Bootloader debugging
I want my application to cooperate with DFU. I am using example DFU project from SDK (6.1) (from nrf6310 folder, i simplified it so it could work on PCA10000), but i need some bigger changes.
My problem is that i cannot start debug session in keil. Is bootloader debugging the same as normal application debugging? I can start application, but i cannot set traps and check where the program is at the moment. Should i do some extra settings in keil?
What i do is: erase chip -> flash s110 SD (v7) -> load bootloader by keil -> start debugging -> no profit :(
  • I have try according to your suggestion but i am not able to start point at main function.
    I have also put break point immediate after main function in my code but i am not able to reach breakpoint.
    I am using keil.
  • Hi, Hung Bui. Thank you for the input! I found that the issue is my dfu_dual_bank.c and some other files are linking to the library file "dfu_type.h" and even if I erase all the chip it still starts from 0x3C000. Writing UICR using nrfjprog will resolve the problem. But I think the linking issue is really confusing regarding this problem.
