Static Passkey nRF52840
I've followed the link https://devzone.nordicsemi.com/f/nordic-q-a/35675/how-to-use-static-passkey-for-a-no-display-no-output-peripheral
and added it to uart example. if connection via android settings , phone asked for passkey and process continue.
however - when connecting fro nRFUART or nRFConnet, passkey is being asked.
any idea why ?
  • Hi Rani,
    Which behavior were you expect the phone/nRFConnect should do ? To be asked or not to be asked?
    Could you explain more clearly ?
  • Sorry, it seems like a type, let me rephrase
    When connecting via Android settings, the user is prompted with a request to enter passkey, and bonding succeed if passkey match
    When connecting via nRFToolbox , user is NOT prompted to enter the passkey and the connection fails.
    If the device is bonded ( via Android settings ) nRFToolbox can connect successfully .
    On another note - how come there is a bug difference between ses_startup_nrf52840.s and gcc_startup_nrf52840.s . why is that ?
  • Could you explain more on "connection fails" ? what exactly happened ?
    Which firmware you have on the nRF52 ? Please be aware that when connecting using nRFToolbox, if the app doesn't try to read/write a characteristic that requires bonding the bonding process won't happen. You would need to do a read or write on a characteristic that require encryption/bonding. Please try again using nRFConnect app and try to read your characteristics.
    1.I am using SDK 15.2
    2.When connecting via nRFToolbox I am getting "rejected by <APP> " .
    ( connection is ok only if using Android setting to bond first )
    3. My application is UART service based, how can I define RX\TX to require bonding ?
    Ran
  • We would need to look at how you modified your application firmware.
    Could you take a screenshot when you see "rejected by <APP> "?
    If you have a look at ble_nus_init() you can find that the characteristic was added as "SEC_OPEN".
    If you change the read/write access of the characteristic to SEC_MITM, then when the characteristic is being read/write the phone will automatically request bonding.
