How to implement two TWI instances
I am having difficulty using a single TWI to support a DAC (MCP4725) and IMU (BNO055).
I am using nRF52 DK, and SDK 14.3 with the SEGGER IDE.  The DAC is running on a timer with samples being loaded every 200 micro seconds.  The IMU is running on the same TWI bus and I am collecting 3 data samples (2 bytes each) every 20 milliseconds.  The data is being piped over BLE at 50 samples per second (packing 2 sets of samples in a single 20 byte packet every 40 milliseconds). If I output a triangular waveform, I get an artifact every 20 milliseconds with a varying time for the length of the artifact (see the attached images below).
My plan is to split the processing so the DAC is on one twi and the IMU on a second TWI bus.  If I do this, what pins can be used for the second TWI if I use the default pins for the first TWI?  Below are my initialization functions:
void dac_twi_init (void)
ret_code_t err_code;
const nrf_drv_twi_config_t twi_mcp4725_config = {
.scl = ARDUINO_SCL_PIN,
.sda = ARDUINO_SDA_PIN,
.frequency = NRF_TWI_FREQ_400K,
.interrupt_priority = APP_IRQ_PRIORITY_HIGH,
.clear_bus_init = false
err_code = nrf_drv_twi_init(&m_dac, &twi_mcp4725_config, twi_handler, NULL);
nrf_drv_twi_enable(&m_dac);
void imu_twi_init (void)
const nrf_drv_twi_config_t twi_bno055_config = {
.scl = 10,
.sda = 9,
err_code = nrf_drv_twi_init(&m_imu, &twi_bno055_config, twi_bno055_handler, NULL);
nrf_drv_twi_enable(&m_imu);
As you can see, the amount of corruption in the waveform varies.  Sometimes it is very obvious and sometimes almost undetectable.  Occurring every 20 mS indicates that the transfer of data from the IMU is impacting the ability for the DAC outputs to continue at the 200 microsecond intervals (they get delayed and thus the horizontal corruption in the DAC output).
My questions are:
1. Do you think using 2 TWIs will solve the issue?
2. Are Pins 9 and 10 "legal" pins to use for the second TWI?
3. Does my initialization above look correct?
4. Is there a possibility of other causes of the corruption and what are they?
Thanks in advance for your help.  This medical project is in the final prototype stages and "clean" DAC waveforms are absolutely necessary.
  • Hi Gary
    The advantage of using two TWI masters is that you can run two transactions in parallel, without the second having to wait for the first to complete.
    You still need to run some code from the CPU to start the transaction, but this should be a much quicker procedure than the full transaction.
    The TWI master interfaces also have an array list feature, which allow you to fire off multiple write transactions without having to run any code on the MCU side. An event from a timer can be connected to the TWI master over PPI, allowing you to trigger the TWI in the background while the CPU is busy doing something else.
    If using two TWI master interfaces is not sufficient to get completely smooth ADC data then this is something you could look into.
    Sampling the ADC should not have to impact the TWI communication, as this can also run transparently in the background. Just make sure that any ADC event handler used to process the data is running at a lower IRQ priority (higher priority number).
    I don't know where you found the reference to 800K TWI frequency. The hardware in the nRF52832 is ratified to 400K only, and I couldn't find the commented define you mentioned in either SDK v14.2.0 or SDK v15.2.0 (there is no SDK v14.3.0).
    Best regards
    Torbjørn
  • Hi Gary
    Best regards
    Torbjørn
  • Thank you Torbjorn,
    I will look into these and should have implemented the dual TWI by early next week and will let you know the result.
    If that does not completely solve it, I will try the alternative using PPI that you suggested.
    I apologize for the typo on the SDK - I am using SDK 14.2.0
    Thanks for your prompt support.
    Gary
  • Hi Gary
    The best of luck. If you have more questions just let me know Slight smile
    Best regards
    Torbjørn
  • Torbjorn,
    The dual TWI masters works well - I still have under 1 mS distortion during transmission of samples over BLE.  The DAC samples involved in the delay are buffered and the waveform "catches up" by sending the samples out faster than every 200 uS.  We can live with that for now.
