SPI configuration for nrf52832
I've configured the SPI with DMA module as in the code below.
I've loaded the tx buffer with sample data and start the transaction; however, I'm not reading anything either on the MOSI pin or the MISO pin. The SCK pin also stays low. The tx and rx end events do go from 0 to 1 correctly.
Any ideas what I'm doing wrong?
Thanksspi code.rtf
  • This your code correctly working on an SPI accelerometer; the delays are arbitrary and not tested with other values (just there to mimic your delays). The returned value is correct:
    #define CSPIN   ACC_CS_PIN   // 11  //spi chip select
    #define SCKPIN  ACC_SCK_PIN  // 12  //spi clock
    #define MOSIPIN ACC_MOSI_PIN // 13  //spi mosi
    #define MISOPIN ACC_MISO_PIN // 14  //spi miso
    #define LIS2DH12_WHO_AM_I          0x0F                          // Read as 0x33
    uint8_t spiTXBuf[] = {0x80|LIS2DH12_WHO_AM_I, 0xFF};
    uint8_t spiRXBuf[sizeof(spiTXBuf)];
    static const uint8_t mRxTxBufLength = sizeof(spiTXBuf);
    void TestSPI(void)
      NRF_GPIO->PIN_CNF[CSPIN] = 1;  //output
      NRF_GPIO->PIN_CNF[SCKPIN] = 1;  //output
      NRF_GPIO->PIN_CNF[MOSIPIN] = 1;  //output
      NRF_GPIO->PIN_CNF[MISOPIN] = 0;  //input pin, input buffer connected, no pull, S0S1, sense disabled
      NRF_GPIO->OUTSET = 1 << CSPIN;  //deactivate by setting chip select high
      NRF_SPIM0->PSEL.SCK = SCKPIN;
      NRF_SPIM0->PSEL.MOSI = MOSIPIN;
      NRF_SPIM0->PSEL.MISO = MISOPIN;
      NRF_SPIM0->CONFIG = 0; //2; // 0b010;  //CPOL 0 -- clock polarity active high, CPHA 1 -- sample on trailing clock edge, send Msb first
      NRF_SPIM0->FREQUENCY = 0x20000000;  //2 Mbps
    //uint8_t spiTXBuf[2];  //2 byte tx buffer
    //uint8_t spiRXBuf[2];  //2 byte rx buffer
    //spiTXBuf[0] = ADS_CMND_RREG; // 0b10101010;  //example byte
    //spiTXBuf[1] = 2-1; // 0b10101010;  //example byte
      nrf_delay_us(200);                  // Delay to allow 18 tclk minimum
      NRF_SPIM0->ENABLE = 7;  //enabled
      NRF_SPIM0->TXD.PTR = (uint32_t)((uint8_t *)spiTXBuf);
      NRF_SPIM0->TXD.MAXCNT = mRxTxBufLength; //2;
      NRF_SPIM0->RXD.PTR = (uint32_t)((uint8_t *)spiRXBuf);
      NRF_SPIM0->RXD.MAXCNT = mRxTxBufLength; //2;
    //  NRF_SPIM0->ENABLE = 7;  //enabled
      NRF_SPIM0->EVENTS_ENDTX = 0;
      NRF_SPIM0->EVENTS_ENDRX = 0;
      NRF_GPIO->OUTCLR = 1 << CSPIN;  //drive cs low to initiate spi comm
    //for(uint8_t i = 0; i < 21; i++) __asm__("nop\n\t");  //low for 21 machine instructions
      nrf_delay_us(200);
      NRF_SPIM0->TASKS_START = 1;
      while(!NRF_SPIM0->EVENTS_ENDTX);  //last byte transmitted
      while(!NRF_SPIM0->EVENTS_ENDRX);  //last byte received
      NRF_SPIM0->TASKS_STOP = 1;
      while(1);
  • I think my problem might be that I'm not using a supported type of buffer for tx and rx. In my code I've created a uint8_t array with 2 elements for each. I've populated the tx buffer with data and set the TXD.PTR to the address of this array. This is what works for me when I use the UARTE with DMA.
    I've updated my code using hmolesworths suggestions and updated TXD.PTR per the data sheet at each loop. But I still don't have anything on the MOSI pin.
    #define CSPIN 11  //spi chip select
    #define SCKPIN 12  //spi clock
    #define MOSIPIN 13  //spi mosi
    #define MISOPIN 14  //spi miso
    int main()
      NRF_SPIM0->CONFIG = 0b010;  //CPOL 0 -- clock polarity active high, CPHA 1 -- sample on trailing clock edge, send Msb first
      NRF_SPIM0->FREQUENCY = 0x02000000;  //250 kbps
      NRF_SPIM0->TXD.MAXCNT = 2;
      NRF_SPIM0->RXD.MAXCNT = 2;
      spiTXBuf[0] = 0b10101010;  //example byte
      spiTXBuf[1] = 0b10101010;  //example byte
      while(1)
        NRF_SPIM0->EVENTS_STARTED = 0;
        while(!NRF_SPIM0->EVENTS_STARTED);
        for(uint8_t i = 0; i < 3; i++) __asm__("nop\n\t");
  • Edit: I just tested your last code posted and it fails the first time through the loop as you start the transfer before setting the pointers, but second time through it works correctly.
    Did using the exact code I posted (with your pin numbers) not work? Is this on an PCA10040 by any chance? Just that P0.13 is affected by U4, SHIELD_DETECT and BUTTON1 in non-obvious ways ..
  • It's not the PCA10040. I have SoftDevice 132 loaded. I'm wondering if I have some hardware issues, since your code is working. I'll check on another board when I can. In the meantime I'll move some pins around.
  • What is a slave chip?
    Accelerometer? Is that an Invensense chip?
    In the case of ICM-20948 or MPU-9250 when I look at SPI Bus Timing Diagram of SPI, I think it is the best timing when it is CPOL=1, CPHA=1.
