Failed to open zephyr project on MacOS
After following the setup procedure and trying to open emStudio per the following image.
I get the following error:
So I ran the command manually
  zephyr git:(nrf91) cmake -GNinja -DBOARD=nrf9160_pca10090 -DBOARD_DIR=/Users/spoulsen/Projects/ncs/zephyr/boards/arm/nrf9160_pca10090 -DZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb -DGNUARMEMB_TOOLCHAIN_PATH=/usr/local/gcc-arm-none-eabi-7-2018-q2-update -B/Users/spoulsen/Projects/ncs/nrf/samples/nrf9160/at_client/build -H/Users/spoulsen/Projects/ncs/nrf/samples/nrf9160/at_client
-- Found PythonInterp: /usr/local/bin/python3 (found suitable version "3.7.1", minimum required is "3.4")
-- Selected BOARD nrf9160_pca10090
Zephyr version: 1.13.99
Parsing Kconfig tree in /Users/spoulsen/Projects/ncs/zephyr/Kconfig
Loading /Users/spoulsen/Projects/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090_defconfig as base
Merging /Users/spoulsen/Projects/ncs/nrf/samples/nrf9160/at_client/prj.conf
warning: GPIO (defined at
/Users/spoulsen/Projects/ncs/zephyr/soc/arm/nordic_nrf/Kconfig.defconfig:17,
soc/arm/nxp_imx/mcimx7_m4/Kconfig.defconfig.mcimx7_m4:29,
soc/arm/nxp_imx/rt/Kconfig.defconfig.mimxrt1052:30,
soc/arm/nxp_imx/rt/Kconfig.defconfig.mimxrt1062:30,
soc/arm/nxp_kinetis/k6x/Kconfig.defconfig.mk64f12:36,
soc/arm/nxp_lpc/lpc54xxx/Kconfig.defconfig.lpc54114_m0:22,
soc/arm/silabs_exx32/efm32hg/Kconfig.defconfig.efm32hg:15,
soc/arm/silabs_exx32/efm32pg12b/Kconfig.defconfig.efm32pg12b:15,
soc/arm/silabs_exx32/efm32wg/Kconfig.defconfig.efm32wg:15,
soc/arm/silabs_exx32/efr32fg1p/Kconfig.defconfig.efr32fg1p:15,
soc/arm/silabs_exx32/efr32mg12p/Kconfig.defconfig.efr32mg12p:15, drivers/gpio/Kconfig:9) was
assigned the value 'n' but got the value 'y'. You can check symbol information (including
dependencies) in the 'menuconfig' interface (see the Application Development Primer section of the
manual), or in the Kconfig reference at
docs.zephyrproject.org/.../CONFIG_GPIO.html (which is updated regularly
from the master branch). See the 'Setting configuration values' section of the Board Porting Guide
as well.
warning: LOG_DEFAULT_LEVEL (defined at subsys/logging/Kconfig:137) was assigned the value '4' but
got the value ''. You can check symbol information (including dependencies) in the 'menuconfig'
interface (see the Application Development Primer section of the manual), or in the Kconfig
reference at docs.zephyrproject.org/.../CONFIG_LOG_DEFAULT_LEVEL.html
(which is updated regularly from the master branch). See the 'Setting configuration values' section
of the Board Porting Guide as well.
warning: NET_RAW_MODE (defined at subsys/net/ip/Kconfig:12) was assigned the value 'y' but got the
value 'n'. This symbol has no prompt, meaning assignments in configuration files have no effect on
it. It can only be set indirectly, via Kconfig defaults (e.g. in a Kconfig.defconfig file) or
through being 'select'ed or 'imply'd (note: try to avoid Kconfig 'select's except for trivial
promptless "helper" symbols without dependencies, as it ignores dependencies and forces symbols on).
You can check symbol information (including dependencies) in the 'menuconfig' interface (see the
Application Development Primer section of the manual), or in the Kconfig reference at
docs.zephyrproject.org/.../CONFIG_NET_RAW_MODE.html (which is updated
regularly from the master branch). See the 'Setting configuration values' section of the Board
Porting Guide as well. It covers Kconfig.defconfig files.
-- Loading /Users/spoulsen/Projects/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090.dts as base
-- Overlaying /Users/spoulsen/Projects/ncs/zephyr/dts/common/common.dts
nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/uart@40008000: duplicate unit-address (also used in node /soc/i2c@40008000)
nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/uart@40009000: duplicate unit-address (also used in node /soc/i2c@40009000)
nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/uart@4000a000: duplicate unit-address (also used in node /soc/i2c@4000a000)
nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/uart@4000b000: duplicate unit-address (also used in node /soc/i2c@4000b000)
nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/uart@40008000: duplicate unit-address (also used in node /soc/spi@40008000)
nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/i2c@40008000: duplicate unit-address (also used in node /soc/spi@40008000)
nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/uart@40009000: duplicate unit-address (also used in node /soc/spi@40009000)
nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/i2c@40009000: duplicate unit-address (also used in node /soc/spi@40009000)
nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/uart@4000a000: duplicate unit-address (also used in node /soc/spi@4000a000)
nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/i2c@4000a000: duplicate unit-address (also used in node /soc/spi@4000a000)
nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/uart@4000b000: duplicate unit-address (also used in node /soc/spi@4000b000)
nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/i2c@4000b000: duplicate unit-address (also used in node /soc/spi@4000b000)
nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/clock@40005000: duplicate unit-address (also used in node /soc/power@40005000)
  File "/Users/spoulsen/Projects/ncs/zephyr/scripts/dts/extract_dts_includes.py", line 15, in <module>
    import yaml
ModuleNotFoundError: No module named 'yaml'
CMake Error at /Users/spoulsen/Projects/ncs/zephyr/cmake/dts.cmake:193 (message):
  command failed with return code: 1
  /Users/spoulsen/Projects/ncs/zephyr/cmake/app/boilerplate.cmake:295 (include)
  CMakeLists.txt:9 (include)
See also "/Users/spoulsen/Projects/ncs/nrf/samples/nrf9160/at_client/build/CMakeFiles/CMakeOutput.log".
  zephyr git:(nrf91)
