SPI configuration for nrf52832
I've configured the SPI with DMA module as in the code below.
I've loaded the tx buffer with sample data and start the transaction; however, I'm not reading anything either on the MOSI pin or the MISO pin. The SCK pin also stays low. The tx and rx end events do go from 0 to 1 correctly.
Any ideas what I'm doing wrong?
Thanksspi code.rtf
  • I made the changes you suggested. Actually the chip select pin is separate from the spi module. It shouldn't have any effect on the clock and data signals. I still don't get anything on the mosi line after the start task is initiated.
  • Here's the amended code with your changes. I also put in a loop for sending continuously the same data. There's still nothing on the MOSI line.
    #define CSPIN 11  //spi chip select
    #define SCKPIN 12  //spi clock
    #define MOSIPIN 13  //spi mosi
    #define MISOPIN 14  //spi miso
    int main()
      NRF_GPIO->PIN_CNF[CSPIN] = 1;  //output
      NRF_GPIO->PIN_CNF[SCKPIN] = 1;  //output
      NRF_GPIO->PIN_CNF[MOSIPIN] = 1;  //output
      NRF_GPIO->PIN_CNF[MISOPIN] = 0;  //input pin, input buffer connected, no pull, S0S1, sense disabled
      NRF_SPIM0->PSEL.SCK = SCKPIN;
      NRF_SPIM0->PSEL.MOSI = MOSIPIN;
      NRF_SPIM0->PSEL.MISO = MISOPIN;
      NRF_SPIM0->CONFIG = 0b010;  //CPOL 0 -- clock polarity active high, CPHA 1 -- sample on trailing clock edge, send Msb first
      NRF_SPIM0->FREQUENCY = 0x02000000;  //250 kbps
      uint8_t spiTXBuf[2];  //2 byte tx buffer
      uint8_t spiRXBuf[2];  //2 byte rx buffer
      spiTXBuf[0] = 0b10101010;  //example byte
      spiTXBuf[1] = 0b10101010;  //example byte
      NRF_SPIM0->TXD.PTR = (uint32_t)((uint8_t *)spiTXBuf);
      NRF_SPIM0->TXD.MAXCNT = 2;
      NRF_SPIM0->RXD.PTR = (uint32_t)((uint8_t *)spiRXBuf);
      NRF_SPIM0->RXD.MAXCNT = 2;
      NRF_SPIM0->ENABLE = 7;  //enabled
      while(1)
        NRF_SPIM0->EVENTS_ENDTX = 0;
        NRF_SPIM0->EVENTS_ENDRX = 0;
        NRF_GPIO->OUTCLR = 1 << CSPIN;  //drive cs low to initiate spi comm
        for(uint8_t i = 0; i < 21; i++) __asm__("nop\n\t");  //low for 21 machine instructions
        NRF_SPIM0->TASKS_START = 1;
        while(!NRF_SPIM0->EVENTS_ENDTX);  //last byte transmitted
        while(!NRF_SPIM0->EVENTS_ENDRX);  //last byte received
        NRF_SPIM0->TASKS_STOP = 1;
        for(uint8_t i = 0; i < 3; i++) __asm__("nop\n\t");
        NRF_GPIO->OUTSET = 1 << CSPIN;
  • Ok last change, this makes your code work on my SPI; SPI has to be enabled before you write the Tx and Rx buffers info:
      NRF_SPIM0->TXD.MAXCNT = mRxTxBufLength; //2;
      NRF_SPIM0->RXD.MAXCNT = mRxTxBufLength; //2;
  • The placement of the ENABLE command doesn't seem to have any effect for me. I see the clock on my scope but nothing on the MOSI pin. It should look like the square wave of the clock signal since the data is 0b10101010
  • Have a look at this driver for reference.  It works across nRF5x series, support both DMA and non-dma, master/slave. https://github.com/I-SYST/EHAL/blob/master/ARM/Nordic/src/spi_nrf5x.cpp
