No network interface to work with on nrf9160
I followed the getting started guide but the kit can't connect. I'm getting this error:
net_if.net_if_init: There is no network interface to work with!
Is this a known bug, how can i fix it? Or is there a hardware issue?
Daan Pape
  • after flashing at_client, and sending AT+CFUN=1 and AT%XSIM?
    have the modem active in network search, but still no connect.
    My understanding, in the "asset_tracker" there should be a at_cmd(... AT%XSIM?..), right?
    AT+CFUN?
    +CFUN: 4
    OK
    AT+CFUN=1
    OK
    AT+CFUN=1
    OK
    AT%XSIM?
    %XSIM: 1
    OK
    AT+CPIN?
    +CPIN: READY
    OK
    AT+CPINR="SIM PIN"
    +CPINR: "SIM PIN",3
    OK
    AT+CIMI
    204080813512818
    OK
    AT+CGMI
    Nordic Semiconductor ASA
    OK
    AT+CGMM
    nRF9120
    OK
    AT+CGMR
    mfw-m1_nrf9160_0.6.8-30.alpha
    OK
    AT+CEMODE?
    +CEMODE: 2
    OK
    AT%XCBAND=?
    %XCBAND: (3,4,13,20)
    OK
    AT+CMEE?
    +CMEE: 0
    OK
    AT+CMEE=1
    OK
    AT+CNEC?
    +CNEC: 0
    OK
    AT+CNEC=24
    OK
    AT+CGEREP?
    +CGEREP: 0,0
    OK
    AT+CGDCONT?
    OK
    AT+CGACT?
    OK
    AT+CGEREP=1
    OK
    AT+CIND=1,1,1
    OK
    AT+CEREG=2
    OK
    AT+CEREG?
    +CEREG: 2,2,"FFFE","FFFFFFFF",7
    OK
    AT%CESQ=1
    OK
    AT+CESQ
    +CESQ: 99,99,255,255,255,255
    OK
  • I am just noting that the out of the box experience with the asset tracker was good for me in USA on VZ. I followed instructions and ran into only one problem: I had to register a new account to activate the sim card.
    I did have problems after loading the at-command example application. I resolved my issues by finally pushing the reset button on the dev kit; note that power cycling or plugging and unplugging usb from my computer, etc did not work, only pushing the reset button worked. I found that even after it was working, when I later updated the modem firmware according to the instructions it wouldn't register on the network. Again, the solution was to push the reset button. Perhaps some folks can try that if everything else is failing.
  • try the reset button like in my other response. Let me know if it works. I am curious if it helps
    I have tried to push the reset button. I can than see the board rebooting but this doesn't resolve the reception issues.
    Daan
  • I do have the same issues with the iBasis sim card in NL. Even after updating the modem firmware.
    Inserting my Vodafone NL sim card worked within seconds. Therefore I think something is wrong with the procedure to activate the iBasis sim card. Putting the iBasis sim card in my phone results in no network, until I selected the iBasis (KPN) APN settings. But, there is no internet connection possible.
    @Nordic, could anyone check if the activation of the sim-cards works correct?
