Is production testing using the nRF DK recommendable?
application note nAN-034 describes two alternatives for production testing an application using the nRF51822. One method is using a commercial tester (MT8852) and the other is using the development kit itself. Using the developemnt kit approach seems tempting from a cost perspective in particular if several parallel setups are needed. Has anyone real production experience using the development kit for production testing? Is it recommendable? What are the drawbacks compared to let's say MT8852?
  • Our production team went down the path of using the development kit for their testing. It seemed to work very well for them. We had a couple of development kits from our evaluation of the nRF51822 and it seemed reasonable to re-purpose them rather than have them sit on a shelf. I don't believe they had any significant hurdles using the development kit in this fashion.
  • I might be a bit biased here, but I think re-using the EK/DK as production testers is a good idea. You can test that the components related to the nRF51 on your board are soldered correctly and verifying that it runs properly by sending some packages or even set up a connection if you have a BLE product. The fact that the device under test receives and transmits as expected would indicate that the production went ok and that everything is programmed correctly.
    You can communicate with the EK that's used a tester through the serial port connection on USB as well. Usually at least we see that customers test a lot of parameters during development and only need to validate that the soldering and programming has been done as expected in production and for this purpose a EK/DK would be a good tester.
  • Thanks for sharing! We'll go for the DK as production tester and see how it works.
