ble freertos - ble_lbs_on_button_change unknown function
I am trying to run the blinky example together with freertos (nRF52840 pDK, pca10056, segger studio), so I took the hrs_freertos example and added ble_lbs service from blinky example. I also do not use bsp support. Led characteristics works fine, but when I press the button, button event handler is called, but when the code come to "ble_lbs_on_button_change" I get "unknown function at /some address/") - in case of runing sw without debug, processor goes to reset.
If I return from button_event_handler() before the call to "ble_lbs_on_button_change()" program is working normal (except without notifications of course)
Any idea what I am doing wrong?
The main.c is attached.
 * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
// Board/nrf6310/ble/ble_app_hrs_rtx/main.c
 * @brief Heart Rate Service Sample Application with RTX main file.
 * This file contains the source code for a sample application using RTX and the
 * Heart Rate service (and also Battery and Device Information services).
 * This application uses the @ref srvlib_conn_params module.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_bas.h"
#include "ble_hrs.h"
#include "ble_dis.h"
#include "ble_lbs.h"
#include "ble_conn_params.h"
#include "sensorsim.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_freertos.h"
#include "app_timer.h"
#include "app_button.h"
#include "peer_manager.h"
#include "bsp_btn_ble.h"
#include "FreeRTOS.h"
#include "task.h"
#include "timers.h"
#include "semphr.h"
#include "fds.h"
#include "ble_conn_state.h"
#include "nrf_drv_clock.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "boards.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define DEVICE_NAME                         "Adeona_LLS"                            /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME                   "JARDesign"                   /**< Manufacturer. Will be passed to Device Information Service. */
#define APP_BLE_OBSERVER_PRIO               3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG                1                                       /**< A tag identifying the SoftDevice BLE configuration. */
#define APP_ADV_INTERVAL                    300                                     /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
#define APP_ADV_DURATION                    18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define BATTERY_LEVEL_MEAS_INTERVAL         2000                                    /**< Battery level measurement interval (ms). */
#define MIN_BATTERY_LEVEL                   81                                      /**< Minimum simulated battery level. */
#define MAX_BATTERY_LEVEL                   100                                     /**< Maximum simulated battery level. */
#define BATTERY_LEVEL_INCREMENT             1                                       /**< Increment between each simulated battery level measurement. */
#define HEART_RATE_MEAS_INTERVAL            1000                                    /**< Heart rate measurement interval (ms). */
#define MIN_HEART_RATE                      140                                     /**< Minimum heart rate as returned by the simulated measurement function. */
#define MAX_HEART_RATE                      300                                     /**< Maximum heart rate as returned by the simulated measurement function. */
#define HEART_RATE_INCREMENT                10                                      /**< Value by which the heart rate is incremented/decremented for each call to the simulated measurement function. */
#define RR_INTERVAL_INTERVAL                300                                     /**< RR interval interval (ms). */
#define MIN_RR_INTERVAL                     100                                     /**< Minimum RR interval as returned by the simulated measurement function. */
#define MAX_RR_INTERVAL                     500                                     /**< Maximum RR interval as returned by the simulated measurement function. */
#define RR_INTERVAL_INCREMENT               1                                       /**< Value by which the RR interval is incremented/decremented for each call to the simulated measurement function. */
#define SENSOR_CONTACT_DETECTED_INTERVAL    5000                                    /**< Sensor Contact Detected toggle interval (ms). */
#define MIN_CONN_INTERVAL                   MSEC_TO_UNITS(400, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.4 seconds). */
#define MAX_CONN_INTERVAL                   MSEC_TO_UNITS(650, UNIT_1_25_MS)        /**< Maximum acceptable connection interval (0.65 second). */
#define SLAVE_LATENCY                       0                                       /**< Slave latency. */
#define CONN_SUP_TIMEOUT                    MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Connection supervisory time-out (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY      5000                                    /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY       30000                                   /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT        3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
#define SEC_PARAM_BOND                      1                                       /**< Perform bonding. */
#define SEC_PARAM_MITM                      0                                       /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC                      0                                       /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS                  0                                       /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES           BLE_GAP_IO_CAPS_NONE                    /**< No I/O capabilities. */
#define SEC_PARAM_OOB                       0                                       /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE              7                                       /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE              16                                      /**< Maximum encryption key size. */
#define DEAD_BEEF                           0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define OSTIMER_WAIT_FOR_QUEUE              2                                       /**< Number of ticks to wait for the timer queue to be ready */
#define ADVERTISING_LED                 BSP_BOARD_LED_0                         /**< Is on when device is advertising. */
#define CONNECTED_LED                   BSP_BOARD_LED_1                         /**< Is on when device has connected. */
#define LEDBUTTON_LED                   BSP_BOARD_LED_2                         /**< LED to be toggled with the help of the LED Button Service. */
#define LEDBUTTON_BUTTON                BSP_BUTTON_0                            /**< Button that will trigger the notification event with the LED Button Service */
BLE_LBS_DEF(m_lbs);   // LED Button Service
BLE_BAS_DEF(m_bas);                                                 /**< Battery service instance. */
BLE_HRS_DEF(m_hrs);                                                 /**< Heart rate service instance. */
NRF_BLE_GATT_DEF(m_gatt);                                           /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                             /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                 /**< Advertising module instance. */
static uint16_t m_conn_handle         = BLE_CONN_HANDLE_INVALID;    /**< Handle of the current connection. */
static bool     m_rr_interval_enabled = true;                       /**< Flag for enabling and disabling the registration of new RR interval measurements (the purpose of disabling this is just to test sending HRM without RR interval data. */
static sensorsim_cfg_t   m_battery_sim_cfg;                         /**< Battery Level sensor simulator configuration. */
static sensorsim_state_t m_battery_sim_state;                       /**< Battery Level sensor simulator state. */
static sensorsim_cfg_t   m_heart_rate_sim_cfg;                      /**< Heart Rate sensor simulator configuration. */
static sensorsim_state_t m_heart_rate_sim_state;                    /**< Heart Rate sensor simulator state. */
static sensorsim_cfg_t   m_rr_interval_sim_cfg;                     /**< RR Interval sensor simulator configuration. */
static sensorsim_state_t m_rr_interval_sim_state;                   /**< RR Interval sensor simulator state. */
static TimerHandle_t m_battery_timer;                               /**< Definition of battery timer. */
static TimerHandle_t m_heart_rate_timer;                            /**< Definition of heart rate timer. */
static TimerHandle_t m_rr_interval_timer;                           /**< Definition of RR interval timer. */
static TimerHandle_t m_sensor_contact_timer;                        /**< Definition of sensor contact detected timer. */
#if NRF_LOG_ENABLED
static TaskHandle_t m_logger_thread;                                /**< Definition of Logger thread. */
static void advertising_start(void * p_erase_bonds);
/**@brief Callback function for asserts in the SoftDevice.
 * @param[in]   line_num   Line number of the failing ASSERT call.
 * @param[in]   file_name  File name of the failing ASSERT call.
/**@brief Function for handling Peer Manager events.
 * @param[in] p_evt  Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
    ret_code_t err_code;
    switch (p_evt->evt_id)
        case PM_EVT_BONDED_PEER_CONNECTED:
            NRF_LOG_INFO("Connected to a previously bonded device.");
        } break;
        case PM_EVT_CONN_SEC_SUCCEEDED:
            NRF_LOG_INFO("Connection secured: role: %d, conn_handle: 0x%x, procedure: %d.",
                         ble_conn_state_role(p_evt->conn_handle),
                         p_evt->conn_handle,
                         p_evt->params.conn_sec_succeeded.procedure);
        } break;
        case PM_EVT_CONN_SEC_FAILED:
            /* Often, when securing fails, it shouldn't be restarted, for security reasons.
             * Other times, it can be restarted directly.
             * Sometimes it can be restarted, but only after changing some Security Parameters.
             * Sometimes, it cannot be restarted until the link is disconnected and reconnected.
             * Sometimes it is impossible, to secure the link, or the peer device does not support it.
             * How to handle this error is highly application dependent. */
        } break;
        case PM_EVT_CONN_SEC_CONFIG_REQ:
            // Reject pairing request from an already bonded peer.
            pm_conn_sec_config_t conn_sec_config = {.allow_repairing = false};
            pm_conn_sec_config_reply(p_evt->conn_handle, &conn_sec_config);
        } break;
        case PM_EVT_STORAGE_FULL:
            // Run garbage collection on the flash.
            err_code = fds_gc();
            if (err_code == FDS_ERR_NO_SPACE_IN_QUEUES)
                // Retry.
        } break;
            bool delete_bonds = false;
            advertising_start(&delete_bonds);
        } break;
        case PM_EVT_PEER_DATA_UPDATE_FAILED:
            // Assert.
            APP_ERROR_CHECK(p_evt->params.peer_data_update_failed.error);
        } break;
        case PM_EVT_PEER_DELETE_FAILED:
            // Assert.
            APP_ERROR_CHECK(p_evt->params.peer_delete_failed.error);
        } break;
        case PM_EVT_PEERS_DELETE_FAILED:
            // Assert.
            APP_ERROR_CHECK(p_evt->params.peers_delete_failed_evt.error);
        } break;
        case PM_EVT_ERROR_UNEXPECTED:
            // Assert.
            APP_ERROR_CHECK(p_evt->params.error_unexpected.error);
        } break;
        case PM_EVT_CONN_SEC_START:
        case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED:
        case PM_EVT_PEER_DELETE_SUCCEEDED:
        case PM_EVT_LOCAL_DB_CACHE_APPLIED:
        case PM_EVT_LOCAL_DB_CACHE_APPLY_FAILED:
            // This can happen when the local DB has changed.
        case PM_EVT_SERVICE_CHANGED_IND_SENT:
        case PM_EVT_SERVICE_CHANGED_IND_CONFIRMED:
/**@brief Function for performing battery measurement and updating the Battery Level characteristic
 *        in Battery Service.
static void battery_level_update(void)
    uint8_t  battery_level;
    battery_level = (uint8_t)sensorsim_measure(&m_battery_sim_state, &m_battery_sim_cfg);
    err_code = ble_bas_battery_level_update(&m_bas, battery_level, BLE_CONN_HANDLE_ALL);
    if ((err_code != NRF_SUCCESS) &&
        (err_code != NRF_ERROR_INVALID_STATE) &&
        (err_code != NRF_ERROR_BUSY) &&
        (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
        APP_ERROR_HANDLER(err_code);
/**@brief Function for handling the Battery measurement timer time-out.
 * @details This function will be called each time the battery level measurement timer expires.
 * @param[in] xTimer Handler to the timer that called this function.
 *                   You may get identifier given to the function xTimerCreate using pvTimerGetTimerID.
static void battery_level_meas_timeout_handler(TimerHandle_t xTimer)
    UNUSED_PARAMETER(xTimer);
    battery_level_update();
/**@brief Function for handling the Heart rate measurement timer time-out.
 * @details This function will be called each time the heart rate measurement timer expires.
 *          It will exclude RR Interval data from every third measurement.
static void heart_rate_meas_timeout_handler(TimerHandle_t xTimer)
    static uint32_t cnt = 0;
    uint16_t        heart_rate;
    heart_rate = (uint16_t)sensorsim_measure(&m_heart_rate_sim_state, &m_heart_rate_sim_cfg);
    cnt++;
    err_code = ble_hrs_heart_rate_measurement_send(&m_hrs, heart_rate);
    // Disable RR Interval recording every third heart rate measurement.
    // NOTE: An application will normally not do this. It is done here just for testing generation
    // of messages without RR Interval measurements.
    m_rr_interval_enabled = ((cnt % 3) != 0);
/**@brief Function for handling the RR interval timer time-out.
 * @details This function will be called each time the RR interval timer expires.
static void rr_interval_timeout_handler(TimerHandle_t xTimer)
    if (m_rr_interval_enabled)
        uint16_t rr_interval;
        rr_interval = (uint16_t)sensorsim_measure(&m_rr_interval_sim_state,
                                                  &m_rr_interval_sim_cfg);
        ble_hrs_rr_interval_add(&m_hrs, rr_interval);
/**@brief Function for handling the Sensor Contact Detected timer time-out.
 * @details This function will be called each time the Sensor Contact Detected timer expires.
static void sensor_contact_detected_timeout_handler(TimerHandle_t xTimer)
    static bool sensor_contact_detected = false;
    sensor_contact_detected = !sensor_contact_detected;
    ble_hrs_sensor_contact_detected_update(&m_hrs, sensor_contact_detected);
/**@brief Function for the Timer initialization.
 * @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void)
    // Initialize timer module.
    // Create timers.
    m_battery_timer = xTimerCreate("BATT",
                                   BATTERY_LEVEL_MEAS_INTERVAL,
                                   pdTRUE,
                                   NULL,
                                   battery_level_meas_timeout_handler);
    m_heart_rate_timer = xTimerCreate("HRT",
                                      HEART_RATE_MEAS_INTERVAL,
                                      pdTRUE,
                                      NULL,
                                      heart_rate_meas_timeout_handler);
    m_rr_interval_timer = xTimerCreate("RRT",
                                       RR_INTERVAL_INTERVAL,
                                       pdTRUE,
                                       NULL,
                                       rr_interval_timeout_handler);
    m_sensor_contact_timer = xTimerCreate("SCT",
                                          SENSOR_CONTACT_DETECTED_INTERVAL,
                                          pdTRUE,
                                          NULL,
                                          sensor_contact_detected_timeout_handler);
    // Error checking
    if ( (NULL == m_battery_timer)
         || (NULL == m_heart_rate_timer)
         || (NULL == m_rr_interval_timer)
         || (NULL == m_sensor_contact_timer) )
        APP_ERROR_HANDLER(NRF_ERROR_NO_MEM);
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
 *          device including the device name, appearance, and the preferred connection parameters.
                                          (const uint8_t *)DEVICE_NAME,
                                          strlen(DEVICE_NAME));
    err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_HEART_RATE_SENSOR_HEART_RATE_BELT);
/**@brief Function for initializing the GATT module. */
static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling write events to the LED characteristic.
 * @param[in] p_lbs     Instance of LED Button Service to which the write applies.
 * @param[in] led_state Written/desired state of the LED.
static void led_write_handler(uint16_t conn_handle, ble_lbs_t * p_lbs, uint8_t led_state)
    if (led_state)
        bsp_board_led_on(LEDBUTTON_LED);
        NRF_LOG_INFO("Received LED ON!");
        bsp_board_led_off(LEDBUTTON_LED);
        NRF_LOG_INFO("Received LED OFF!");
 * @details Initialize the Heart Rate, Battery and Device Information services.
    ble_hrs_init_t     hrs_init;
    ble_bas_init_t     bas_init;
    ble_dis_init_t     dis_init;
    ble_lbs_init_t     lbs_init     = {0};
    uint8_t            body_sensor_location;
    // Initialize Heart Rate Service.
    body_sensor_location = BLE_HRS_BODY_SENSOR_LOCATION_FINGER;
    memset(&hrs_init, 0, sizeof(hrs_init));
    hrs_init.evt_handler                 = NULL;
    hrs_init.is_sensor_contact_supported = true;
    hrs_init.p_body_sensor_location      = &body_sensor_location;
    // Here the sec level for the Heart Rate Service can be changed/increased.
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&hrs_init.hrs_hrm_attr_md.cccd_write_perm);
    BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hrs_init.hrs_hrm_attr_md.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hrs_init.hrs_hrm_attr_md.write_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&hrs_init.hrs_bsl_attr_md.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hrs_init.hrs_bsl_attr_md.write_perm);
    err_code = ble_hrs_init(&m_hrs, &hrs_init);
    // Initialize Battery Service.
    memset(&bas_init, 0, sizeof(bas_init));
    // Here the sec level for the Battery Service can be changed/increased.
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&bas_init.battery_level_char_attr_md.cccd_write_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&bas_init.battery_level_char_attr_md.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&bas_init.battery_level_char_attr_md.write_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&bas_init.battery_level_report_read_perm);
    bas_init.evt_handler          = NULL;
    bas_init.support_notification = true;
    bas_init.p_report_ref         = NULL;
    bas_init.initial_batt_level   = 100;
    err_code = ble_bas_init(&m_bas, &bas_init);
    // Initialize Device Information Service.
    memset(&dis_init, 0, sizeof(dis_init));
    ble_srv_ascii_to_utf8(&dis_init.manufact_name_str, (char *)MANUFACTURER_NAME);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&dis_init.dis_attr_md.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&dis_init.dis_attr_md.write_perm);
    err_code = ble_dis_init(&dis_init);
    // Initialize LBS.
    lbs_init.led_write_handler = led_write_handler;
    err_code = ble_lbs_init(&m_lbs, &lbs_init);
/**@brief Function for initializing the sensor simulators. */
static void sensor_simulator_init(void)
    m_battery_sim_cfg.min          = MIN_BATTERY_LEVEL;
    m_battery_sim_cfg.max          = MAX_BATTERY_LEVEL;
    m_battery_sim_cfg.incr         = BATTERY_LEVEL_INCREMENT;
    m_battery_sim_cfg.start_at_max = true;
    sensorsim_init(&m_battery_sim_state, &m_battery_sim_cfg);
    m_heart_rate_sim_cfg.min          = MIN_HEART_RATE;
    m_heart_rate_sim_cfg.max          = MAX_HEART_RATE;
    m_heart_rate_sim_cfg.incr         = HEART_RATE_INCREMENT;
    m_heart_rate_sim_cfg.start_at_max = false;
    sensorsim_init(&m_heart_rate_sim_state, &m_heart_rate_sim_cfg);
    m_rr_interval_sim_cfg.min          = MIN_RR_INTERVAL;
    m_rr_interval_sim_cfg.max          = MAX_RR_INTERVAL;
    m_rr_interval_sim_cfg.incr         = RR_INTERVAL_INCREMENT;
    m_rr_interval_sim_cfg.start_at_max = false;
    sensorsim_init(&m_rr_interval_sim_state, &m_rr_interval_sim_cfg);
/**@brief   Function for starting application timers.
 * @details Timers are run after the scheduler has started.
static void application_timers_start(void)
    // Start application timers.
    if (pdPASS != xTimerStart(m_battery_timer, OSTIMER_WAIT_FOR_QUEUE))
    if (pdPASS != xTimerStart(m_heart_rate_timer, OSTIMER_WAIT_FOR_QUEUE))
    if (pdPASS != xTimerStart(m_rr_interval_timer, OSTIMER_WAIT_FOR_QUEUE))
    if (pdPASS != xTimerStart(m_sensor_contact_timer, OSTIMER_WAIT_FOR_QUEUE))
/**@brief Function for handling the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module which
 *          are passed to the application.
 *          @note All this function does is to disconnect. This could have been done by simply
 *                setting the disconnect_on_fail config parameter, but instead we use the event
 *                handler mechanism to demonstrate its use.
 * @param[in]   p_evt   Event received from the Connection Parameters Module.
/**@brief Function for handling a Connection Parameters error.
/**@brief Function for initializing the Connection Parameters module. */
    // Prepare wakeup buttons.
    uint32_t err_code;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
            NRF_LOG_INFO("Fast advertising.");
            //err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING);
            //APP_ERROR_CHECK(err_code);
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
    uint32_t err_code;
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected");
            //err_code = bsp_indication_set(BSP_INDICATE_CONNECTED);
            bsp_board_led_on(CONNECTED_LED);
            bsp_board_led_off(ADVERTISING_LED);
            // For Button Service
            err_code = app_button_enable();
            NRF_LOG_INFO("Disconnected");
            bsp_board_led_off(CONNECTED_LED);
            err_code = app_button_disable();
            NRF_LOG_DEBUG("BLE_GAP_EVT_SEC_PARAMS_REQUEST - CHeck this one.");
            // Pairing not supported
            err_code = sd_ble_gap_sec_params_reply(m_conn_handle,
                                                   BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP,
                                                   NULL,
                                                   NULL);
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
            NRF_LOG_DEBUG("BLE_GATTS_EVT_SYS_ATTR_MISSING - CHeck this one.");
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
            // No implementation needed.
    uint32_t ram_start = 0;
    // Enable BLE stack.
 * @param[in]   event   Event generated by button press.
static void bsp_event_handler(bsp_event_t event)
    NRF_LOG_DEBUG("BSP Event Handler - shouldn't be there!!!");
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
        case BSP_EVENT_DISCONNECT:
        case BSP_EVENT_WHITELIST_OFF:
/**@brief Function for the Peer Manager initialization. */
static void peer_manager_init(void)
    err_code = pm_init();
    sec_param.bond           = SEC_PARAM_BOND;
    sec_param.mitm           = SEC_PARAM_MITM;
    sec_param.lesc           = SEC_PARAM_LESC;
    sec_param.keypress       = SEC_PARAM_KEYPRESS;
    sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob            = SEC_PARAM_OOB;
    sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc  = 1;
    sec_param.kdist_own.id   = 1;
    sec_param.kdist_peer.enc = 1;
    sec_param.kdist_peer.id  = 1;
/**@brief Clear bond information from persistent storage. */
static void delete_bonds(void)
    NRF_LOG_INFO("Erase bonds!");
    err_code = pm_peers_delete();
/**@brief Function for initializing the Advertising functionality. */
    ble_advertising_init_t init;
    ble_uuid_t m_adv_uuids[] =                                   /**< Universally unique service identifiers. */
      //{BLE_UUID_HEART_RATE_SERVICE, BLE_UUID_TYPE_BLE},
      //{BLE_UUID_BATTERY_SERVICE, BLE_UUID_TYPE_BLE},
      //{BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE},
      {LBS_UUID_SERVICE,  m_lbs.uuid_type}
    uint8_t       flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
    init.advdata.include_appearance      = true;
    init.advdata.flags                   = flags;
    init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
static void log_init(void)
    bsp_event_t startup_event;
    //err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    err_code = bsp_init(BSP_INIT_LEDS, bsp_event_handler);
/**@brief Function for handling events from the button handler module.
 * @param[in] pin_no        The pin that the event applies to.
 * @param[in] button_action The button action (press/release).
static void button_event_handler(uint8_t pin_no, uint8_t button_action)
    NRF_LOG_INFO("Button pressed");
//  return;
    switch (pin_no)
        case LEDBUTTON_BUTTON:
            NRF_LOG_INFO("Send button state change 1.");
            err_code = ble_lbs_on_button_change(m_conn_handle, &m_lbs, button_action);
            if (err_code != NRF_SUCCESS &&
                err_code != BLE_ERROR_INVALID_CONN_HANDLE &&
                err_code != NRF_ERROR_INVALID_STATE &&
            APP_ERROR_HANDLER(pin_no);
/**@brief Function for the LEDs initialization.
 * @details Initializes all LEDs used by the application.
static void leds_init(void)
/**@brief Function for initializing the button handler module.
static void buttons_init(void)
    //The array must be static because a pointer to it will be saved in the button handler module.
    static app_button_cfg_t buttons[] =
        {LEDBUTTON_BUTTON, APP_BUTTON_ACTIVE_LOW, BUTTON_PULL, button_event_handler}
    err_code = app_button_init(buttons, ARRAY_SIZE(buttons),
                               APP_TIMER_TICKS(50));
/**@brief Function for starting advertising. */
    bool erase_bonds = *(bool*)p_erase_bonds;
    if (erase_bonds)
        delete_bonds();
        // Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
        ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
    bsp_board_led_on(ADVERTISING_LED);
#if NRF_LOG_ENABLED
/**@brief Thread for handling the logger.
 * @details This thread is responsible for processing log entries if logs are deferred.
 *          Thread flushes all log entries and suspends. It is resumed by idle task hook.
 * @param[in]   arg   Pointer used for passing some arbitrary information (context) from the
 *                    osThreadCreate() call to the thread.
static void logger_thread(void * arg)
    UNUSED_PARAMETER(arg);
    while (1)
        NRF_LOG_FLUSH();
        vTaskSuspend(NULL); // Suspend myself
#endif //NRF_LOG_ENABLED
/**@brief A function which is hooked to idle task.
 * @note Idle hook must be enabled in FreeRTOS configuration (configUSE_IDLE_HOOK).
void vApplicationIdleHook( void )
#if NRF_LOG_ENABLED
     vTaskResume(m_logger_thread);
/**@brief Function for initializing the clock.
static void clock_init(void)
    ret_code_t err_code = nrf_drv_clock_init();
/**@brief Function for application main entry.
    bool erase_bonds;
    // Initialize modules.
    log_init();
    clock_init();
    // Do not start any interrupt that uses system functions before system initialisation.
    // The best solution is to start the OS before any other initalisation.
#if NRF_LOG_ENABLED
    // Start execution.
    if (pdPASS != xTaskCreate(logger_thread, "LOGGER", 256, NULL, 1, &m_logger_thread))
    // Activate deep sleep mode.
    SCB->SCR |= SCB_SCR_SLEEPDEEP_Msk;
    timers_init();
    //buttons_leds_init(&erase_bonds);
    leds_init();
    buttons_init();
    // Configure and initialize the BLE stack.
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
//    sensor_simulator_init();
    conn_params_init();
    peer_manager_init();
//    application_timers_start();
    // Create a FreeRTOS task for the BLE stack.
    // The task will run advertising_start() before entering its loop.
    nrf_sdh_freertos_init(advertising_start, &erase_bonds);
    NRF_LOG_INFO("HRS FreeRTOS example started.");
    // Start FreeRTOS scheduler.
    vTaskStartScheduler();
    for (;;)
        APP_ERROR_HANDLER(NRF_ERROR_FORBIDDEN);
