Failed to read/write ADXL362 data using nRF52840
Hello All,
I have connected nRF52840 with ADXL362 over SPI, and try to read/write data on "Power Control register".
The process I follow,
1. Rest ADXL362.
2. Write data 0x02 in "Power Control register" of ADXL362.
2. Read value of  "Power Control register" of ADXL362.
But every time I read data form ADXL362 I got 0x00 value.
Logs are attached.
For testing this I have modify SPI test code located at "nRF5_SDK_15.0.0_a53641a\examples\peripheral\spi"
Code is also attached here, will you please guide me, If I did any wrong in SPI configuration?
I am little bit confuse of "tx_buffer_length" & "rx_buffer_length" value passing in nrf_drv_spi_transfer() function.
Does the values of "tx_buffer_length" & "rx_buffer_length" are correct at line no 101 & 118 in main.c file?
Thanks in advance.
<info> app: #########################################################
<info> app: SPI example started.
<info> SPIM: Function: nrfx_spim_init, error code: NRF_SUCCESS.
<info> app: <---- ADXL325 reset ---->
<info> SPIM: Function: spim_xfer, error code: NRF_SUCCESS.
<debug> SPIM: Event: NRF_SPIM_EVENT_END.
<info> app: Transfer completed.
<info> app:  00 00 00               |...
<info> app: soft reset
<info> app: <--- ADXL325 set power control register --->
<info> app: ** 0 0 0
<info> app:  00 00                  |..
<info> app: Setting Measeurement Mode - Reg 2D before = 0
<info> app: -----------
<info> app: , Reg 2D after = 0
 * Copyright (c) 2015 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
#include "nrf_drv_spi.h"
#include "nrf_gpio.h"
#include "nrf_delay.h"
#include "boards.h"
#include "app_error.h"
#include <string.h>
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define SPI_INSTANCE  0 /**< SPI instance index. */
static const nrf_drv_spi_t spi = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE);  /**< SPI instance. */
static volatile bool spi_xfer_done;  /**< Flag used to indicate that SPI instance completed the transfer. */
#define TEST_STRING "Nordic"
static uint8_t       m_tx_buf[] = TEST_STRING;           /**< TX buffer. */
static uint8_t       m_rx_buf[sizeof(TEST_STRING) + 1];    /**< RX buffer. */
static const uint8_t m_length = sizeof(m_tx_buf);        /**< Transfer length. */
uint8_t tx[3] = { 0x0B, 0x00, 0x00 };
uint8_t rx[3] = { 0 };
 * @brief SPI user event handler.
 * @param event
void spi_event_handler(nrf_drv_spi_evt_t const * p_event,
                       void *                    p_context)
    spi_xfer_done = true;
    NRF_LOG_INFO("Transfer completed.");
    //NRF_LOG_INFO("%d.", p_event->type);
    //NRF_LOG_INFO("%d %d %s", p_event->data.done.rx_length, p_event->data.done.tx_length, p_event->data.done.p_tx_buffer);
//    if (m_rx_buf[0] != 0)
    if (rx[0] != 0)
        NRF_LOG_INFO(" Received:");
        NRF_LOG_HEXDUMP_INFO(m_rx_buf, strlen((const char *)m_rx_buf));
   NRF_LOG_HEXDUMP_INFO(rx, 3);
#define XL362_REG_WRITE          0x0a
#define XL362_REG_READ           0x0b
#define XL362_POWER_CTL          0x2d
#define XL362_SOFT_RESET         0x1f
#define XL362_SOFT_RESET_KEY     0x52
uint8_t adxl362_read_one_reg(uint8_t reg_address)
  uint8_t tx_buff[3] = {0};
  uint8_t rx_buff[3] = {0};
  // </CS down> <command byte (0x0A or 0x0B)> <address byte> <data byte> <additional data bytes for multi-byte> � </CS up>
  tx_buff[0] = XL362_REG_READ;
  tx_buff[1] = reg_address;
  tx_buff[2] = 0x00;            // dummy byte
   APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, tx_buff, 3, rx_buff, 1));
   NRF_LOG_INFO("** %d %d %d", rx[0], rx[1], rx[2]);
   NRF_LOG_HEXDUMP_INFO(rx, 2);
   return rx_buff[2];
void adxl362_write_one_reg(uint8_t reg_address, uint8_t reg_value)
  tx_buff[0] = XL362_REG_WRITE;
  tx_buff[2] = reg_value;
   APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, tx_buff, 3, rx_buff, 3));
//   NRF_LOG_INFO("** %d %d %d", rx[0], rx[1], rx[2]);
//   NRF_LOG_HEXDUMP_INFO(rx, 2);
void adxl362_reset()
  // soft reset
  adxl362_write_one_reg(XL362_SOFT_RESET, XL362_SOFT_RESET_KEY);
  // Note: A latency of approximately 0.5 ms is required after soft reset.
  nrf_delay_ms(200);
  NRF_LOG_INFO("soft reset");
void beginMeasure()
  uint8_t reg_val = 0x0;
  // read Reg 2D before modifying for measure mode
  reg_val = adxl362_read_one_reg(XL362_POWER_CTL);
  NRF_LOG_INFO("Setting Measeurement Mode - Reg 2D before = %d", reg_val);
  // turn on measurement mode
  uint8_t temp_write = (reg_val | 0x02);  // turn on measurement bit in Reg 2D
  adxl362_write_one_reg(XL362_POWER_CTL, temp_write);
  nrf_delay_ms(10);
  //nrf_delay_ms(200);
  NRF_LOG_INFO("-----------");
  NRF_LOG_INFO(", Reg 2D after = %d", reg_val);
    NRF_LOG_INFO("#########################################################");
    NRF_LOG_INFO("SPI example started.");
    nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
#if 1
    spi_config.ss_pin   = NRF_GPIO_PIN_MAP(0,17);       //17
    spi_config.miso_pin = NRF_GPIO_PIN_MAP(0,23);       //23
    spi_config.mosi_pin = NRF_GPIO_PIN_MAP(0,21);       //21
    spi_config.sck_pin  = NRF_GPIO_PIN_MAP(0,19);       //19
#else
    spi_config.ss_pin   = SPI_SS_PIN;
    spi_config.miso_pin = SPI_MOSI_PIN;
    spi_config.mosi_pin = SPI_MISO_PIN;
    spi_config.sck_pin  = SPI_SCK_PIN;
    spi_config.frequency = NRF_SPIM_FREQ_1M;
//    spi_config.bit_order    = NRF_DRV_SPI_BIT_ORDER_LSB_FIRST;
//    spi_config.irq_priority = NRFX_SPIM_DEFAULT_CONFIG_IRQ_PRIORITY;
//    spi_config.mode = NRF_SPIM_MODE_3;
     ret_code_t ret = nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL);
     if(ret != NRF_SUCCESS)
        NRF_LOG_INFO("SPI init failed:  %d", ret);
    //APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, NULL, NULL));
    NRF_LOG_INFO("<---- ADXL325 reset ---->");
    adxl362_reset();
    NRF_LOG_INFO("<--- ADXL325 set power control register --->");
    beginMeasure();
    while (1)
#if 0
        // Reset rx buffer and transfer done flag
        memset(m_rx_buf, 0, m_length);
        spi_xfer_done = false;
//        APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, tx, 3, rx, 3));
          nrf_drv_spi_transfer(&spi, tx, 3, rx, 1);
        NRF_LOG_INFO("SPI tx: %d", ret);
      uint8_t  reg_val = adxl362_read_one_reg(XL362_POWER_CTL);
        while (!spi_xfer_done)
            __WFE();
        NRF_LOG_FLUSH();
//        bsp_board_led_invert(BSP_BOARD_LED_0);
        nrf_delay_ms(200);
sdk_config.h
  • Hello Sir,
    Thanks for replay.
    1. Could you post your latest source code that performs the SPI read/write?
    Ans: Please find spim_adxl362.zip file contains source code for reading 0x01 register.
    3. Could you post the arduino code used?
    For Arduino I follow this document
    1. Open ADXL362_SimpleRead example sketch.
    2. To read 0x01 register modify ADXL362 library. added readDevIDData() function in it. ADXL362.cpp file is attached here.
    3. called readDevIDData() in loop.
    Note: SDK version: nRF5_SDK_15.0.0_a53641a
    Thanks in advance.
    4237.ADXL362.cpp6747.ADXL362.h3247.spim_adxl362.zip
  • I cannot see any difference in the way the communication is performed, other than the nRF sends the 3 bytes without any delay.
    You could try to split up the transfer into 1 byte transfers, like this:
            for (int i = 0; i < 3; i++){
                APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, &m_tx_buf[i], 1, &m_rx_buf[i], 1));
                    __WFE();
    However; the sensors datasheet states that this should work without delay in SPI communication.
    Could you please provide a scope/logic analyzer trace of all SPI lines at the same time, with both arduino and the nRF solution? It is close to impossible to see whats happening without having all SPI lines in the same trace.
    Håkon
    I'm experiencing the same issue with the ADXL362 and the NRF52840DK.  Were you able to resolve the issue?  I suspect this is an issue with the ADXL362, not the Nordic.  I'm going to try breaking up the writes next.
    If you create a new case, with logic traces, and explain your specific setup (which GPIOs you're using etc), we can help you out. This case is over 2 years old, and is likely outdated for your use-case (SDK used etc).
    Håkon
  • I recently had the same problem with the ADXL362 on an nRF52832DK board. I connected the ADXL362 (on a developer board "ADXL362/346") with a short cable (about 5 cm).
    After many attempts in all possible directions (clock, source code, waveform, resistances in signal lines), I found a solution:
    I removed the cables and soldered a pin strip directly to the "ADXL362/346" developer board (without VIN, this is connected to VDD on P1 by cable) and plugged it directly into P4 (pin 0.19 to GND). Since this is plugged in directly, the ADXL362 works without any problems.
    I don't find that plausible, but I was able to continue my project with it.
    I'm not sure if it will help others, but it's worth a try.
    And it would be nice to hear if this has helped others as well.
    Best regards
    Marko
