NRF52810 RSSI accuracy in long time testing
Hi, we are using NRF52810 in our indoor navigation projects. By calculate signal source RSSIs got from different receiver we can get the approximate position of signal source. Below is some information when we develop on NRF52810.
  1. We use radio ESB protocol to transmit and receive
  2. In the receiver, the RSSI is detected when ADDRESS event happened, by enable using ADDRESS_RSSISTART shortcut
  3. We use SDK 15.0.0
To test the RSSI accuracy, we did a test: connect following component using SMA-IPEX cable, and place them in shielding case.
  1. Transmitter Source, send one packet every one second. In the test, we use four different frequencies
  2. Attenuator, -20dB
  3. Receiver, same frequency as transmitter
After about 19 hours, we get the following statistic result
Frequency
Counter of different RSSI values
-30dBm
-31dBm
-32dBm
-33dBm
-34dBm
-35dBm
Freq1
6
28
0
68602
4
Freq2
1639
57
2098
61009
3837
Freq3
2
68618
17
3
Freq4
439
0
13
68156
4
28
From the result, it seems the RSSI accuracy is out of the range +/-2dB, especially in the Freq2 and Freq4, which some RSSIs are +3dB more than the most frequently RSSI. So I have the following questions:
  1. Could I test the RSSI accuracy using the way described above? And is the result reasonable?
  2. Could I know the way that you do the RSSI accuracy test?
  3. In your test, the RSSI accuracy is 100% in +/-2dB range?
  4. Is +/-1dB happened must be more than +/-2dB?
  5. In the datasheet, the RSSI period only task 0.25us, does it only do one point measurement other than do several measurement and calculate the average?
6. is there any advice when we using RSSI function?
  • I hope someone from Nordic chimes in but in terms of radio architecture, most RSSI's are calculated using the received SN ratio and the estimated noise figure of the front end to figure out what the RSSI should be.  It is rare they actually do it by measuring the actual power. Since this is not the actual received signal strength it is influenced by interferers  such as WiFi (especially the synth spurs and IMD noise that sit at the edge of OFDM waveforms).
    Then to further confound the data, any gain control done by receiver can cause cyclical changes in the SN and thus the RSSI.
    Finally, radios and antennae are never flat across their passband. So power at chan 1 won't be the same as at chan 4, etc. Radio that have closed loop control can calibrate out these errors, but a simple bluetooth radio has no closed loop power control and thus you won't even have the same power on all channels and thus won't have the same RSSI.
    Also rooms never have flat response.  2.4GHz easily bounce off of stuff in the room, metal work may act as reactive loads and all the reflected signals will either be constructive or destructive as you move around the room and the phases relationships change.
    On your end easiest thing would be to characterize your system and cal out the errors in your software. Then once you start with flat response your work might get easier. But all your numbers will be nuts anyway as soon as someone walks around the room or moves the furniture.
    On your test setup above doing conductive measurements all the same is true.  The radio will have non-flat 50ohm performance, micro coax cables are garbage and have non-flat performance along with the small hirose connectors are rarely close to 50ohm which only makes the radio response worse.
    And who made your attenuator??? Good RF attenuators are about $1,000 and are calibrated regularly. A high quality step attenuator might be $5,000. A simple 30dB pad is maybe +/- 3dB and that's if you actually spent a few bucks on it.
    You should also do the test at a lower level. You will never see -30dBm in real life and I doubt Nordic optimized the gain control for that range.
  • By calculate signal source RSSIs got from different receiver we can get the approximate position of signal source
    This comes up again and again with monotonous regularity.
    The word "approximate" is key - and its a very rough approximation indeed!
  • As you mention that power receiver get is a little high, I changed the signal source’s transmit power to -30dBm, and send 408 packets every second. After 36 hours , the statistic result is below:
    Data statistic from 2018-12-21 12h~23h
    Frequency
    -74
    dBm
    -75
    dBm
    -76
    dBm
    -77
    dBm
    -78
    dBm
    -79
    dBm
    Freq1
    357,840
    17,291,877
    46,108
    Freq2
    3,233,995
    14,459,380
    2,397
    Freq3
    95,107
    16,101,572
    1,439,553
    22
    Freq4
    2,199,524
    15,484,449
    11,056
    Data statistic from 2018-12-22 00h~23h
    Frequency
    -74
    dBm
    -75
    dBm
    -76
    dBm
    -77
    dBm
    -78
    dBm
    -79
    dBm
    Freq1
    2,243,034
    33,121,204
    27,350
    Freq2
    11,276,635
    24,113,425
    1,413
    Freq3
    971,500
    33,454,642
    881,368
    2
    Freq4
    4
    9,826,233
    25,559,532
    4,597
    Receiver get -74~-79dBm power, and the RSSImax - RSSImin <=4. In the datasheet, it says the “RSSI Accuracy Valid Range” is -90dBm~-20dBm. In my first test, the RSSI is about -30dBm which is in the range, but the RSSI distribution when got about -30dBm is not in the accuracy range +/-2dB.
    The RF attenuator, mine is quite cheap, and it has fixed attenuation during test. We test the attenuator using net analyzer, the frequency response is stable under the fixed frequency.
    Maybe our test environment is not so perfect, it’s tested only in a shield case other than in anechoic chamber. We expected that when all the component are placed quietly in shield case (most external radio should be blocked, the internal radio bounce maybe exist) and connected by cable, the RSSI should have little deviation. The test result above is still a little more than our expection.
  • Have in mind that the accuracy is +-2dB TYPICAL (not MAX), that in mind I would say that your measurements are as expected.
    Kenneth
