Failed to read/write ADXL362 data using nRF52840
Hello All,
I have connected nRF52840 with ADXL362 over SPI, and try to read/write data on "Power Control register".
The process I follow,
1. Rest ADXL362.
2. Write data 0x02 in "Power Control register" of ADXL362.
2. Read value of  "Power Control register" of ADXL362.
But every time I read data form ADXL362 I got 0x00 value.
Logs are attached.
For testing this I have modify SPI test code located at "nRF5_SDK_15.0.0_a53641a\examples\peripheral\spi"
Code is also attached here, will you please guide me, If I did any wrong in SPI configuration?
I am little bit confuse of "tx_buffer_length" & "rx_buffer_length" value passing in nrf_drv_spi_transfer() function.
Does the values of "tx_buffer_length" & "rx_buffer_length" are correct at line no 101 & 118 in main.c file?
Thanks in advance.
<info> app: #########################################################
<info> app: SPI example started.
<info> SPIM: Function: nrfx_spim_init, error code: NRF_SUCCESS.
<info> app: <---- ADXL325 reset ---->
<info> SPIM: Function: spim_xfer, error code: NRF_SUCCESS.
<debug> SPIM: Event: NRF_SPIM_EVENT_END.
<info> app: Transfer completed.
<info> app:  00 00 00               |...
<info> app: soft reset
<info> app: <--- ADXL325 set power control register --->
<info> app: ** 0 0 0
<info> app:  00 00                  |..
<info> app: Setting Measeurement Mode - Reg 2D before = 0
<info> app: -----------
<info> app: , Reg 2D after = 0
 * Copyright (c) 2015 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
#include "nrf_drv_spi.h"
#include "nrf_gpio.h"
#include "nrf_delay.h"
#include "boards.h"
#include "app_error.h"
#include <string.h>
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define SPI_INSTANCE  0 /**< SPI instance index. */
static const nrf_drv_spi_t spi = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE);  /**< SPI instance. */
static volatile bool spi_xfer_done;  /**< Flag used to indicate that SPI instance completed the transfer. */
#define TEST_STRING "Nordic"
static uint8_t       m_tx_buf[] = TEST_STRING;           /**< TX buffer. */
static uint8_t       m_rx_buf[sizeof(TEST_STRING) + 1];    /**< RX buffer. */
static const uint8_t m_length = sizeof(m_tx_buf);        /**< Transfer length. */
uint8_t tx[3] = { 0x0B, 0x00, 0x00 };
uint8_t rx[3] = { 0 };
 * @brief SPI user event handler.
 * @param event
void spi_event_handler(nrf_drv_spi_evt_t const * p_event,
                       void *                    p_context)
    spi_xfer_done = true;
    NRF_LOG_INFO("Transfer completed.");
    //NRF_LOG_INFO("%d.", p_event->type);
    //NRF_LOG_INFO("%d %d %s", p_event->data.done.rx_length, p_event->data.done.tx_length, p_event->data.done.p_tx_buffer);
//    if (m_rx_buf[0] != 0)
    if (rx[0] != 0)
        NRF_LOG_INFO(" Received:");
        NRF_LOG_HEXDUMP_INFO(m_rx_buf, strlen((const char *)m_rx_buf));
   NRF_LOG_HEXDUMP_INFO(rx, 3);
#define XL362_REG_WRITE          0x0a
#define XL362_REG_READ           0x0b
#define XL362_POWER_CTL          0x2d
#define XL362_SOFT_RESET         0x1f
#define XL362_SOFT_RESET_KEY     0x52
uint8_t adxl362_read_one_reg(uint8_t reg_address)
  uint8_t tx_buff[3] = {0};
  uint8_t rx_buff[3] = {0};
  // </CS down> <command byte (0x0A or 0x0B)> <address byte> <data byte> <additional data bytes for multi-byte> � </CS up>
  tx_buff[0] = XL362_REG_READ;
  tx_buff[1] = reg_address;
  tx_buff[2] = 0x00;            // dummy byte
   APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, tx_buff, 3, rx_buff, 1));
   NRF_LOG_INFO("** %d %d %d", rx[0], rx[1], rx[2]);
   NRF_LOG_HEXDUMP_INFO(rx, 2);
   return rx_buff[2];
void adxl362_write_one_reg(uint8_t reg_address, uint8_t reg_value)
  tx_buff[0] = XL362_REG_WRITE;
  tx_buff[2] = reg_value;
   APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, tx_buff, 3, rx_buff, 3));
//   NRF_LOG_INFO("** %d %d %d", rx[0], rx[1], rx[2]);
//   NRF_LOG_HEXDUMP_INFO(rx, 2);
void adxl362_reset()
  // soft reset
  adxl362_write_one_reg(XL362_SOFT_RESET, XL362_SOFT_RESET_KEY);
  // Note: A latency of approximately 0.5 ms is required after soft reset.
  nrf_delay_ms(200);
  NRF_LOG_INFO("soft reset");
void beginMeasure()
  uint8_t reg_val = 0x0;
  // read Reg 2D before modifying for measure mode
  reg_val = adxl362_read_one_reg(XL362_POWER_CTL);
  NRF_LOG_INFO("Setting Measeurement Mode - Reg 2D before = %d", reg_val);
  // turn on measurement mode
  uint8_t temp_write = (reg_val | 0x02);  // turn on measurement bit in Reg 2D
  adxl362_write_one_reg(XL362_POWER_CTL, temp_write);
  nrf_delay_ms(10);
  //nrf_delay_ms(200);
  NRF_LOG_INFO("-----------");
  NRF_LOG_INFO(", Reg 2D after = %d", reg_val);
    NRF_LOG_INFO("#########################################################");
    NRF_LOG_INFO("SPI example started.");
    nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
#if 1
    spi_config.ss_pin   = NRF_GPIO_PIN_MAP(0,17);       //17
    spi_config.miso_pin = NRF_GPIO_PIN_MAP(0,23);       //23
    spi_config.mosi_pin = NRF_GPIO_PIN_MAP(0,21);       //21
    spi_config.sck_pin  = NRF_GPIO_PIN_MAP(0,19);       //19
#else
    spi_config.ss_pin   = SPI_SS_PIN;
    spi_config.miso_pin = SPI_MOSI_PIN;
    spi_config.mosi_pin = SPI_MISO_PIN;
    spi_config.sck_pin  = SPI_SCK_PIN;
    spi_config.frequency = NRF_SPIM_FREQ_1M;
//    spi_config.bit_order    = NRF_DRV_SPI_BIT_ORDER_LSB_FIRST;
//    spi_config.irq_priority = NRFX_SPIM_DEFAULT_CONFIG_IRQ_PRIORITY;
//    spi_config.mode = NRF_SPIM_MODE_3;
     ret_code_t ret = nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL);
     if(ret != NRF_SUCCESS)
        NRF_LOG_INFO("SPI init failed:  %d", ret);
    //APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, NULL, NULL));
    NRF_LOG_INFO("<---- ADXL325 reset ---->");
    adxl362_reset();
    NRF_LOG_INFO("<--- ADXL325 set power control register --->");
    beginMeasure();
    while (1)
#if 0
        // Reset rx buffer and transfer done flag
        memset(m_rx_buf, 0, m_length);
        spi_xfer_done = false;
//        APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, tx, 3, rx, 3));
          nrf_drv_spi_transfer(&spi, tx, 3, rx, 1);
        NRF_LOG_INFO("SPI tx: %d", ret);
      uint8_t  reg_val = adxl362_read_one_reg(XL362_POWER_CTL);
        while (!spi_xfer_done)
            __WFE();
        NRF_LOG_FLUSH();
//        bsp_board_led_invert(BSP_BOARD_LED_0);
        nrf_delay_ms(200);
sdk_config.h
