Failed to open zephyr project on MacOS
After following the setup procedure and trying to open emStudio per the following image.
I get the following error:
So I ran the command manually
➜  zephyr git:(nrf91) ✗ cmake -GNinja -DBOARD=nrf9160_pca10090 -DBOARD_DIR=/Users/spoulsen/Projects/ncs/zephyr/boards/arm/nrf9160_pca10090 -DZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb -DGNUARMEMB_TOOLCHAIN_PATH=/usr/local/gcc-arm-none-eabi-7-2018-q2-update -B/Users/spoulsen/Projects/ncs/nrf/samples/nrf9160/at_client/build -H/Users/spoulsen/Projects/ncs/nrf/samples/nrf9160/at_client
-- Found PythonInterp: /usr/local/bin/python3 (found suitable version "3.7.1", minimum required is "3.4")
-- Selected BOARD nrf9160_pca10090
Zephyr version: 1.13.99
Parsing Kconfig tree in /Users/spoulsen/Projects/ncs/zephyr/Kconfig
Loading /Users/spoulsen/Projects/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090_defconfig as base
Merging /Users/spoulsen/Projects/ncs/nrf/samples/nrf9160/at_client/prj.conf
warning: GPIO (defined at
/Users/spoulsen/Projects/ncs/zephyr/soc/arm/nordic_nrf/Kconfig.defconfig:17,
soc/arm/nxp_imx/mcimx7_m4/Kconfig.defconfig.mcimx7_m4:29,
soc/arm/nxp_imx/rt/Kconfig.defconfig.mimxrt1052:30,
soc/arm/nxp_imx/rt/Kconfig.defconfig.mimxrt1062:30,
soc/arm/nxp_kinetis/k6x/Kconfig.defconfig.mk64f12:36,
soc/arm/nxp_lpc/lpc54xxx/Kconfig.defconfig.lpc54114_m0:22,
soc/arm/silabs_exx32/efm32hg/Kconfig.defconfig.efm32hg:15,
soc/arm/silabs_exx32/efm32pg12b/Kconfig.defconfig.efm32pg12b:15,
soc/arm/silabs_exx32/efm32wg/Kconfig.defconfig.efm32wg:15,
soc/arm/silabs_exx32/efr32fg1p/Kconfig.defconfig.efr32fg1p:15,
soc/arm/silabs_exx32/efr32mg12p/Kconfig.defconfig.efr32mg12p:15, drivers/gpio/Kconfig:9) was
assigned the value 'n' but got the value 'y'. You can check symbol information (including
dependencies) in the 'menuconfig' interface (see the Application Development Primer section of the
manual), or in the Kconfig reference at
docs.zephyrproject.org/.../CONFIG_GPIO.html (which is updated regularly
from the master branch). See the 'Setting configuration values' section of the Board Porting Guide
as well.
warning: LOG_DEFAULT_LEVEL (defined at subsys/logging/Kconfig:137) was assigned the value '4' but
got the value ''. You can check symbol information (including dependencies) in the 'menuconfig'
interface (see the Application Development Primer section of the manual), or in the Kconfig
reference at docs.zephyrproject.org/.../CONFIG_LOG_DEFAULT_LEVEL.html
(which is updated regularly from the master branch). See the 'Setting configuration values' section
of the Board Porting Guide as well.
warning: NET_RAW_MODE (defined at subsys/net/ip/Kconfig:12) was assigned the value 'y' but got the
value 'n'. This symbol has no prompt, meaning assignments in configuration files have no effect on
it. It can only be set indirectly, via Kconfig defaults (e.g. in a Kconfig.defconfig file) or
through being 'select'ed or 'imply'd (note: try to avoid Kconfig 'select's except for trivial
promptless "helper" symbols without dependencies, as it ignores dependencies and forces symbols on).
You can check symbol information (including dependencies) in the 'menuconfig' interface (see the
Application Development Primer section of the manual), or in the Kconfig reference at
docs.zephyrproject.org/.../CONFIG_NET_RAW_MODE.html (which is updated
regularly from the master branch). See the 'Setting configuration values' section of the Board
Porting Guide as well. It covers Kconfig.defconfig files.
-- Loading /Users/spoulsen/Projects/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090.dts as base
-- Overlaying /Users/spoulsen/Projects/ncs/zephyr/dts/common/common.dts
nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/uart@40008000: duplicate unit-address (also used in node /soc/i2c@40008000)
nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/uart@40009000: duplicate unit-address (also used in node /soc/i2c@40009000)
nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/uart@4000a000: duplicate unit-address (also used in node /soc/i2c@4000a000)
nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/uart@4000b000: duplicate unit-address (also used in node /soc/i2c@4000b000)
nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/uart@40008000: duplicate unit-address (also used in node /soc/spi@40008000)
nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/i2c@40008000: duplicate unit-address (also used in node /soc/spi@40008000)
nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/uart@40009000: duplicate unit-address (also used in node /soc/spi@40009000)
nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/i2c@40009000: duplicate unit-address (also used in node /soc/spi@40009000)
nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/uart@4000a000: duplicate unit-address (also used in node /soc/spi@4000a000)
nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/i2c@4000a000: duplicate unit-address (also used in node /soc/spi@4000a000)
nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/uart@4000b000: duplicate unit-address (also used in node /soc/spi@4000b000)
nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/i2c@4000b000: duplicate unit-address (also used in node /soc/spi@4000b000)
nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/clock@40005000: duplicate unit-address (also used in node /soc/power@40005000)
  File "/Users/spoulsen/Projects/ncs/zephyr/scripts/dts/extract_dts_includes.py", line 15, in <module>
    import yaml
ModuleNotFoundError: No module named 'yaml'
CMake Error at /Users/spoulsen/Projects/ncs/zephyr/cmake/dts.cmake:193 (message):
  command failed with return code: 1
  /Users/spoulsen/Projects/ncs/zephyr/cmake/app/boilerplate.cmake:295 (include)
  CMakeLists.txt:9 (include)
See also "/Users/spoulsen/Projects/ncs/nrf/samples/nrf9160/at_client/build/CMakeFiles/CMakeOutput.log".
  • I got this warning on pip:
    You are using pip version 10.0.1, however version 18.1 is available.
    You should consider upgrading via the 'pip install --upgrade pip' command.
    After running pip install --upgrade pip I get this on the retry of Cmake
    Loading /Users/spoulsen/Projects/ncs/nrf/samples/nrf9160/at_client/build/zephyr/.config as base
    /Users/spoulsen/Projects/ncs/zephyr/scripts/dts/extract_dts_includes.py:496: DeprecationWarning: Using or importing the ABCs from 'collections' instead of from 'collections.abc' is deprecated, and in 3.8 it will stop working
      and isinstance(merge_dct[k], collections.Mapping)):
    -- Cache files will be written to: /Users/spoulsen/Library/Caches/zephyr
    -- The C compiler identification is GNU 7.3.1
    -- The CXX compiler identification is GNU 7.3.1
    -- Found assembler: /usr/local/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc
    -- Performing Test toolchain_is_ok
    -- Performing Test toolchain_is_ok - Success
    CMake Warning (dev) at /Users/spoulsen/Projects/ncs/zephyr/cmake/extensions.cmake:100 (target_link_libraries):
      Policy CMP0079 is not set: target_link_libraries allows use with targets in
      other directories.  Run "cmake --help-policy CMP0079" for policy details.
      Use the cmake_policy command to set the policy and suppress this warning.
      Target
        zephyr_interface
      is not created in this directory.  For compatibility with older versions of
      CMake, link library
        /Users/spoulsen/Projects/ncs/nrfxlib/bsdlib/lib/cortex-m33/hard-float/libbsd_nrf9160_xxaa.a
      will be looked up in the directory in which the target was created rather
      than in this calling directory.
      /Users/spoulsen/Projects/ncs/nrfxlib/bsdlib/CMakeLists.txt:23 (zephyr_link_libraries)
    This warning is for project developers.  Use -Wno-dev to suppress it.
      Target
        zephyr_interface
      CMake, link library
        /Users/spoulsen/Projects/ncs/nrfxlib/bsdlib/lib/cortex-m33/hard-float/liboberon_2.0.5.a
      Target
        zephyr_interface
      CMake, link library
        c
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /Users/spoulsen/Projects/ncs/nrf/samples/nrf9160/at_client/build
  • emStudio still gets the same error on opening the project.
  • I am able to open the project by running emStudio in a terminal after setting the environment variable.
     source zephyr-env.sh
    ~/arm_segger_embedded_studio_v411_macos_x64_nordic/SEGGER\ Embedded\ Studio\ for\ ARM\ 4.11.app/Contents/MacOS/emStudio
  • The recommendation below is probably mandatory on MacOS
  • Hello, Steven,is your problem solved? How is it solved? I also encountered a similar problem on win7 64bit.
