Regarding Python Scripts for nrf52840 to connect and transfer data.
Hi ,
What I am trying:-
-connect the custom board with nrf52840 chip using nrf52 dongle on pc with python.
-Already set some commands on custom board so when my pc (via dongle) connects to custom board, I want to send some commands and accordingly receive the response.
For this I got my hands-on nrf dongle to give my laptop a BLE access.
And I am trying to access the board using dongle (using python script) and I am getting below error,
raise NordicSemiException('Failed to {}. Error code: {}'.format(wrapped.__name__, err_code))
pc_ble_driver_py.exceptions.NordicSemiException: Failed to open. Error code: 13.
Would anyone able to tell me how do i resolve this.
I want to have python code that can connect and do some data transfer over BLE using Dongle connected to my pc and I have tried with hart_rate_monitor unsuccessfully.
EDIT 1:- I am able to scan and connect my board using the nRF Connect windows app. Same I wanted to implement over python.
Hinesh
  • Hi
    Enclosing screenshot from app.
    sorry, was misunderstood previously.
    In mobile app I can see two unknown services, and for both I am pasting screen shots here. and you were correct about mixed up on several uuid's.
    So does it work now? If not, what is your code now?
    Terje
  • Hi
    It is not working.
    My code Is same that I have pasted above.
    Any changes I do I end up in CCCD UUID not valid.
    I needed your input here.
    EDIT: - Still getting the same error.
    Received advertisment report, address: 0x5031ADC0000A, device_name: POC1_2-3
    New connection: 0
    ATT MTU exchanged: conn_handle=0 att_mtu=23
    ATT MTU exchange response: conn_handle=0
      File "C:\Program Files\JetBrains\PyCharm Community Edition 2018.1.3\helpers\pydev\pydevd.py", line 1664, in <module>
        main()
      File "C:\Program Files\JetBrains\PyCharm Community Edition 2018.1.3\helpers\pydev\pydevd.py", line 1658, in main
        globals = debugger.run(setup['file'], None, None, is_module)
      File "C:\Program Files\JetBrains\PyCharm Community Edition 2018.1.3\helpers\pydev\pydevd.py", line 1068, in run
        pydev_imports.execfile(file, globals, locals)  # execute the script
      File "C:/My_Projects/Script.py", line 269, in <module>
        main(serial_port)
      File "C:/My_Projects/Script.py", line 250, in main
        conn_handle = collector.connect_and_discover()
      File "C:/My_Projects/Script.py", line 200, in connect_and_discover
        self.adapter.enable_notification(new_conn,BLEUUID(0x2902, CCCD_BASE_UUID))#BLEUUID(0x2902, DC_SERVICE_BASE_UUID))  # BLEUUID(BLEUUID.Standard.battery_level))
      File "C:\Python27\lib\site-packages\pc_ble_driver_py\ble_driver.py", line 125, in wrapper
        err_code = wrapped(*args, **kwargs)
      File "C:\Python27\lib\site-packages\pc_ble_driver_py\ble_adapter.py", line 254, in enable_notification
        raise NordicSemiException('CCCD not found')
    pc_ble_driver_py.exceptions.NordicSemiException: CCCD not found
    It is still hard to tell without getting to see the exact code that you run. In order to figure out what is wrong, it is necessary to have both the code and the error message.
    In this case also the device in the other end is important, but you have already provided enough information about it and I assume that that one does not change. The code however you have changed several times up until now, and so it is important to know what it looks like right now.
    Terje
  • Hi
    Thank you for the response.
    You are correct the code on the other end will not change.
    however the code which I am using to connect also I keeping same, except checking with UUID's. A trial and error to remove the ': CCCD not found' by debugging.
    inserting code which is right now, but not working
    import Queue
    import json
    import time
    import sys
    from datetime import datetime, timedelta
    from bitstruct import *
    from pprint import pformat
    import binascii
    from pc_ble_driver_py.observers import *
    from nordicsemi.ble_adapter import *
    try:
        with open("Config_Files/Connection_Settings.json")as conn:
            config = json.load(conn)
    except Exception as e:
        print str(e)
        print 'Could not open settings file'
        raw_input("Press ENTER to exit...")
        quit()
    ##### NRF PART ################
    CCCD_UUID = '00002902-0000-1000-8000-00805f9b34fb'
    DC_SERVICE_BASE_UUID = BLEUUIDBase([0x00, 0x00, 0x22, 0x22, 0x00, 0x00, 0x10, 0x00,
                                        0x80, 0x00, 0x00, 0x80, 0x5f, 0x9b, 0x34, 0xfb])
    DATA_CHAR_UUID  = BLEUUID(0x2222, DC_SERVICE_BASE_UUID)
    DATA2_CHAR_UUID = BLEUUID(0x3333, DC_SERVICE_BASE_UUID)
    # BASE_UUID = BLEUUIDBase([0x8E, 0xC9, 0x00, 0x00, 0xF3, 0x15, 0x4F, 0x60,
    #                          0x9F, 0xB8, 0x83, 0x88, 0x30, 0xDA, 0xEA, 0x50])
    # DC_SERVICE_BASE_UUID = BLEUUIDBase([0x00, 0x00, 0x22, 0x22, 0x00, 0x00, 0x10, 0x00,
    #                                     0x80, 0x00, 0x00, 0x80, 0x5f, 0x9b, 0x34, 0xfb])
    CCCD_BASE_UUID = BLEUUIDBase([0x00, 0x00, 0x29, 0x02, 0x00, 0x00, 0x10, 0x00,
                                  0x80, 0x00, 0x00, 0x80, 0x5F, 0x9B, 0x34, 0xFB])
    # Buttonless characteristics
    BLE_DFU_BUTTONLESS_CHAR_UUID = BLEUUID(0x2902, CCCD_BASE_UUID)
    BLE_DFU_BUTTONLESS_BONDED_CHAR_UUID = BLEUUID(0x2902, CCCD_BASE_UUID)
    SERVICE_CHANGED_UUID = BLEUUID(0x2A05)
    def init(conn_ic_id):
        global BLEDriver, BLEAdvData, BLEEvtID, BLEAdapter, BLEEnableParams, BLEGapTimeoutSrc, BLEUUID
        from pc_ble_driver_py import config
        config.__conn_ic_id__ = conn_ic_id
        from pc_ble_driver_py.ble_driver import BLEDriver, BLEAdvData, BLEEvtID, BLEEnableParams, BLEGapTimeoutSrc, BLEUUID
        from pc_ble_driver_py.ble_adapter import BLEAdapter
        global nrf_sd_ble_api_ver
        nrf_sd_ble_api_ver = config.sd_api_ver_get()
    class HRCollector(BLEDriverObserver, BLEAdapterObserver):
        def __init__(self, adapter):
            super(HRCollector, self).__init__()
            self.adapter = adapter
            self.conn_q = Queue.Queue()
            self.adapter.observer_register(self)
            self.adapter.driver.observer_register(self)
        def open(self):
            self.adapter.driver.open()
            ble_enable_params = BLEEnableParams(vs_uuid_count=1,
                                                service_changed=False,
                                                periph_conn_count=0,
                                                central_conn_count=CONNECTIONS,
                                                central_sec_count=CONNECTIONS)
            if nrf_sd_ble_api_ver >= 3:
                print("Enabling larger ATT MTUs")
                ble_enable_params.att_mtu = 50
            self.adapter.driver.ble_enable(ble_enable_params)
        def close(self):
            self.adapter.driver.close()
        @property
        def connect_and_discover(self):
            self.adapter.driver.ble_gap_scan_start()
            new_conn = self.conn_q.get(timeout=60)
                att_mtu = self.adapter.att_mtu_exchange(new_conn)
            self.adapter.service_discovery(new_conn)
            # self.adapter.enable_notification(new_conn, BLEUUID(BLEUUID.Standard.heart_rate))
            return new_conn
        def on_gap_evt_connected(self, ble_driver, conn_handle, peer_addr, role, conn_params):
            print('New connection: {}'.format(conn_handle))
            self.conn_q.put(conn_handle)
        def on_gap_evt_disconnected(self, ble_driver, conn_handle, reason):
            print('Disconnected: {} {}'.format(conn_handle, reason))
        def on_gap_evt_timeout(self, ble_driver, conn_handle, src):
            if src == BLEGapTimeoutSrc.scan:
                ble_driver.ble_gap_scan_start()
        def on_gap_evt_adv_report(self, ble_driver, conn_handle, peer_addr, rssi, adv_type, adv_data):
            dev_name_list = None
            if BLEAdvData.Types.complete_local_name in adv_data.records:
                dev_name_list = adv_data.records[BLEAdvData.Types.complete_local_name]
            elif BLEAdvData.Types.short_local_name in adv_data.records:
                dev_name_list = adv_data.records[BLEAdvData.Types.short_local_name]
            else:
                return
            dev_name = "".join(chr(e) for e in dev_name_list)
            address_string = "".join("{0:02X}".format(b) for b in peer_addr.addr)
            print('Received advertisment report, address: 0x{}, device_name: {}'.format(address_string,
        dev_name))
            if (dev_name == TARGET_DEV_NAME):
                self.adapter.connect(peer_addr)
        def on_notification(self, ble_adapter, conn_handle, uuid, data):
            print('Connection: {}, {} = {}'.format(conn_handle, uuid, data))
        def on_att_mtu_exchanged(self, ble_driver, conn_handle, att_mtu):
            print('ATT MTU exchanged: conn_handle={} att_mtu={}'.format(conn_handle, att_mtu))
        def on_gattc_evt_exchange_mtu_rsp(self, ble_driver, conn_handle, **kwargs):
            print('ATT MTU exchange response: conn_handle={}'.format(conn_handle))
    def main(serial_port):
        print('Serial port used: {}'.format(serial_port))
        driver = BLEDriver(serial_port=serial_port, auto_flash=True)
        adapter = BLEAdapter(driver)
        collector = HRCollector(adapter)
        collector.open()
        adapter.write_req(conn_handle, CCCD_UUID, [3])#RAW_TYPE)
        # collector.connect_and_discover()
        # collector.wri
    if __name__ == "__main__":
        serial_port = None
        # if len(sys.argv) < 2:
        #     print("Please specify connectivity IC identifier (NRF51, NRF52)")
        #     exit(1)
        init("NRF52")
        if len(sys.argv) == 3:
            serial_port = sys.argv[2]
        else:
            descs = BLEDriver.enum_serial_ports()
            choices = ['{}: {}'.format(d.port, d.serial_number) for d in descs]
            choice = '0'  # item_choose(choices)
            serial_port = port_enter  # "COM12" #descs[choice].port
            main(serial_port)
            quit()
    ##### NRF PART ####### HINESH ############## NRF PART ###### #########
