How to Run DTM on nRF52840 development kit using MT8852B?
Hi all,
I have a nRF52840 development kit and flashed (I believed it flashed successfully) with direct test mode .hex file from SDK 15.2. What I facing was not able to run any test from MT8852B due to unable to get the unit address from the board. Did anyone tried to run DTM with MT8852B on nRF52840 DK ? Kindly advise
TQ
    In order to get DTM running on any bluetooth tester, you would need to use other RXD and TXD pins when using the nRF5x development kit. This is because the UART is by default routed to the SEGGER IC on the devkit, so you will get two UART hosts conflicting the lines.
    If you go into the dtm/direct_test_mode/main.c file, you can change the defines for RXD and TXD in function uart_init().
    After changing these from the default GPIOs P0.06 and P0.08 (flip the kit over to see which GPIOs are unused), you can connect the chosen GPIOs to the bluetooth testers UART. Remember to use BLE 2-Wire when connecting to the Anritsu.
    Håkon
  • hi Hakan,
    regarding the Rx & Tx pin, if i only use the J3 usb port as the power source to the nRF52840 chipset, could this good enough to avoid the conflict as you mentioned?? in this case, do i still need to redefine the pin in the main.c file ??
    Another thing, i am using the dtm/direct_test_mode_pca10056.hex file instead of the dtm/main.c file as the source for the test. any different between them?? kindly advice if i am using the correct source code..
    tq
    The pins P0.06 and P0.08 are still connected to an unpowered IC if you only power via the "nRF USB" connector, which would sink current through the unpowered IC.
    Here's a modified DTM (from SDK 15.2) with P0.20 and P0.21 used: nrf52840_xxaa_dtm_p020_p021.hex
    Could you try these pins and see if that works better?
    Håkon
    Thank you for the .hex file, the P0.20 is Tx ? P0.21 is Rx ?
    There is an error during flashing the hex file into my nRF52840 development kit. Below is the error pop out when I tried to flash my board using nRFgo Studio.
    Then i used J-Flash Lite v6.40 to do flashing, and the program shows me the flashing is completed. However, I still failed to get the address on MT8852B.
    Here are some questions from me:
    1. i need to flash softdevice first then only can flash the application software?
    2. why i the flashing result is "completed" when using J-Flash Lite? and, it is really flashed?
    3. on the Anritsu MT8852B, i tried both BLE2WIRE & RS232 to get the address but none on them working. I assumed there is no UART communication between Anritsu and DUT.
    4. i noticed there are few supply port on the nRF52840 DK board. what is your configuration about that to make it works ?
    TQ, looking for your advice..
    1 and 2.) No need to program the softdevice. Use nrfjprog from the command line:
    nrfjprog -e && nrfjprog --program path\to\dtm.hex --reset
    3.) You shall use BLE2WIRE and connect the RXD/TXD to pins P0.20 and P0.21. "RS232" is for classic BR/EDR bluetooth testing.
    4.) As long as the nRF is powered up and the debugger is connected, it should be fine. Please see the nRF52840 user guide for more details on what the different switches do.
    Håkon
