ble freertos - ble_lbs_on_button_change unknown function
I am trying to run the blinky example together with freertos (nRF52840 pDK, pca10056, segger studio), so I took the hrs_freertos example and added ble_lbs service from blinky example. I also do not use bsp support. Led characteristics works fine, but when I press the button, button event handler is called, but when the code come to "ble_lbs_on_button_change" I get "unknown function at /some address/") - in case of runing sw without debug, processor goes to reset.
If I return from button_event_handler() before the call to "ble_lbs_on_button_change()" program is working normal (except without notifications of course)
Any idea what I am doing wrong?
The main.c is attached.
 * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
// Board/nrf6310/ble/ble_app_hrs_rtx/main.c
 * @brief Heart Rate Service Sample Application with RTX main file.
 * This file contains the source code for a sample application using RTX and the
 * Heart Rate service (and also Battery and Device Information services).
 * This application uses the @ref srvlib_conn_params module.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_bas.h"
#include "ble_hrs.h"
#include "ble_dis.h"
#include "ble_lbs.h"
#include "ble_conn_params.h"
#include "sensorsim.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_freertos.h"
#include "app_timer.h"
#include "app_button.h"
#include "peer_manager.h"
#include "bsp_btn_ble.h"
#include "FreeRTOS.h"
#include "task.h"
#include "timers.h"
#include "semphr.h"
#include "fds.h"
#include "ble_conn_state.h"
#include "nrf_drv_clock.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "boards.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define DEVICE_NAME                         "Adeona_LLS"                            /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME                   "JARDesign"                   /**< Manufacturer. Will be passed to Device Information Service. */
#define APP_BLE_OBSERVER_PRIO               3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG                1                                       /**< A tag identifying the SoftDevice BLE configuration. */
#define APP_ADV_INTERVAL                    300                                     /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
#define APP_ADV_DURATION                    18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define BATTERY_LEVEL_MEAS_INTERVAL         2000                                    /**< Battery level measurement interval (ms). */
#define MIN_BATTERY_LEVEL                   81                                      /**< Minimum simulated battery level. */
#define MAX_BATTERY_LEVEL                   100                                     /**< Maximum simulated battery level. */
#define BATTERY_LEVEL_INCREMENT             1                                       /**< Increment between each simulated battery level measurement. */
#define HEART_RATE_MEAS_INTERVAL            1000                                    /**< Heart rate measurement interval (ms). */
#define MIN_HEART_RATE                      140                                     /**< Minimum heart rate as returned by the simulated measurement function. */
#define MAX_HEART_RATE                      300                                     /**< Maximum heart rate as returned by the simulated measurement function. */
#define HEART_RATE_INCREMENT                10                                      /**< Value by which the heart rate is incremented/decremented for each call to the simulated measurement function. */
#define RR_INTERVAL_INTERVAL                300                                     /**< RR interval interval (ms). */
#define MIN_RR_INTERVAL                     100                                     /**< Minimum RR interval as returned by the simulated measurement function. */
#define MAX_RR_INTERVAL                     500                                     /**< Maximum RR interval as returned by the simulated measurement function. */
#define RR_INTERVAL_INCREMENT               1                                       /**< Value by which the RR interval is incremented/decremented for each call to the simulated measurement function. */
#define SENSOR_CONTACT_DETECTED_INTERVAL    5000                                    /**< Sensor Contact Detected toggle interval (ms). */
#define MIN_CONN_INTERVAL                   MSEC_TO_UNITS(400, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.4 seconds). */
#define MAX_CONN_INTERVAL                   MSEC_TO_UNITS(650, UNIT_1_25_MS)        /**< Maximum acceptable connection interval (0.65 second). */
#define SLAVE_LATENCY                       0                                       /**< Slave latency. */
#define CONN_SUP_TIMEOUT                    MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Connection supervisory time-out (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY      5000                                    /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY       30000                                   /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT        3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
#define SEC_PARAM_BOND                      1                                       /**< Perform bonding. */
#define SEC_PARAM_MITM                      0                                       /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC                      0                                       /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS                  0                                       /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES           BLE_GAP_IO_CAPS_NONE                    /**< No I/O capabilities. */
#define SEC_PARAM_OOB                       0                                       /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE              7                                       /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE              16                                      /**< Maximum encryption key size. */
#define DEAD_BEEF                           0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define OSTIMER_WAIT_FOR_QUEUE              2                                       /**< Number of ticks to wait for the timer queue to be ready */
#define ADVERTISING_LED                 BSP_BOARD_LED_0                         /**< Is on when device is advertising. */
#define CONNECTED_LED                   BSP_BOARD_LED_1                         /**< Is on when device has connected. */
#define LEDBUTTON_LED                   BSP_BOARD_LED_2                         /**< LED to be toggled with the help of the LED Button Service. */
#define LEDBUTTON_BUTTON                BSP_BUTTON_0                            /**< Button that will trigger the notification event with the LED Button Service */
BLE_LBS_DEF(m_lbs);   // LED Button Service
BLE_BAS_DEF(m_bas);                                                 /**< Battery service instance. */
BLE_HRS_DEF(m_hrs);                                                 /**< Heart rate service instance. */
NRF_BLE_GATT_DEF(m_gatt);                                           /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                             /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                 /**< Advertising module instance. */
static uint16_t m_conn_handle         = BLE_CONN_HANDLE_INVALID;    /**< Handle of the current connection. */
static bool     m_rr_interval_enabled = true;                       /**< Flag for enabling and disabling the registration of new RR interval measurements (the purpose of disabling this is just to test sending HRM without RR interval data. */
static sensorsim_cfg_t   m_battery_sim_cfg;                         /**< Battery Level sensor simulator configuration. */
static sensorsim_state_t m_battery_sim_state;                       /**< Battery Level sensor simulator state. */
static sensorsim_cfg_t   m_heart_rate_sim_cfg;                      /**< Heart Rate sensor simulator configuration. */
static sensorsim_state_t m_heart_rate_sim_state;                    /**< Heart Rate sensor simulator state. */
static sensorsim_cfg_t   m_rr_interval_sim_cfg;                     /**< RR Interval sensor simulator configuration. */
static sensorsim_state_t m_rr_interval_sim_state;                   /**< RR Interval sensor simulator state. */
static TimerHandle_t m_battery_timer;                               /**< Definition of battery timer. */
static TimerHandle_t m_heart_rate_timer;                            /**< Definition of heart rate timer. */
static TimerHandle_t m_rr_interval_timer;                           /**< Definition of RR interval timer. */
static TimerHandle_t m_sensor_contact_timer;                        /**< Definition of sensor contact detected timer. */
#if NRF_LOG_ENABLED
static TaskHandle_t m_logger_thread;                                /**< Definition of Logger thread. */
static void advertising_start(void * p_erase_bonds);
/**@brief Callback function for asserts in the SoftDevice.
 * @param[in]   line_num   Line number of the failing ASSERT call.
 * @param[in]   file_name  File name of the failing ASSERT call.
/**@brief Function for handling Peer Manager events.
 * @param[in] p_evt  Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
    ret_code_t err_code;
    switch (p_evt->evt_id)
        case PM_EVT_BONDED_PEER_CONNECTED:
            NRF_LOG_INFO("Connected to a previously bonded device.");
        } break;
        case PM_EVT_CONN_SEC_SUCCEEDED:
            NRF_LOG_INFO("Connection secured: role: %d, conn_handle: 0x%x, procedure: %d.",
                         ble_conn_state_role(p_evt->conn_handle),
                         p_evt->conn_handle,
                         p_evt->params.conn_sec_succeeded.procedure);
        } break;
        case PM_EVT_CONN_SEC_FAILED:
            /* Often, when securing fails, it shouldn't be restarted, for security reasons.
             * Other times, it can be restarted directly.
             * Sometimes it can be restarted, but only after changing some Security Parameters.
             * Sometimes, it cannot be restarted until the link is disconnected and reconnected.
             * Sometimes it is impossible, to secure the link, or the peer device does not support it.
             * How to handle this error is highly application dependent. */
        } break;
        case PM_EVT_CONN_SEC_CONFIG_REQ:
            // Reject pairing request from an already bonded peer.
            pm_conn_sec_config_t conn_sec_config = {.allow_repairing = false};
            pm_conn_sec_config_reply(p_evt->conn_handle, &conn_sec_config);
        } break;
        case PM_EVT_STORAGE_FULL:
            // Run garbage collection on the flash.
            err_code = fds_gc();
            if (err_code == FDS_ERR_NO_SPACE_IN_QUEUES)
                // Retry.
        } break;
            bool delete_bonds = false;
            advertising_start(&delete_bonds);
        } break;
        case PM_EVT_PEER_DATA_UPDATE_FAILED:
            // Assert.
            APP_ERROR_CHECK(p_evt->params.peer_data_update_failed.error);
        } break;
        case PM_EVT_PEER_DELETE_FAILED:
            // Assert.
            APP_ERROR_CHECK(p_evt->params.peer_delete_failed.error);
        } break;
        case PM_EVT_PEERS_DELETE_FAILED:
            // Assert.
            APP_ERROR_CHECK(p_evt->params.peers_delete_failed_evt.error);
        } break;
        case PM_EVT_ERROR_UNEXPECTED:
            // Assert.
            APP_ERROR_CHECK(p_evt->params.error_unexpected.error);
        } break;
        case PM_EVT_CONN_SEC_START:
        case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED:
        case PM_EVT_PEER_DELETE_SUCCEEDED:
        case PM_EVT_LOCAL_DB_CACHE_APPLIED:
        case PM_EVT_LOCAL_DB_CACHE_APPLY_FAILED:
            // This can happen when the local DB has changed.
        case PM_EVT_SERVICE_CHANGED_IND_SENT:
        case PM_EVT_SERVICE_CHANGED_IND_CONFIRMED:
/**@brief Function for performing battery measurement and updating the Battery Level characteristic
 *        in Battery Service.
static void battery_level_update(void)
    uint8_t  battery_level;
    battery_level = (uint8_t)sensorsim_measure(&m_battery_sim_state, &m_battery_sim_cfg);
    err_code = ble_bas_battery_level_update(&m_bas, battery_level, BLE_CONN_HANDLE_ALL);
    if ((err_code != NRF_SUCCESS) &&
        (err_code != NRF_ERROR_INVALID_STATE) &&
        (err_code != NRF_ERROR_BUSY) &&
        (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
        APP_ERROR_HANDLER(err_code);
/**@brief Function for handling the Battery measurement timer time-out.
 * @details This function will be called each time the battery level measurement timer expires.
 * @param[in] xTimer Handler to the timer that called this function.
 *                   You may get identifier given to the function xTimerCreate using pvTimerGetTimerID.
static void battery_level_meas_timeout_handler(TimerHandle_t xTimer)
    UNUSED_PARAMETER(xTimer);
    battery_level_update();
/**@brief Function for handling the Heart rate measurement timer time-out.
 * @details This function will be called each time the heart rate measurement timer expires.
 *          It will exclude RR Interval data from every third measurement.
static void heart_rate_meas_timeout_handler(TimerHandle_t xTimer)
    static uint32_t cnt = 0;
    uint16_t        heart_rate;
    heart_rate = (uint16_t)sensorsim_measure(&m_heart_rate_sim_state, &m_heart_rate_sim_cfg);
    cnt++;
    err_code = ble_hrs_heart_rate_measurement_send(&m_hrs, heart_rate);
    // Disable RR Interval recording every third heart rate measurement.
    // NOTE: An application will normally not do this. It is done here just for testing generation
    // of messages without RR Interval measurements.
    m_rr_interval_enabled = ((cnt % 3) != 0);
/**@brief Function for handling the RR interval timer time-out.
 * @details This function will be called each time the RR interval timer expires.
static void rr_interval_timeout_handler(TimerHandle_t xTimer)
    if (m_rr_interval_enabled)
        uint16_t rr_interval;
        rr_interval = (uint16_t)sensorsim_measure(&m_rr_interval_sim_state,
                                                  &m_rr_interval_sim_cfg);
        ble_hrs_rr_interval_add(&m_hrs, rr_interval);
/**@brief Function for handling the Sensor Contact Detected timer time-out.
 * @details This function will be called each time the Sensor Contact Detected timer expires.
static void sensor_contact_detected_timeout_handler(TimerHandle_t xTimer)
    static bool sensor_contact_detected = false;
    sensor_contact_detected = !sensor_contact_detected;
    ble_hrs_sensor_contact_detected_update(&m_hrs, sensor_contact_detected);
/**@brief Function for the Timer initialization.
 * @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void)
    // Initialize timer module.
    // Create timers.
    m_battery_timer = xTimerCreate("BATT",
                                   BATTERY_LEVEL_MEAS_INTERVAL,
                                   pdTRUE,
                                   NULL,
                                   battery_level_meas_timeout_handler);
    m_heart_rate_timer = xTimerCreate("HRT",
                                      HEART_RATE_MEAS_INTERVAL,
                                      pdTRUE,
                                      NULL,
                                      heart_rate_meas_timeout_handler);
    m_rr_interval_timer = xTimerCreate("RRT",
                                       RR_INTERVAL_INTERVAL,
                                       pdTRUE,
                                       NULL,
                                       rr_interval_timeout_handler);
    m_sensor_contact_timer = xTimerCreate("SCT",
                                          SENSOR_CONTACT_DETECTED_INTERVAL,
                                          pdTRUE,
                                          NULL,
                                          sensor_contact_detected_timeout_handler);
    // Error checking
    if ( (NULL == m_battery_timer)
         || (NULL == m_heart_rate_timer)
         || (NULL == m_rr_interval_timer)
         || (NULL == m_sensor_contact_timer) )
        APP_ERROR_HANDLER(NRF_ERROR_NO_MEM);
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
 *          device including the device name, appearance, and the preferred connection parameters.
                                          (const uint8_t *)DEVICE_NAME,
                                          strlen(DEVICE_NAME));
    err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_HEART_RATE_SENSOR_HEART_RATE_BELT);
/**@brief Function for initializing the GATT module. */
static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling write events to the LED characteristic.
 * @param[in] p_lbs     Instance of LED Button Service to which the write applies.
 * @param[in] led_state Written/desired state of the LED.
static void led_write_handler(uint16_t conn_handle, ble_lbs_t * p_lbs, uint8_t led_state)
    if (led_state)
        bsp_board_led_on(LEDBUTTON_LED);
        NRF_LOG_INFO("Received LED ON!");
        bsp_board_led_off(LEDBUTTON_LED);
        NRF_LOG_INFO("Received LED OFF!");
 * @details Initialize the Heart Rate, Battery and Device Information services.
    ble_hrs_init_t     hrs_init;
    ble_bas_init_t     bas_init;
    ble_dis_init_t     dis_init;
    ble_lbs_init_t     lbs_init     = {0};
    uint8_t            body_sensor_location;
    // Initialize Heart Rate Service.
    body_sensor_location = BLE_HRS_BODY_SENSOR_LOCATION_FINGER;
    memset(&hrs_init, 0, sizeof(hrs_init));
    hrs_init.evt_handler                 = NULL;
    hrs_init.is_sensor_contact_supported = true;
    hrs_init.p_body_sensor_location      = &body_sensor_location;
    // Here the sec level for the Heart Rate Service can be changed/increased.
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&hrs_init.hrs_hrm_attr_md.cccd_write_perm);
    BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hrs_init.hrs_hrm_attr_md.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hrs_init.hrs_hrm_attr_md.write_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&hrs_init.hrs_bsl_attr_md.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hrs_init.hrs_bsl_attr_md.write_perm);
    err_code = ble_hrs_init(&m_hrs, &hrs_init);
    // Initialize Battery Service.
    memset(&bas_init, 0, sizeof(bas_init));
    // Here the sec level for the Battery Service can be changed/increased.
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&bas_init.battery_level_char_attr_md.cccd_write_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&bas_init.battery_level_char_attr_md.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&bas_init.battery_level_char_attr_md.write_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&bas_init.battery_level_report_read_perm);
    bas_init.evt_handler          = NULL;
    bas_init.support_notification = true;
    bas_init.p_report_ref         = NULL;
    bas_init.initial_batt_level   = 100;
    err_code = ble_bas_init(&m_bas, &bas_init);
    // Initialize Device Information Service.
    memset(&dis_init, 0, sizeof(dis_init));
    ble_srv_ascii_to_utf8(&dis_init.manufact_name_str, (char *)MANUFACTURER_NAME);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&dis_init.dis_attr_md.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&dis_init.dis_attr_md.write_perm);
    err_code = ble_dis_init(&dis_init);
    // Initialize LBS.
    lbs_init.led_write_handler = led_write_handler;
    err_code = ble_lbs_init(&m_lbs, &lbs_init);
/**@brief Function for initializing the sensor simulators. */
static void sensor_simulator_init(void)
    m_battery_sim_cfg.min          = MIN_BATTERY_LEVEL;
    m_battery_sim_cfg.max          = MAX_BATTERY_LEVEL;
    m_battery_sim_cfg.incr         = BATTERY_LEVEL_INCREMENT;
    m_battery_sim_cfg.start_at_max = true;
    sensorsim_init(&m_battery_sim_state, &m_battery_sim_cfg);
    m_heart_rate_sim_cfg.min          = MIN_HEART_RATE;
    m_heart_rate_sim_cfg.max          = MAX_HEART_RATE;
    m_heart_rate_sim_cfg.incr         = HEART_RATE_INCREMENT;
    m_heart_rate_sim_cfg.start_at_max = false;
    sensorsim_init(&m_heart_rate_sim_state, &m_heart_rate_sim_cfg);
    m_rr_interval_sim_cfg.min          = MIN_RR_INTERVAL;
    m_rr_interval_sim_cfg.max          = MAX_RR_INTERVAL;
    m_rr_interval_sim_cfg.incr         = RR_INTERVAL_INCREMENT;
    m_rr_interval_sim_cfg.start_at_max = false;
    sensorsim_init(&m_rr_interval_sim_state, &m_rr_interval_sim_cfg);
/**@brief   Function for starting application timers.
 * @details Timers are run after the scheduler has started.
static void application_timers_start(void)
    // Start application timers.
    if (pdPASS != xTimerStart(m_battery_timer, OSTIMER_WAIT_FOR_QUEUE))
    if (pdPASS != xTimerStart(m_heart_rate_timer, OSTIMER_WAIT_FOR_QUEUE))
    if (pdPASS != xTimerStart(m_rr_interval_timer, OSTIMER_WAIT_FOR_QUEUE))
    if (pdPASS != xTimerStart(m_sensor_contact_timer, OSTIMER_WAIT_FOR_QUEUE))
/**@brief Function for handling the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module which
 *          are passed to the application.
 *          @note All this function does is to disconnect. This could have been done by simply
 *                setting the disconnect_on_fail config parameter, but instead we use the event
 *                handler mechanism to demonstrate its use.
 * @param[in]   p_evt   Event received from the Connection Parameters Module.
/**@brief Function for handling a Connection Parameters error.
/**@brief Function for initializing the Connection Parameters module. */
    // Prepare wakeup buttons.
    uint32_t err_code;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
            NRF_LOG_INFO("Fast advertising.");
            //err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING);
            //APP_ERROR_CHECK(err_code);
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
    uint32_t err_code;
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected");
            //err_code = bsp_indication_set(BSP_INDICATE_CONNECTED);
            bsp_board_led_on(CONNECTED_LED);
            bsp_board_led_off(ADVERTISING_LED);
            // For Button Service
            err_code = app_button_enable();
            NRF_LOG_INFO("Disconnected");
            bsp_board_led_off(CONNECTED_LED);
            err_code = app_button_disable();
            NRF_LOG_DEBUG("BLE_GAP_EVT_SEC_PARAMS_REQUEST - CHeck this one.");
            // Pairing not supported
            err_code = sd_ble_gap_sec_params_reply(m_conn_handle,
                                                   BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP,
                                                   NULL,
                                                   NULL);
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
            NRF_LOG_DEBUG("BLE_GATTS_EVT_SYS_ATTR_MISSING - CHeck this one.");
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
            // No implementation needed.
    uint32_t ram_start = 0;
    // Enable BLE stack.
 * @param[in]   event   Event generated by button press.
static void bsp_event_handler(bsp_event_t event)
    NRF_LOG_DEBUG("BSP Event Handler - shouldn't be there!!!");
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
        case BSP_EVENT_DISCONNECT:
        case BSP_EVENT_WHITELIST_OFF:
/**@brief Function for the Peer Manager initialization. */
static void peer_manager_init(void)
    err_code = pm_init();
    sec_param.bond           = SEC_PARAM_BOND;
    sec_param.mitm           = SEC_PARAM_MITM;
    sec_param.lesc           = SEC_PARAM_LESC;
    sec_param.keypress       = SEC_PARAM_KEYPRESS;
    sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob            = SEC_PARAM_OOB;
    sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc  = 1;
    sec_param.kdist_own.id   = 1;
    sec_param.kdist_peer.enc = 1;
    sec_param.kdist_peer.id  = 1;
/**@brief Clear bond information from persistent storage. */
static void delete_bonds(void)
    NRF_LOG_INFO("Erase bonds!");
    err_code = pm_peers_delete();
/**@brief Function for initializing the Advertising functionality. */
    ble_advertising_init_t init;
    ble_uuid_t m_adv_uuids[] =                                   /**< Universally unique service identifiers. */
      //{BLE_UUID_HEART_RATE_SERVICE, BLE_UUID_TYPE_BLE},
      //{BLE_UUID_BATTERY_SERVICE, BLE_UUID_TYPE_BLE},
      //{BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE},
      {LBS_UUID_SERVICE,  m_lbs.uuid_type}
    uint8_t       flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
    init.advdata.include_appearance      = true;
    init.advdata.flags                   = flags;
    init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
static void log_init(void)
    bsp_event_t startup_event;
    //err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    err_code = bsp_init(BSP_INIT_LEDS, bsp_event_handler);
/**@brief Function for handling events from the button handler module.
 * @param[in] pin_no        The pin that the event applies to.
 * @param[in] button_action The button action (press/release).
static void button_event_handler(uint8_t pin_no, uint8_t button_action)
    NRF_LOG_INFO("Button pressed");
//  return;
    switch (pin_no)
        case LEDBUTTON_BUTTON:
            NRF_LOG_INFO("Send button state change 1.");
            err_code = ble_lbs_on_button_change(m_conn_handle, &m_lbs, button_action);
            if (err_code != NRF_SUCCESS &&
                err_code != BLE_ERROR_INVALID_CONN_HANDLE &&
                err_code != NRF_ERROR_INVALID_STATE &&
            APP_ERROR_HANDLER(pin_no);
/**@brief Function for the LEDs initialization.
 * @details Initializes all LEDs used by the application.
static void leds_init(void)
/**@brief Function for initializing the button handler module.
static void buttons_init(void)
    //The array must be static because a pointer to it will be saved in the button handler module.
    static app_button_cfg_t buttons[] =
        {LEDBUTTON_BUTTON, APP_BUTTON_ACTIVE_LOW, BUTTON_PULL, button_event_handler}
    err_code = app_button_init(buttons, ARRAY_SIZE(buttons),
                               APP_TIMER_TICKS(50));
/**@brief Function for starting advertising. */
    bool erase_bonds = *(bool*)p_erase_bonds;
    if (erase_bonds)
        delete_bonds();
        // Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
        ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
    bsp_board_led_on(ADVERTISING_LED);
#if NRF_LOG_ENABLED
/**@brief Thread for handling the logger.
 * @details This thread is responsible for processing log entries if logs are deferred.
 *          Thread flushes all log entries and suspends. It is resumed by idle task hook.
 * @param[in]   arg   Pointer used for passing some arbitrary information (context) from the
 *                    osThreadCreate() call to the thread.
static void logger_thread(void * arg)
    UNUSED_PARAMETER(arg);
    while (1)
        NRF_LOG_FLUSH();
        vTaskSuspend(NULL); // Suspend myself
#endif //NRF_LOG_ENABLED
/**@brief A function which is hooked to idle task.
 * @note Idle hook must be enabled in FreeRTOS configuration (configUSE_IDLE_HOOK).
void vApplicationIdleHook( void )
#if NRF_LOG_ENABLED
     vTaskResume(m_logger_thread);
/**@brief Function for initializing the clock.
static void clock_init(void)
    ret_code_t err_code = nrf_drv_clock_init();
/**@brief Function for application main entry.
    bool erase_bonds;
    // Initialize modules.
    log_init();
    clock_init();
    // Do not start any interrupt that uses system functions before system initialisation.
    // The best solution is to start the OS before any other initalisation.
#if NRF_LOG_ENABLED
    // Start execution.
    if (pdPASS != xTaskCreate(logger_thread, "LOGGER", 256, NULL, 1, &m_logger_thread))
    // Activate deep sleep mode.
    SCB->SCR |= SCB_SCR_SLEEPDEEP_Msk;
    timers_init();
    //buttons_leds_init(&erase_bonds);
    leds_init();
    buttons_init();
    // Configure and initialize the BLE stack.
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
//    sensor_simulator_init();
    conn_params_init();
    peer_manager_init();
//    application_timers_start();
    // Create a FreeRTOS task for the BLE stack.
    // The task will run advertising_start() before entering its loop.
    nrf_sdh_freertos_init(advertising_start, &erase_bonds);
    NRF_LOG_INFO("HRS FreeRTOS example started.");
    // Start FreeRTOS scheduler.
    vTaskStartScheduler();
    for (;;)
        APP_ERROR_HANDLER(NRF_ERROR_FORBIDDEN);
  • Have you tested with a fresh copy of the SDK, just to make sure there is no changed library files? I will send you compiled hex-files tomorrow that is working on my bord. This way we can test if there is something with the enviroment or something else that is wrong.
  • Attached compiled hex file for PCA10056. Can you test it on your board? ble_app_blinky_freertos_pca10056_s140.hex (remember to also flash the softdevice, as it is not merged with the application)
  • It works with your hex - I left the the softdevice from my project.
    I also tried with the latest SDK - 15.2.0 - the same error - now I get some more data about Hardfault and it is UNALIGNED MEMORY ACCESS.
    The log is:
    <info> app: BLE Blinky FreeRTOS example started.
    <info> app: Fast advertising.
    <info> app: BLE EVT Handler: 16
    <info> app: Connected
    <info> app: BLE EVT Handler: 80
    <info> app: led_write_handler
    <info> app: Received LED ON!
    <info> app: On conn params evtr
    <info> app: BLE EVT Handler: 18
    <info> app: Button pressed
    <info> app: Send button state change 1.
    <info> app: On button event handler exit - code is.
    <info> app: 0
    <error> hardfault: HARD FAULT at 0x0002BEC6
    <error> hardfault: R0: 0xDB681B4B R1: 0x00000979 R2: 0x200070C8 R3: 0x200070C8
    <error> hardfault: R12: 0x20006D68 LR: 0x0002BEB9 PSR: 0x8100000E
    <error> hardfault: Cause: The processor has made an unaligned memory access.
    <info> app: gatt_init
    The I tried the latest Segger Embedded Studio  - did not work.
    Then I changed Code options for Unaligned Access Support. - no luck.
    Then I changed optimization level to 3 (for Release) and it worked.
    Then I also changed Configuration to Debug - and optimization level is Debug (probably 0 ?) and it also worked.
    Then I set back to Release and Opt. Level to None and get the same error again.
    So basically now I have working option, but I am not totally satisfied as I do not know exactly why this error occurs.
  • Hi Jardis,
    I took your main.c and I could see the hardfault. This was because of the stack corruption as the logs were using too much of the free stack.
    I disabled the logs in sdk_config.h file
    and also doubled the below in FreeRTOSConfig.h file
    #define configTOTAL_HEAP_SIZE                                                     ( 4096 * 2 )
    no more hardfaults after this
  • Hi Susheel,
    obviously there is some problem, when also "LogTask" is running.
    It is true, that if you turn it off, the other task (and the idle task) will run "normally".
    But just increase of heap size, doesn't help.
    I am not an expert for the FreeRTOS, but I believe, that task stack is allocated from HEAP.
    Even if you increase the heap and increase the allocated LOG task stack it doesn't help (and there is plenty of RAM available)
    And all this settings are the same in debug and release (but the alignment of the code is different as there are different optimizations involved).
    I also enabled:
    #define configCHECK_FOR_STACK_OVERFLOW 1
    #define configUSE_MALLOC_FAILED_HOOK 1
    in FreeRTOSConfig.h and appropriate functions in main.c:
    void vApplicationMallocFailedHook (void)
    void vApplicationStackOverflowHook( xTaskHandle *pxTask, signed char *pcTaskName )
    but I never capture any of upper errors.
