Thread Topology Monitor can associate an user name with a device. Where is it stored (in computer application or directly into the device) ? If it's in the device, can i do that with a cli command ?
Thank you
Thank you
Are you talking about the labels for the nodes? These are stored in the memory on the computer:
"You may assign a custom label to a Thread node and store it in persistent memory on the PC side, which helps to track topology changes."
(quote from this site)
Edvin
Hello Edvin,
Thank you for your help. It's probably that but how can i save it and export it on another computer ?
I don't think that it is possible to extract this data from the topology monitor. If you want a more permanent mapping, you should use the Thread addresses, which will not change, and stay the same regardless of what device that is monitoring the network.
Edvin
