app_timer
HI, I am using NRF52832 sdk15.2 .
I have some doubts
How to assign two to three different timers to do different functions
1. I need to read the sensor data every one second. and i need to other function for every 5 sec.
2. I am using BLE_UART program.
i need to send the respective data to the mobile phone for every one sec  only after the bluetooth is paired.
is it possible to change in ble /uart event handle
or we need to use app_timer to resolve this.
thank you.....
  • It would probably require some kind of timer, so why not use app_timer? I don't think you need to make any changes to the event handlers since you're going to send the data from the nrf52832 to the phone. If however the phone sends some data back, then you might need to change it.
  • Yeah, When i connect with mobile phone automatically the respective data_array (string) has to print with delay of one sec
    is it possible to add in this ble_evt_handler() function itself..!
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                bsp_board_led_on(CONNECTED_LED);
                err_code = app_button_enable();
                NRF_LOG_INFO("Disconnected");
                bsp_board_led_off(CONNECTED_LED);
                err_code = app_button_disable();
                //advertising_start();
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
                // Pairing not supported
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
    after the ble connected
    possible to add app_timer to send continuously the string to phone with delay of one sec
    and from phone to controller some commands has to be receive to change the axis of the sensor.and respective..
    both transmission and receive in nrf52.
  • Nordic technical support staff will be reduced during the holiday season from 21st December to 7th January
    Longer response time to tickets must be expected during this period.
    Other DevZone users might be active and respond to public tickets as usual.
