upload error while updating firmware via OTA using nrf connect application.
I am trying to update the firmware via OTA , while uploading the firmware I am getting "upload failed" message on the nrf connect application.
I am using nrf51422 board,sdk v10.0.0 .
I have downloaded the "dual_bank_ble_s110" boot loader firmware in the nrf51422 board.In nrf connect I have connected to "DfuTarg".
I have created a zip file for "ble_hrs" example, so when I am trying to update the firmware from nrf connect I am getting "UPLOAD FAILED" message on the application.
Could anybody help me in solving this?
Thanks in advance.
    I will suggest you to first go through the documentation and see if everything is done correctly.
  • Hi Mttrinh,
    I have done the things as per of the document, I have tested the default test image and I am able to update it via OTA.
    "C:\Users\Dell\Downloads\nRF51_SDK_10.0.0_dc26b5e\examples\dfu\ble_dfu_send_hex\test_images_update_nrf51"
    Now I am tying to update the "ble_app_hrs with dfu"
    C:\Users\Dell\Downloads\nRF51_SDK_10.0.0_dc26b5e\examples\ble_peripheral\ble_app_hrs\pca10028\s110_with_dfu
    As DFU is already supported for this example I trying to update it from nrf connect. While choosing "application" for updating there is no "init.dat" is creating.
    I tried updating this example by creating a "dfu_zip" file by using the following command.
    C:\Program Files (x86)\Nordic Semiconductor\Master Control Panel\3.10.0.14\nrf>nrfutil dfu genpkg --application "C:\Users\kishor.babu\Downloads\nRF51_SDK_10.0.0_dc26b5e\examples\ble_peripheral\ble_app_hrs\pca10028\s110_with_dfu\arm5_no_packs\_build\nrf51422_xxac_s110.hex"  --application-version 4 --dev-revision 0xffff --dev-type 0xffff --sd-req 0x0080 "D:\dfu_test\dfu_hrs.zip"
    But while updating this "zip" file I am getting "operation failed" error in the nrf toolbox.
    So, please let me know what may be the issue and how I can resolve it.
    Can you update nrfutil to the latest version and try again? It can be found here.
  •  updated the nrfutil but when I am trying to generate the zip file I am getting "Error: No such command "genpkg".
    The other thing is when I loaded and connected to "ble_app_hrs with dfu" and trying to upload the dfu test image "dfu_test_app_hrm_s110 i, it is not happening showing the error "DFU_DEVICE_DISCONNECTED".
    I want to update dfu using sdk v10.0.0 only, so, how can I make it  to work?
  • Did some testing over here and it seems like the new nrfutil doesn't work with SDK10.0.0. If you instead use the nrfutil found in the Master Control Panel\3.10.0.14\nrf, but change --sd-req 0x0080 to 0x0064.
    We tried to flash "ble_app_hrs with dfu" and uploading the dfu test image, everything seems to work fine over here at least. I would recommend you to using SDK12.3.0 instead, is there a reason why you are using SDK10.0.0?
