simple_on_off vendor model on Mesh 3.1
I am converting the simple_on_off vendor model to send a message on mesh 3.1.
the server  implemented the simple_on_off model successfully. But but my client runs into  0>, app_error_weak.c,  119, Mesh error 8 at 0x00000000 (:0)  straight away.
I suspect the line below in mesh_init could be causing the problem
  .core.p_uuid = dev_uuid,
NOTE: This is for the PCA10059 not the DK. LEDS and Buttons have been remapped. I have removed generic_on_off model .c and . h files. I have kept model_common.c
/* Copyright (c) 2010 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
 * list of conditions and the following disclaimer.
#include <stdint.h>
#include <string.h>
/* HAL */
#include "boards.h"
#include "simple_hal.h"
#include "app_timer.h"
/* Core */
#include "nrf_mesh_config_core.h"
#include "nrf_mesh_gatt.h"
#include "nrf_mesh_configure.h"
#include "nrf_mesh.h"
#include "mesh_stack.h"
#include "device_state_manager.h"
#include "access_config.h"
/* Provisioning and configuration */
#include "mesh_provisionee.h"
#include "mesh_app_utils.h"
/* Models */
//#include "generic_onoff_client.h"
#include "simple_on_off_client.h"
#include "simple_on_off_common.h"
/* Logging and RTT */
#include "log.h"
#include "rtt_input.h"
/* Example specific includes */
#include "app_config.h"
#include "nrf_mesh_config_examples.h"
#include "light_switch_example_common.h"
#include "example_common.h"
#include "ble_softdevice_support.h"
#define RTT_INPUT_POLL_PERIOD_MS (100)
#define GROUP_MSG_REPEAT_COUNT (2)
#define LED_BLINK_INTERVAL_MS (200)
#define LED_BLINK_SHORT_INTERVAL_MS (50)
#define LED_BLINK_CNT_START (2)
#define LED_BLINK_CNT_RESET (3)
#define LED_BLINK_CNT_PROV (4)
#define LED_BLINK_CNT_NO_REPLY (6)
static simple_on_off_client_t m_clients[CLIENT_MODEL_INSTANCE_COUNT];
//static const uint8_t m_client_node_uuid[NRF_MESH_UUID_SIZE] = CLIENT_NODE_UUID;
static bool m_device_provisioned;
static void client_status_cb(const simple_on_off_client_t *p_self, simple_on_off_status_t status, uint16_t src);
static bool client_publication_configured(void) {
  dsm_handle_t pub_addr_handle;
  for (uint8_t i = 0; i < CLIENT_MODEL_INSTANCE_COUNT; i++) {
    if (access_model_publish_address_get(m_clients[i].model_handle, &pub_addr_handle) == NRF_SUCCESS) {
      if (pub_addr_handle == DSM_HANDLE_INVALID) {
        return false;
    } else {
      return false;
  return true;
static void provisioning_complete_cb(void) {
  __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Successfully provisioned\n");
  dsm_local_unicast_address_t node_address;
  dsm_local_unicast_addresses_get(&node_address);
  __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Node Address: 0x%04x \n", node_address.address_start);
  hal_led_mask_set(LEDS_MASK, LED_MASK_STATE_OFF);
  hal_led_blink_ms(LEDS_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_PROV);
static uint32_t server_index_get(const simple_on_off_client_t *p_client) {
  uint32_t index = p_client - &m_clients[0];
  NRF_MESH_ASSERT(index < SERVER_NODE_COUNT);
  return index;
static void client_publish_timeout_cb(access_model_handle_t handle, void *p_self) {
  __LOG(LOG_SRC_APP, LOG_LEVEL_ERROR, "Acknowledged send timedout\n");
static void client_status_cb(const simple_on_off_client_t *p_self, simple_on_off_status_t status, uint16_t src) {
  uint32_t server_index = server_index_get(p_self);
  //__LOG(LOG_SRC_APP, LOG_LEVEL_ERROR, "server status received \n",p_self);
  switch (status) {
  case SIMPLE_ON_OFF_STATUS_ON:
    hal_led_pin_set(BSP_LED_0 + server_index, true);
  case SIMPLE_ON_OFF_STATUS_OFF:
    hal_led_pin_set(BSP_LED_0 + server_index, false);
  case SIMPLE_ON_OFF_STATUS_ERROR_NO_REPLY:
    hal_led_blink_ms(LEDS_MASK, LED_BLINK_SHORT_INTERVAL_MS, LED_BLINK_CNT_NO_REPLY);
  case SIMPLE_ON_OFF_STATUS_CANCELLED:
    __LOG(LOG_SRC_APP, LOG_LEVEL_ERROR, "Unknown status \n");
static void node_reset(void) {
  __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- Node reset  -----\n");
  hal_led_blink_ms(LEDS_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_RESET);
  mesh_stack_device_reset();
static void config_server_evt_cb(const config_server_evt_t *p_evt) {
  if (p_evt->type == CONFIG_SERVER_EVT_NODE_RESET) {
    node_reset();
static void button_event_handler(uint32_t button_number) {
  //__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Button %u pressed\n", button_number);
  if (client_publication_configured()) {
    uint32_t status = NRF_SUCCESS;
    switch (button_number) {
    case 0:
    case 1:
      /* send unicast message, with inverted GPIO pin value */
      status = simple_on_off_client_set(&m_clients[button_number],
          !hal_led_pin_get(BSP_LED_0 + button_number));
    case 2:
    case 3:
      /* send a group message to the ODD group, with inverted GPIO pin value */
      status = simple_on_off_client_set_unreliable(&m_clients[button_number],
          !hal_led_pin_get(BSP_LED_0 + button_number),
          GROUP_MSG_REPEAT_COUNT);
      hal_led_pin_set(BSP_LED_0 + button_number, !hal_led_pin_get(BSP_LED_0 + button_number));
    if (status == NRF_ERROR_INVALID_STATE ||status == NRF_ERROR_NO_MEM ||status == NRF_ERROR_BUSY) {
      __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Cannot send. Device is busy.\n");
    } else {
      ERROR_CHECK(status);
  } else {
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Ignored. Node is not configured.\n");
/*uint32_t send_command_client(simple_on_off_client_t *p_client, uint8_t *msg, uint16_t length) {
  //int i;
  send_command_msg_t command_msg;
  command_msg.length = length;
  strncpy(command_msg.command, msg, length);
  access_message_tx_t message;
  message.opcode.opcode = SEND_COMMAND;
  message.opcode.company_id = ACCESS_COMPANY_ID_NORDIC;
  message.p_buffer = (const uint8_t *)&command_msg;
  message.length = command_msg.length + 2;
  status = access_model_publish(p_client->model_handle, &message);
  Method for sending to all nodes!
  for (uint8_t i = 0; i < 3; ++i)
        if (status == NRF_SUCCESS) {
  return status;
static void rtt_input_handler(int key)
    if (key >= '0' && key <= '3')
        uint32_t button_number = key - '0';
        button_event_handler(button_number);
static void models_init_cb(void) {
  __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Initializing and adding models\n");
  for (uint32_t i = 0; i < CLIENT_MODEL_INSTANCE_COUNT; ++i) {
    m_clients[i].status_cb = client_status_cb;
    m_clients[i].timeout_cb = client_publish_timeout_cb;
    ERROR_CHECK(simple_on_off_client_init(&m_clients[i], i + 1));
    ERROR_CHECK(access_model_subscription_list_alloc(m_clients[i].model_handle));
static void mesh_init(void) {
uint8_t dev_uuid[NRF_MESH_UUID_SIZE];
 uint8_t node_uuid_prefix[NODE_UUID_PREFIX_LEN] = CLIENT_NODE_UUID_PREFIX;
  mesh_stack_init_params_t init_params =
          .core.irq_priority = NRF_MESH_IRQ_PRIORITY_LOWEST,
          .core.lfclksrc = DEV_BOARD_LF_CLK_CFG,
          .models.models_init_cb = models_init_cb,
          .models.config_server_cb = config_server_evt_cb};
  ERROR_CHECK(mesh_stack_init(&init_params, &m_device_provisioned));
static void initialize(void) {
  __LOG_INIT(LOG_SRC_APP | LOG_SRC_ACCESS, LOG_LEVEL_INFO, LOG_CALLBACK_DEFAULT);
  __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- BLE Mesh Light Switch Client Demo -----\n");
  hal_leds_init();
#if BUTTON_BOARD
  ERROR_CHECK(hal_buttons_init(button_event_handler));
 nrf_clock_lf_cfg_t lfc_cfg = DEV_BOARD_LF_CLK_CFG;
  mesh_init();
static void start(void) {
  rtt_input_enable(rtt_input_handler, RTT_INPUT_POLL_PERIOD_MS);
  ERROR_CHECK(mesh_stack_start());
  if (!m_device_provisioned) {
    static const uint8_t static_auth_data[NRF_MESH_KEY_SIZE] = STATIC_AUTH_DATA;
    mesh_provisionee_start_params_t prov_start_params =
            .p_static_data = static_auth_data,
            .prov_complete_cb = provisioning_complete_cb};
    ERROR_CHECK(mesh_provisionee_prov_start(&prov_start_params));
  const uint8_t *p_uuid = nrf_mesh_configure_device_uuid_get();
  __LOG_XB(LOG_SRC_APP, LOG_LEVEL_INFO, "Device UUID ", p_uuid, NRF_MESH_UUID_SIZE);
  hal_led_blink_ms(LEDS_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_START);
int main(void) {
  bsp_board_init(BSP_INIT_LEDS); // leds fro pca10059
  initialize();
  start();
  for (;;) {
    (void)sd_app_evt_wait();
If someone could shed some light as to why im getting error 8
thanks in advance
  • Hi.
    I think that your order of calling might be wrong. Looking at your code, it seems that you call mesh_stack_init() without having initialized the Mesh state, which throws an error in nrf_mesh.c, line 284.
    Can you call nrf_mesh_enable() before you call  mesh_stack_init() and see if this works?
    Andreas
  • Hi Andreas
     Did  what you suggested and still have error 8. Do you perhaps have an example of  on_off vendor model on mesh 3.1?
    Then I can compare.
    I know it has something to do with mesh_init and models_init. If I use the default generic_on_off functions of mesh_init and models_init (tegether with generic_onn_off.c and .h files it seems to work.
  • Thanks Andreas, these are for the Generic model. Im looking for a sample of the functions or sample main.c for simple_on_off model in the vendor directory
    They don't work together
  • Hi.
    The first models_init_cb() has an initialization call inside it for the simple_on_off model, if you look closly.
    Are you looking for the source file for this implementation? You can find it in Mesh SDK 2.0.0 under models\simple_on_off\src\simple_on_off_client.c
    Here it is:
    #include <stdint.h>
    #include <stddef.h>
    #include "access.h"
    #include "access_reliable.h"
    #include "nrf_mesh_assert.h"
    #include "log.h"
     * Static variables
    /** Keeps a single global TID for all transfers. */
    static uint8_t m_tid;
     * Static functions
    static void reliable_status_cb(access_model_handle_t model_handle,
                                   void * p_args,
                                   access_reliable_status_t status)
        simple_on_off_client_t * p_client = p_args;
        NRF_MESH_ASSERT(p_client->status_cb != NULL);
        p_client->state.reliable_transfer_active = false;
        switch (status)
            case ACCESS_RELIABLE_TRANSFER_SUCCESS:
                /* Ignore */
            case ACCESS_RELIABLE_TRANSFER_TIMEOUT:
                p_client->status_cb(p_client, SIMPLE_ON_OFF_STATUS_ERROR_NO_REPLY, NRF_MESH_ADDR_UNASSIGNED);
            case ACCESS_RELIABLE_TRANSFER_CANCELLED:
                p_client->status_cb(p_client, SIMPLE_ON_OFF_STATUS_CANCELLED, NRF_MESH_ADDR_UNASSIGNED);
                /* Should not be possible. */
                NRF_MESH_ASSERT(false);
    /** Returns @c true if the message received was from the address corresponding to the clients
     * publish address. */
    static bool is_valid_source(const simple_on_off_client_t * p_client,
                                const access_message_rx_t * p_message)
        /* Check the originator of the status. */
        dsm_handle_t publish_handle;
        nrf_mesh_address_t publish_address;
        if (access_model_publish_address_get(p_client->model_handle, &publish_handle) != NRF_SUCCESS ||
            publish_handle == DSM_HANDLE_INVALID ||
            dsm_address_get(publish_handle, &publish_address) != NRF_SUCCESS ||
            publish_address.value != p_message->meta_data.src.value)
            return false;
            return true;
    static uint32_t send_reliable_message(const simple_on_off_client_t * p_client,
                                          simple_on_off_opcode_t opcode,
                                          const uint8_t * p_data,
                                          uint16_t length)
        access_reliable_t reliable;
        reliable.model_handle = p_client->model_handle;
        reliable.message.p_buffer = p_data;
        reliable.message.length = length;
        reliable.message.opcode.opcode = opcode;
        reliable.message.opcode.company_id = SIMPLE_ON_OFF_COMPANY_ID;
        reliable.message.force_segmented = false;
        reliable.message.transmic_size = NRF_MESH_TRANSMIC_SIZE_DEFAULT;
        reliable.reply_opcode.opcode = SIMPLE_ON_OFF_OPCODE_STATUS;
        reliable.reply_opcode.company_id = SIMPLE_ON_OFF_COMPANY_ID;
        reliable.timeout = ACCESS_RELIABLE_TIMEOUT_MIN;
        reliable.status_cb = reliable_status_cb;
        return access_model_reliable_publish(&reliable);
     * Opcode handler callback(s)
    static void handle_status_cb(access_model_handle_t handle, const access_message_rx_t * p_message, void * p_args)
        if (!is_valid_source(p_client, p_message))
            return;
        simple_on_off_msg_status_t * p_status =
            (simple_on_off_msg_status_t *) p_message->p_data;
        simple_on_off_status_t on_off_status = (p_status->present_on_off ?
                                                  SIMPLE_ON_OFF_STATUS_ON : SIMPLE_ON_OFF_STATUS_OFF);
        p_client->status_cb(p_client, on_off_status, p_message->meta_data.src.value);
    static const access_opcode_handler_t m_opcode_handlers[] =
        {{SIMPLE_ON_OFF_OPCODE_STATUS, SIMPLE_ON_OFF_COMPANY_ID}, handle_status_cb}
    static void handle_publish_timeout(access_model_handle_t handle, void * p_args)
        if (p_client->timeout_cb != NULL)
            p_client->timeout_cb(handle, p_args);
     * Public API
    uint32_t simple_on_off_client_init(simple_on_off_client_t * p_client, uint16_t element_index)
        if (p_client == NULL ||
            p_client->status_cb == NULL)
            return NRF_ERROR_NULL;
        access_model_add_params_t init_params;
        init_params.model_id.model_id = SIMPLE_ON_OFF_CLIENT_MODEL_ID;
        init_params.model_id.company_id = SIMPLE_ON_OFF_COMPANY_ID;
        init_params.element_index = element_index;
        init_params.p_opcode_handlers = &m_opcode_handlers[0];
        init_params.opcode_count = sizeof(m_opcode_handlers) / sizeof(m_opcode_handlers[0]);
        init_params.p_args = p_client;
        init_params.publish_timeout_cb = handle_publish_timeout;
        return access_model_add(&init_params, &p_client->model_handle);
    uint32_t simple_on_off_client_set(simple_on_off_client_t * p_client, bool on_off)
        if (p_client == NULL || p_client->status_cb == NULL)
        else if (p_client->state.reliable_transfer_active)
        p_client->state.data.on_off = on_off ? 1 : 0;
        p_client->state.data.tid = m_tid++;
        uint32_t status = send_reliable_message(p_client,
                                                SIMPLE_ON_OFF_OPCODE_SET,
                                                (const uint8_t *)&p_client->state.data,
                                                sizeof(simple_on_off_msg_set_t));
            p_client->state.reliable_transfer_active = true;
        return status;
    uint32_t simple_on_off_client_set_unreliable(simple_on_off_client_t * p_client, bool on_off, uint8_t repeats)
        simple_on_off_msg_set_unreliable_t set_unreliable;
        set_unreliable.on_off = on_off ? 1 : 0;
        set_unreliable.tid = m_tid++;
        message.opcode.opcode = SIMPLE_ON_OFF_OPCODE_SET_UNRELIABLE;
        message.p_buffer = (const uint8_t*) &set_unreliable;
        message.length = sizeof(set_unreliable);
        for (uint8_t i = 0; i < repeats; ++i)
            if (status != NRF_SUCCESS)
        return status;
    uint32_t simple_on_off_client_get(simple_on_off_client_t * p_client)
                                                SIMPLE_ON_OFF_OPCODE_GET,
                                                NULL,
                                                0);
        return status;
     * Cancel any ongoing reliable message transfer.
     * @param[in] p_client Pointer to the client instance structure.
    void simple_on_off_client_pending_msg_cancel(simple_on_off_client_t * p_client)
        (void)access_model_reliable_cancel(p_client->model_handle);
    Andreas
  • I do have the source file thanks , my problem is Im not sure how to add it to static void mesh_init(void)
    and static void models_init_cb(void) for MESH 3.1. Im either getting compile errors and when it does compile im sitting with mesh error 8.
    the server side is working but the client side is not.  When I provision the server  the elements come us as vendor model which is correct.
    must I remove the generic_on_off .c and .h files from the solution or keep them there ?
    my latest main.c for client below . Im not getting the uuid in RTT viewer just  the following
    <t: 0>, main.c, 300, ----- BLE Mesh Light Switch Client Demo -----
    <t: 13072>, main.c, 271, Initializing and adding models
    <t: 17971>, app_error_weak.c, 108, Mesh assert at 0x0002ACB2 (:0)
    thanks for the help.
    #include <stdint.h>
    #include <string.h>
    /* HAL */
    #include "boards.h"
    /* Core */
    /* Models */
    #include "log.h"
    #define APP_STATE_OFF                (0)
    #define APP_STATE_ON                 (1)
    #define APP_UNACK_MSG_REPEAT_COUNT   (2)
     #define DEV_BOARD_LF_CLK_CFG  { \
            .source = NRF_SDH_CLOCK_LF_SRC, \
            .rc_ctiv = NRF_SDH_CLOCK_LF_RC_CTIV, \
            .rc_temp_ctiv = NRF_SDH_CLOCK_LF_RC_TEMP_CTIV, \
            .accuracy = NRF_SDH_CLOCK_LF_ACCURACY \
    //static void client_status_cb(const simple_on_off_client_t *p_self, simple_on_off_status_t status, uint16_t src);
            return false;
        } else {
          return false;
      return true;
    static void device_identification_start_cb(uint8_t attention_duration_s)
        hal_led_mask_set(LEDS_MASK, false);
        hal_led_blink_ms(BSP_LED_2_MASK  | BSP_LED_3_MASK,
                         LED_BLINK_ATTENTION_INTERVAL_MS,
                         LED_BLINK_ATTENTION_COUNT(attention_duration_s));
    static void provisioning_aborted_cb(void)
        hal_led_blink_stop();
      return index;
      switch (status) {
      //uint32_t status = config_client_node_reset();
      //__LOG(LOG_SRC_APP, LOG_LEVEL_ERROR,"Node Reset Status:0x%08lX\n",status);
      /* This function may return if there are ongoing flash operations. */
        node_reset();
        case 0:
        case 1:
        case 2:
        case 3:
        } else {
      } else {
      //int i;
      return status;
        __LOG_INIT(LOG_SRC_APP | LOG_SRC_ACCESS | LOG_SRC_BEARER, LOG_LEVEL_INFO, LOG_CALLBACK_DEFAULT);
        ERROR_CHECK(app_timer_init());
        hal_leds_init();
    #if BUTTON_BOARD
        ble_stack_init();
    #if MESH_FEATURE_GATT_ENABLED
        gap_params_init();
        conn_params_init();
        mesh_init();
                .prov_complete_cb = provisioning_complete_cb,
                .prov_device_identification_start_cb = device_identification_start_cb,
                .prov_device_identification_stop_cb = NULL,
                .prov_abort_cb = provisioning_aborted_cb,
                .p_device_uri = EX_URI_LS_CLIENT
        mesh_app_uuid_print(nrf_mesh_configure_device_uuid_get());
    //  const uint8_t *p_uuid = nrf_mesh_configure_device_uuid_get();
    //  __LOG_XB(LOG_SRC_APP, LOG_LEVEL_INFO, "Device UUID ", p_uuid, NRF_MESH_UUID_SIZE);
      initialize();
      start();
      for (;;) {
  • Hi Andreas I have managed to compile and run the Vendor_client model
    problem was as per below p.uuid=NULL,
            .core.p_uuid             = NULL,//dev_uuid,
    Complete main.c for vendor client on off model below
    #include <stdint.h>
    #include <string.h>
    /* HAL */
    #include "boards.h"
    /* Core */
    /* Models */
    #include "log.h"
            return false;
        } else {
          return false;
      return true;
      return index;
      switch (status) {
        node_reset();
        case 0:
        case 1:
        case 2:
        case 3:
        } else {
      } else {
      //int i;
      return status;
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- PCA10059 client -----\n");
        hal_leds_init();
    #if BUTTON_BOARD
        ble_stack_init();
        gap_params_init();
        conn_params_init();
        mesh_init();
      //ERROR_CHECK(mesh_stack_start());
      initialize();
      start();
      for (;;) {
  • Hi.
    Great to see that you solved the problem! I would like to wish you good luck with further work!
    Andreas
