down       = m_demo1_phase & 1;
        bool    next_phase = false;
        uint16_t * p_channels = (uint16_t *)&m_demo1_seq_values;
        uint16_t value = p_channels[channel];
        if (down)
            value -= m_demo1_step;
            if (value == 0)
                next_phase = true;
            value += m_demo1_step;
            if (value >= m_demo1_top)
                next_phase = true;
        p_channels[channel] = value;
        if (next_phase)
            if (++m_demo1_phase >= 2 * NRF_PWM_CHANNEL_COUNT)
                m_demo1_phase = 0;
static void pwm_init(void)
    NRF_LOG_INFO("Demo 1");
    nrf_drv_pwm_config_t const config0 =
        .output_pins =
            BSP_LED_0 | NRF_DRV_PWM_PIN_INVERTED, // channel 0
        .irq_priority = APP_IRQ_PRIORITY_LOWEST,
        .base_clock   = NRF_PWM_CLK_1MHz,
        .count_mode   = NRF_PWM_MODE_UP,
        .top_value    = m_demo1_top,
        .load_mode    = NRF_PWM_LOAD_INDIVIDUAL,
        .step_mode    = NRF_PWM_STEP_AUTO
    APP_ERROR_CHECK(nrf_drv_pwm_init(&m_pwm0, &config0, demo1_handler));
    APP_ERROR_CHECK(nrf_drv_pwm_simple_playback(&m_pwm0, &m_demo1_seq, 1,
                                      NRF_DRV_PWM_FLAG_LOOP));
void update_pwm(int16_t duty_cycle)
    m_demo1_seq_values.channel_0 = duty_cycle;
    nrf_drv_pwm_simple_playback(&m_pwm0, &m_demo1_seq, 1, 0);
    pwm_init();
    for (;;)
Kind regards
    The duty cycle is generally the ratio between the top_value and seq_value.
    With the code you uploaded, the PWM will go from 100% duty, and slowly go to 0%, and then up again to 100% duty, giving the LED1 a fading effect.
    If you just want to set a simple duty cycle, here is some code example on how to do that:
    Snippet:
     * Copyright (c) 2015 - 2017, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup pwm_example_main main.c
     * @ingroup pwm_example
     * @brief PWM Example Application main file.
     * This file contains the source code for a sample application using PWM.
    #include <stdio.h>
    #include <string.h>
    #include "boards.h"
    #include "bsp.h"
    #define OUTPUT_PIN LED_1
    // Declare variables holding PWM sequence values. In this example only one channel is used
    nrf_pwm_values_individual_t seq_values[] = {0, 0, 0, 0};
    nrf_pwm_sequence_t const seq =
        .values.p_individual = seq_values,
        .length          = NRF_PWM_VALUES_LENGTH(seq_values),
        .repeats         = 0,
        .end_delay       = 0
    // Set duty cycle between 0 and 100%
    void pwm_update_duty_cycle(uint8_t duty_cycle)
        // Check if value is outside of range. If so, set to 100%
        if(duty_cycle >= 100)
            seq_values->channel_0 = 100 | 0x8000;
            seq_values->channel_0 = duty_cycle | 0x8000;
        nrf_drv_pwm_simple_playback(&m_pwm0, &seq, 1, NRF_DRV_PWM_FLAG_LOOP);
            .output_pins =
                OUTPUT_PIN, // channel 0
                NRF_DRV_PWM_PIN_NOT_USED,             // channel 1
                NRF_DRV_PWM_PIN_NOT_USED,             // channel 2
                NRF_DRV_PWM_PIN_NOT_USED,             // channel 3
            .top_value    = 100,
        // Init PWM without error handler
        APP_ERROR_CHECK(nrf_drv_pwm_init(&m_pwm0, &config0, NULL));
        // Start clock for accurate frequencies
        // Wait for clock to start
        while(NRF_CLOCK->EVENTS_HFCLKSTARTED == 0);
        pwm_init();
        pwm_update_duty_cycle(50);
        for (;;)
         __WFE;
  • Hi
    Thank you for replying. I tried your code but by changing the pwm_update_duty_cycle(50); nothing happened!
    for example i changed 50 to zero and it must be turn of the led but led still on!
  • for example i changed 50 to zero and it must be turn of the led but led still on
    The LEDs on the DK are active low. I have inverted the PWM in this code:
    /** @file
    #include <stdio.h>
    #include <string.h>
    #include "boards.h"
    #include "bsp.h"
        .repeats         = 0,
        .end_delay       = 0
            seq_values->channel_0 = 100;
            seq_values->channel_0 = duty_cycle;
            .output_pins =
            .top_value    = 100,
        pwm_init();
        pwm_update_duty_cycle(0);
        for (;;)
         __WFE;
  • Thank you for answering. Now it works by one pin. I connected one RGB led to three pins and updated the duty cycle for 3 color. But i have still another problem and RGB led remains off. Could you please check the bellow code?
    /** @file
    #include <stdio.h>
    #include <string.h>
    #include "boards.h"
    #include "bsp.h"
    #define OUTPUT_PIN1 3
    #define OUTPUT_PIN2 4
    #define OUTPUT_PIN3 28
    static nrf_drv_pwm_t m_pwm1 = NRF_DRV_PWM_INSTANCE(0);
    static nrf_drv_pwm_t m_pwm2 = NRF_DRV_PWM_INSTANCE(0);
    nrf_pwm_sequence_t const seq1 =
        .repeats         = 0,
        .end_delay       = 0
    nrf_pwm_sequence_t const seq2 =
        .repeats         = 0,
        .end_delay       = 0
    nrf_pwm_sequence_t const seq3 =
        .repeats         = 0,
        .end_delay       = 0
    void pwm_update_duty_cycle(uint8_t duty_cycle_red , uint8_t duty_cycle_green , uint8_t duty_cycle_blue)
        if(duty_cycle_red >= 100)
            seq_values->channel_0 = duty_cycle_red | 0x8000;
        if(duty_cycle_green >= 100)
            seq_values->channel_1 = 100 | 0x8000;
            seq_values->channel_1 = duty_cycle_green | 0x8000;
        if(duty_cycle_blue >= 100)
            seq_values->channel_2 = 100 | 0x8000;
            seq_values->channel_2 = duty_cycle_blue | 0x8000;
        nrf_drv_pwm_simple_playback(&m_pwm0, &seq1, 1, NRF_DRV_PWM_FLAG_LOOP);
        nrf_drv_pwm_simple_playback(&m_pwm1, &seq2, 1, NRF_DRV_PWM_FLAG_LOOP);
        nrf_drv_pwm_simple_playback(&m_pwm2, &seq3, 1, NRF_DRV_PWM_FLAG_LOOP);
            .output_pins =
                OUTPUT_PIN1, // channel 0
                OUTPUT_PIN2, // channel 1
                OUTPUT_PIN3, // channel 2
            .top_value    = 100,
        APP_ERROR_CHECK(nrf_drv_pwm_init(&m_pwm1, &config0, NULL));
        APP_ERROR_CHECK(nrf_drv_pwm_init(&m_pwm2, &config0, NULL));
        pwm_init();
        pwm_update_duty_cycle(0,100,0);
        for (;;)
         __WFE;
  • You can have 4 PWM channels for each instance, so you only need to create 1 instance.
    Snippet:
    /** @file
    #include <stdio.h>
    #include <string.h>
    #include "boards.h"
    #include "bsp.h"
    #define OUTPUT_PIN1 17
    #define OUTPUT_PIN2 18
    #define OUTPUT_PIN3 19
        .repeats         = 0,
        .end_delay       = 0
        //RED
            seq_values->channel_0 = 100;// | 0x8000;
            seq_values->channel_0 = duty_cycle_red;// | 0x8000;
        //GREEN
            seq_values->channel_1 = 100; // | 0x8000;
            seq_values->channel_1 = duty_cycle_green; // | 0x8000;
        //BLUE
            seq_values->channel_2 = 100; // | 0x8000;
            seq_values->channel_2 = duty_cycle_blue; // | 0x8000;
            .output_pins =
            .top_value    = 100,
        pwm_init();
        pwm_update_duty_cycle(20,50,80);
        for (;;)
         __WFE;
