BluetoothLeAdvertiser.stopAdvertising() causes device to disconnect
I develop an Android app which connects to a Nordic chip, and I cannot get the Android app to stop advertising once it connects to the central from the SDK multi link project.
I  was curious if any one from Nordic might be able to have some insight into why the Android phone cannot be prevented from advertising once it's connected to a central.
I know that Nordic chips stop advertising once they connect, and in fact I thought this behavior was a specification in the BLE protocol.
I would like to be able to format my code code with the old mark up language this web site used to sue like Stack Overflow does, and I have no idea why I can long use the old way for formalizing questions. Any explanation?
Here my BluetoothGattServerCallback where I handle two events `STATE_CONNECTED` and `STATE_DISCONNECTED`
private static class CallBack extends BluetoothGattServerCallback {
private Set<BluetoothDevice> mRegisteredDevices = new HashSet<>();
private MainActivity mMainActivity;
public CallBack(Set<BluetoothDevice> registeredDevices, MainActivity mainActivity){
mRegisteredDevices = registeredDevices;
mMainActivity = mainActivity;
@Override
public void onConnectionStateChange(BluetoothDevice device, int status, int newState) {
Log.i(TAG,"onConnectionStateChange()");
switch (newState)
case STATE_CONNECTED :
handleStateConnected( device, status, newState);
case STATE_DISCONNECTED :
handleStateDisconnected( device, status, newState);
Here is handler `STATE_CONNECTED`
private void handleStateConnected(BluetoothDevice device, int status, int newState)
Log.i(TAG, "BluetoothDevice CONNECTED: " + device);
mRegisteredDevices.add(device);
stopAdvertising();
Here is handler `STATE_DISCONNECTED`
private void handleStateDisconnected(BluetoothDevice device, int status, int newState)
Log.i(TAG, "BluetoothDevice DISCONNECTED: " + device);
mRegisteredDevices.remove(device);
startAdvertising();
On `STATE_CONNECTED` I would like my phone to stop advertising, and on `STATE_DISCONNECTED` I would like the phone to resume advertising; the default behaviour appears to be that the device will continue advertising after it's connected, so I added `stopAdvertising()` and `startAdvertising()` in the event handlers `handleStateConnected()` and `handleStateDisconnected()` respectively.
The phone now goes into an infinite loop of connecting and reconnecting, the reason being that after calling `stopAdvertising()` the phone will disconnect, causing it to begin advertising again, after which it will connect.
The control flow of my app is to begin advertising, then set up GATT server:
private void initServer(){
Log.v(TAG,"initServer()");
mBluetoothManager = (BluetoothManager) getSystemService(BLUETOOTH_SERVICE);
BluetoothAdapter bluetoothAdapter = mBluetoothManager.getAdapter();
// We can't continue without proper Bluetooth support
if (!checkBluetoothSupport(bluetoothAdapter)) {
finish();
// Register for system Bluetooth events (GATT server started in receiver)
IntentFilter filter = new IntentFilter(BluetoothAdapter.ACTION_STATE_CHANGED);
registerReceiver(mBluetoothReceiver, filter);
if (!bluetoothAdapter.isEnabled()) {
Log.d(TAG, "Bluetooth is currently disabled...enabling");
bluetoothAdapter.enable();
} else {
startAdvertising();
startServer();
Here is `startAdvertising()`
public static void startAdvertising() {
Log.i(TAG,"startAdvertising()");
mBluetoothLeAdvertiser = bluetoothAdapter.getBluetoothLeAdvertiser();
if (mBluetoothLeAdvertiser == null) {
Log.w(TAG, "Failed to create mBleAdvertiser");
return;
Log.v(TAG,"created advertizer");
AdvertiseSettings settings = new AdvertiseSettings.Builder()
.setAdvertiseMode(AdvertiseSettings.ADVERTISE_MODE_BALANCED)
.setConnectable(true)
.setTimeout(0) // Limit advertising to a given amount of time A value of 0 will disable the time limit
.setTxPowerLevel(AdvertiseSettings.ADVERTISE_TX_POWER_MEDIUM)
.build();
boolean isNameChanged = BluetoothAdapter.getDefaultAdapter().setName(DEVICE_NAME);
if(isNameChanged) Log.d(TAG,"Device name changed successfully.");
AdvertiseData data = new AdvertiseData.Builder()
.setIncludeDeviceName(true)
.setIncludeTxPowerLevel(false)
.addServiceUuid(ParcelUuid.fromString(Services.GloService.UUID))
.build();
.startAdvertising(settings, data, mAdvertiseCallback);
Here is `startServer()`
private void startServer() {
Log.i(TAG,"startServer()");
mBluetoothGattServer =
MyProfile.getOpenServer(this, mBluetoothManager,mRegisteredDevices,this);
if (mBluetoothGattServer == null) {
Log.w(TAG, "Unable to create GATT server");
return;
And here is `MyProfile.getOpenServer` which returns the server object initialized with the call back declared at the top of the post.
public static BluetoothGattServer getOpenServer(Context ctx,
BluetoothManager bluManager,
mBluetoothManager = bluManager;
CallBack callBack = new CallBack(registeredDevices, mainActivity);
BluetoothGattServer server = bluManager.openGattServer(ctx, callBack);
BluetoothGattService myService = getMyService();
server.addService(myService);
return server;
  • I can't even edit my own post, this new Q&A website is regression from the previous version IMO. I almost don't even want to ask for help.
    First of all, sorry for the devzone experience. Don't know what to say, I'm not responsible for this Disappointed
    Coming to your question: advertising is independent from the connections. On Android a phone may actually advertise with many different advertising sets, each with a different, changing from time to time address, etc. You control advertising separately from connections.
    Your approach to stop advertising when a remote device connects is correct. Remember to call `server.connect(device, autoConnect)` after a device connected. This is to let the system know that you're now going to use the connection, otherwise the system may close it if you don't do `device.connectGatt(...)` (which also tells the system, that you will actively use the connection in your app). When you are done, call `server.cancelConnection(device)`. If `server.connect(...)` won't help, call `connectGatt(..)` to get access to the device`s services.
    Stopping advertising should not disconnect anything, just like it doesn't disconnect in nRF Connect when you stop advertising. It may be either the automatic disconnection, which happens a second after last client disconnected (or when your device connected, but no client connected to it), or some mistake in your code.
    Hope that helped!
    BR, Aleksander
  • Btw, there are some phones, for example Meizu 2 with Android 5.1, where calling `server.connect(device, autoConnect)` will actually call `onConnectionStateChanged callback again. So make sure you don't fall into a loop.
