j-Link Server cannot connect to target nRF51822
Hi all,
I'm trying to follow this Nordic blog post in order to use Luna Eclipse, GDB and J-link for debugging of ble_app_hrs from Nordic SDK 6.1 on a PCA10001
It is going well, I can compile, and Eclipse can check syntax etc. However, debugging via GDB and J-link GDB Server does not work. I have isolated the error to also exist when starting the J-link GDB Server manually (outside Eclipse). It comes with the following error: image description
J-Link Server Settings:
image description
Other Observations:
  • When J-link GDB Server is attempting to connect, the "SEGGER" LED03 is blinking briefly
  • J-Link Commander can connect (it seems)
  • nRFGo Studio can read and write images
  • Command line flash write via nrfjprog works as expected
  • blinky_example project works on the board
Any help will be greatly appreciated!
Best Regards Klaus Frandsen Denmark
