static void hids_init(void) migrated from sdk12.3 to sdk15.0 is not available
In (SDK12.3 NRF51822) is normally used.
But migrate to (SDK15.0 NRF52832) and crash once connected to bluetooth
    uint32_t                   err_code;
    ble_hids_init_t            hids_init_obj;
    ble_hids_inp_rep_init_t    input_report_array[2];
    ble_hids_inp_rep_init_t  * p_input_report;
    ble_hids_outp_rep_init_t   output_report_array[1];
    ble_hids_outp_rep_init_t * p_output_report;
    uint8_t                    hid_info_flags;
    static uint8_t report_map_data[] =
        0x05, 0x01,                 // Usage Page (Generic Desktop)
        0x09, 0x06,                 // Usage (Keyboard)
        0xA1, 0x01,                 // Collection (Application)
		0x85, 0x01,                     //     Report Id (1)
        0x05, 0x07,                 //     Usage Page (Key Codes)
        0x19, 0xe0,                 //     Usage Minimum (224)
        0x29, 0xe7,                 //     Usage Maximum (231)
        0x15, 0x00,                 //     Logical Minimum (0)
        0x25, 0x01,                 //     Logical Maximum (1)
        0x75, 0x01,                 //     Report Size (1)
        0x95, 0x08,                 //     Report Count (8)
        0x81, 0x02,                 //     Input (Data, Variable, Absolute)
        0x95, 0x01,                 //     Report Count (1)
        0x75, 0x08,                 //     Report Size (8)
        0x81, 0x01,                 //     Input (Constant) reserved byte(1)
        0x95, 0x05,                 //     Report Count (5)
        0x05, 0x08,                 //     Usage Page (Page# for LEDs)
        0x19, 0x01,                 //     Usage Minimum (1)
        0x29, 0x05,                 //     Usage Maximum (5)
        0x91, 0x02,                 //     Output (Data, Variable, Absolute), Led report
        0x75, 0x03,                 //     Report Size (3)
        0x91, 0x01,                 //     Output (Data, Variable, Absolute), Led report padding
        0x95, 0x06,                 //     Report Count (6)
        0x25, 0x65,                 //     Logical Maximum (101)
        0x05, 0x07,                 //     Usage Page (Key codes)
        0x19, 0x00,                 //     Usage Minimum (0)
        0x29, 0x65,                 //     Usage Maximum (101)
        0x81, 0x00,                 //     Input (Data, Array) Key array(6 bytes)
        0x09, 0x05,                 //     Usage (Vendor Defined)
        0x26, 0xFF, 0x00,           //     Logical Maximum (255)
        0x75, 0x08,                 //     Report Count (2)
        0x95, 0x02,                 //     Report Size (8 bit)
        0xB1, 0x02,                 //     Feature (Data, Variable, Absolute)
        0xC0,                       // End Collection (Application)
        // Report ID 2: Advanced buttons
        0x05, 0x0C,                     // Usage Page (Consumer)
        0x09, 0x01,                     // Usage (Consumer Control)
        0x85, 0x02,                     //     Report Id (2)
        0x15, 0x00,                     //     Logical minimum (0)
        0x25, 0x01,                     //     Logical maximum (1)
        0x09, 0xCD,                     //     Usage (Play/Pause)
        0x81, 0x02,                     //     Input (Data,Value,Relative,Bit Field)
        0x0A, 0x83, 0x01,               //     Usage (AL Consumer Control Configuration)
        0x09, 0xB5,                     //     Usage (Scan Next Track)
        0x09, 0xB6,                     //     Usage (Scan Previous Track)
        0x09, 0xEA,                     //     Usage (Volume Down)
        0x09, 0xE9,                     //     Usage (Volume Up)
        0x0A, 0x25, 0x02,               //     Usage (AC Forward)
        0x0A, 0x24, 0x02,               //     Usage (AC Back)
        0xC0                            // End Collection
    // Initialize HID Service - keyboard descriptor input and output report
    p_input_report                      = &input_report_array[INPUT_REPORT_KEYS_INDEX];
    p_input_report->max_len             = INPUT_REPORT_KEYS_MAX_LEN;
    p_input_report->rep_ref.report_id   = INPUT_REP_REF_ID;
    p_input_report->rep_ref.report_type = BLE_HIDS_REP_TYPE_INPUT;
    BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&p_input_report->security_mode.cccd_write_perm);
    BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&p_input_report->security_mode.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&p_input_report->security_mode.write_perm);
    p_output_report                      = &output_report_array[OUTPUT_REPORT_INDEX];
    p_output_report->max_len             = OUTPUT_REPORT_MAX_LEN;
    p_output_report->rep_ref.report_id   = OUTPUT_REP_REF_ID;
    p_output_report->rep_ref.report_type = BLE_HIDS_REP_TYPE_OUTPUT;
	// 	Initialize HID Service - ConsumerControl
    p_input_report                      = &input_report_array[INPUT_CCONTROL_KEYS_INDEX];
    p_input_report->max_len             = INPUT_CC_REPORT_KEYS_MAX_LEN;
    p_input_report->rep_ref.report_id   = INPUT_CC_REP_REF_ID;
    BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&p_output_report->security_mode.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&p_output_report->security_mode.write_perm);
    hid_info_flags = HID_INFO_FLAG_REMOTE_WAKE_MSK | HID_INFO_FLAG_NORMALLY_CONNECTABLE_MSK;
    memset(&hids_init_obj, 0, sizeof(hids_init_obj));
    hids_init_obj.evt_handler                    = on_hids_evt;
    hids_init_obj.error_handler                  = service_error_handler;
    hids_init_obj.is_kb                          = true;
    hids_init_obj.is_mouse                       = false;
    hids_init_obj.inp_rep_count                  = 2;
    hids_init_obj.p_inp_rep_array                = input_report_array;
    hids_init_obj.outp_rep_count                 = 1;
    hids_init_obj.p_outp_rep_array               = output_report_array;
    hids_init_obj.feature_rep_count              = 0;
    hids_init_obj.p_feature_rep_array            = NULL;
    hids_init_obj.rep_map.data_len               = sizeof(report_map_data);
    hids_init_obj.rep_map.p_data                 = report_map_data;
    hids_init_obj.hid_information.bcd_hid        = BASE_USB_HID_SPEC_VERSION;
    hids_init_obj.hid_information.b_country_code = 0;
    hids_init_obj.hid_information.flags          = hid_info_flags;
    hids_init_obj.included_services_count        = 0;
    hids_init_obj.p_included_services_array      = NULL;
    BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.rep_map.security_mode.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hids_init_obj.rep_map.security_mode.write_perm);
    BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.hid_information.security_mode.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hids_init_obj.hid_information.security_mode.write_perm);
        &hids_init_obj.security_mode_boot_kb_inp_rep.cccd_write_perm);
    BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_boot_kb_inp_rep.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hids_init_obj.security_mode_boot_kb_inp_rep.write_perm);
    BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_boot_kb_outp_rep.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_boot_kb_outp_rep.write_perm);
    BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_protocol.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_protocol.write_perm);
    BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hids_init_obj.security_mode_ctrl_point.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&hids_init_obj.security_mode_ctrl_point.write_perm);
    err_code = ble_hids_init(&m_hids, &hids_init_obj);
