simple_on_off vendor model on Mesh 3.1
I am converting the simple_on_off vendor model to send a message on mesh 3.1.
the server  implemented the simple_on_off model successfully. But but my client runs into  0>, app_error_weak.c,  119, Mesh error 8 at 0x00000000 (:0)  straight away.
I suspect the line below in mesh_init could be causing the problem
  .core.p_uuid = dev_uuid,
NOTE: This is for the PCA10059 not the DK. LEDS and Buttons have been remapped. I have removed generic_on_off model .c and . h files. I have kept model_common.c
/* Copyright (c) 2010 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
 * list of conditions and the following disclaimer.
#include <stdint.h>
#include <string.h>
/* HAL */
#include "boards.h"
#include "simple_hal.h"
#include "app_timer.h"
/* Core */
#include "nrf_mesh_config_core.h"
#include "nrf_mesh_gatt.h"
#include "nrf_mesh_configure.h"
#include "nrf_mesh.h"
#include "mesh_stack.h"
#include "device_state_manager.h"
#include "access_config.h"
/* Provisioning and configuration */
#include "mesh_provisionee.h"
#include "mesh_app_utils.h"
/* Models */
//#include "generic_onoff_client.h"
#include "simple_on_off_client.h"
#include "simple_on_off_common.h"
/* Logging and RTT */
#include "log.h"
#include "rtt_input.h"
/* Example specific includes */
#include "app_config.h"
#include "nrf_mesh_config_examples.h"
#include "light_switch_example_common.h"
#include "example_common.h"
#include "ble_softdevice_support.h"
#define RTT_INPUT_POLL_PERIOD_MS (100)
#define GROUP_MSG_REPEAT_COUNT (2)
#define LED_BLINK_INTERVAL_MS (200)
#define LED_BLINK_SHORT_INTERVAL_MS (50)
#define LED_BLINK_CNT_START (2)
#define LED_BLINK_CNT_RESET (3)
#define LED_BLINK_CNT_PROV (4)
#define LED_BLINK_CNT_NO_REPLY (6)
static simple_on_off_client_t m_clients[CLIENT_MODEL_INSTANCE_COUNT];
//static const uint8_t m_client_node_uuid[NRF_MESH_UUID_SIZE] = CLIENT_NODE_UUID;
static bool m_device_provisioned;
static void client_status_cb(const simple_on_off_client_t *p_self, simple_on_off_status_t status, uint16_t src);
static bool client_publication_configured(void) {
  dsm_handle_t pub_addr_handle;
  for (uint8_t i = 0; i < CLIENT_MODEL_INSTANCE_COUNT; i++) {
    if (access_model_publish_address_get(m_clients[i].model_handle, &pub_addr_handle) == NRF_SUCCESS) {
      if (pub_addr_handle == DSM_HANDLE_INVALID) {
        return false;
    } else {
      return false;
  return true;
static void provisioning_complete_cb(void) {
  __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Successfully provisioned\n");
  dsm_local_unicast_address_t node_address;
  dsm_local_unicast_addresses_get(&node_address);
  __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Node Address: 0x%04x \n", node_address.address_start);
  hal_led_mask_set(LEDS_MASK, LED_MASK_STATE_OFF);
  hal_led_blink_ms(LEDS_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_PROV);
static uint32_t server_index_get(const simple_on_off_client_t *p_client) {
  uint32_t index = p_client - &m_clients[0];
  NRF_MESH_ASSERT(index < SERVER_NODE_COUNT);
  return index;
static void client_publish_timeout_cb(access_model_handle_t handle, void *p_self) {
  __LOG(LOG_SRC_APP, LOG_LEVEL_ERROR, "Acknowledged send timedout\n");
static void client_status_cb(const simple_on_off_client_t *p_self, simple_on_off_status_t status, uint16_t src) {
  uint32_t server_index = server_index_get(p_self);
  //__LOG(LOG_SRC_APP, LOG_LEVEL_ERROR, "server status received \n",p_self);
  switch (status) {
  case SIMPLE_ON_OFF_STATUS_ON:
    hal_led_pin_set(BSP_LED_0 + server_index, true);
  case SIMPLE_ON_OFF_STATUS_OFF:
    hal_led_pin_set(BSP_LED_0 + server_index, false);
  case SIMPLE_ON_OFF_STATUS_ERROR_NO_REPLY:
    hal_led_blink_ms(LEDS_MASK, LED_BLINK_SHORT_INTERVAL_MS, LED_BLINK_CNT_NO_REPLY);
  case SIMPLE_ON_OFF_STATUS_CANCELLED:
    __LOG(LOG_SRC_APP, LOG_LEVEL_ERROR, "Unknown status \n");
static void node_reset(void) {
  __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- Node reset  -----\n");
  hal_led_blink_ms(LEDS_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_RESET);
  mesh_stack_device_reset();
static void config_server_evt_cb(const config_server_evt_t *p_evt) {
  if (p_evt->type == CONFIG_SERVER_EVT_NODE_RESET) {
    node_reset();
static void button_event_handler(uint32_t button_number) {
  //__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Button %u pressed\n", button_number);
  if (client_publication_configured()) {
    uint32_t status = NRF_SUCCESS;
    switch (button_number) {
    case 0:
    case 1:
      /* send unicast message, with inverted GPIO pin value */
      status = simple_on_off_client_set(&m_clients[button_number],
          !hal_led_pin_get(BSP_LED_0 + button_number));
    case 2:
    case 3:
      /* send a group message to the ODD group, with inverted GPIO pin value */
      status = simple_on_off_client_set_unreliable(&m_clients[button_number],
          !hal_led_pin_get(BSP_LED_0 + button_number),
          GROUP_MSG_REPEAT_COUNT);
      hal_led_pin_set(BSP_LED_0 + button_number, !hal_led_pin_get(BSP_LED_0 + button_number));
    if (status == NRF_ERROR_INVALID_STATE ||status == NRF_ERROR_NO_MEM ||status == NRF_ERROR_BUSY) {
      __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Cannot send. Device is busy.\n");
    } else {
      ERROR_CHECK(status);
  } else {
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Ignored. Node is not configured.\n");
/*uint32_t send_command_client(simple_on_off_client_t *p_client, uint8_t *msg, uint16_t length) {
  //int i;
  send_command_msg_t command_msg;
  command_msg.length = length;
  strncpy(command_msg.command, msg, length);
  access_message_tx_t message;
  message.opcode.opcode = SEND_COMMAND;
  message.opcode.company_id = ACCESS_COMPANY_ID_NORDIC;
  message.p_buffer = (const uint8_t *)&command_msg;
  message.length = command_msg.length + 2;
  status = access_model_publish(p_client->model_handle, &message);
  Method for sending to all nodes!
  for (uint8_t i = 0; i < 3; ++i)
        if (status == NRF_SUCCESS) {
  return status;
static void rtt_input_handler(int key)
    if (key >= '0' && key <= '3')
        uint32_t button_number = key - '0';
        button_event_handler(button_number);
static void models_init_cb(void) {
  __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Initializing and adding models\n");
  for (uint32_t i = 0; i < CLIENT_MODEL_INSTANCE_COUNT; ++i) {
    m_clients[i].status_cb = client_status_cb;
    m_clients[i].timeout_cb = client_publish_timeout_cb;
    ERROR_CHECK(simple_on_off_client_init(&m_clients[i], i + 1));
    ERROR_CHECK(access_model_subscription_list_alloc(m_clients[i].model_handle));
static void mesh_init(void) {
uint8_t dev_uuid[NRF_MESH_UUID_SIZE];
 uint8_t node_uuid_prefix[NODE_UUID_PREFIX_LEN] = CLIENT_NODE_UUID_PREFIX;
  mesh_stack_init_params_t init_params =
          .core.irq_priority = NRF_MESH_IRQ_PRIORITY_LOWEST,
          .core.lfclksrc = DEV_BOARD_LF_CLK_CFG,
          .models.models_init_cb = models_init_cb,
          .models.config_server_cb = config_server_evt_cb};
  ERROR_CHECK(mesh_stack_init(&init_params, &m_device_provisioned));
static void initialize(void) {
  __LOG_INIT(LOG_SRC_APP | LOG_SRC_ACCESS, LOG_LEVEL_INFO, LOG_CALLBACK_DEFAULT);
  __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- BLE Mesh Light Switch Client Demo -----\n");
  hal_leds_init();
#if BUTTON_BOARD
  ERROR_CHECK(hal_buttons_init(button_event_handler));
 nrf_clock_lf_cfg_t lfc_cfg = DEV_BOARD_LF_CLK_CFG;
  mesh_init();
static void start(void) {
  rtt_input_enable(rtt_input_handler, RTT_INPUT_POLL_PERIOD_MS);
  ERROR_CHECK(mesh_stack_start());
  if (!m_device_provisioned) {
    static const uint8_t static_auth_data[NRF_MESH_KEY_SIZE] = STATIC_AUTH_DATA;
    mesh_provisionee_start_params_t prov_start_params =
            .p_static_data = static_auth_data,
            .prov_complete_cb = provisioning_complete_cb};
    ERROR_CHECK(mesh_provisionee_prov_start(&prov_start_params));
  const uint8_t *p_uuid = nrf_mesh_configure_device_uuid_get();
  __LOG_XB(LOG_SRC_APP, LOG_LEVEL_INFO, "Device UUID ", p_uuid, NRF_MESH_UUID_SIZE);
  hal_led_blink_ms(LEDS_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_START);
int main(void) {
  bsp_board_init(BSP_INIT_LEDS); // leds fro pca10059
  initialize();
  start();
  for (;;) {
    (void)sd_app_evt_wait();
If someone could shed some light as to why im getting error 8
thanks in advance
  • Hi Andreas I have managed to compile and run the Vendor_client model
    problem was as per below p.uuid=NULL,
            .core.p_uuid             = NULL,//dev_uuid,
    Complete main.c for vendor client on off model below
    #include <stdint.h>
    #include <string.h>
    /* HAL */
    #include "boards.h"
    /* Core */
    /* Models */
    #include "log.h"
    #define APP_STATE_OFF                (0)
    #define APP_STATE_ON                 (1)
    #define APP_UNACK_MSG_REPEAT_COUNT   (2)
     #define DEV_BOARD_LF_CLK_CFG  { \
            .source = NRF_SDH_CLOCK_LF_SRC, \
            .rc_ctiv = NRF_SDH_CLOCK_LF_RC_CTIV, \
            .rc_temp_ctiv = NRF_SDH_CLOCK_LF_RC_TEMP_CTIV, \
            .accuracy = NRF_SDH_CLOCK_LF_ACCURACY \
    //static void client_status_cb(const simple_on_off_client_t *p_self, simple_on_off_status_t status, uint16_t src);
            return false;
        } else {
          return false;
      return true;
    static void device_identification_start_cb(uint8_t attention_duration_s)
        hal_led_mask_set(LEDS_MASK, false);
        hal_led_blink_ms(BSP_LED_2_MASK  | BSP_LED_3_MASK,
                         LED_BLINK_ATTENTION_INTERVAL_MS,
                         LED_BLINK_ATTENTION_COUNT(attention_duration_s));
    static void provisioning_aborted_cb(void)
        hal_led_blink_stop();
      return index;
      switch (status) {
      //uint32_t status = config_client_node_reset();
      //__LOG(LOG_SRC_APP, LOG_LEVEL_ERROR,"Node Reset Status:0x%08lX\n",status);
      /* This function may return if there are ongoing flash operations. */
        node_reset();
        case 0:
        case 1:
        case 2:
        case 3:
        } else {
      } else {
      //int i;
      return status;
        __LOG_INIT(LOG_SRC_APP | LOG_SRC_ACCESS | LOG_SRC_BEARER, LOG_LEVEL_INFO, LOG_CALLBACK_DEFAULT);
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- PCA10059 client -----\n");
        ERROR_CHECK(app_timer_init());
        hal_leds_init();
    #if BUTTON_BOARD
        ble_stack_init();
    #if MESH_FEATURE_GATT_ENABLED
        gap_params_init();
        conn_params_init();
        mesh_init();
      //ERROR_CHECK(mesh_stack_start());
                .prov_complete_cb = provisioning_complete_cb,
                .prov_device_identification_start_cb = device_identification_start_cb,
                .prov_device_identification_stop_cb = NULL,
                .prov_abort_cb = provisioning_aborted_cb,
                .p_device_uri = EX_URI_LS_CLIENT
        mesh_app_uuid_print(nrf_mesh_configure_device_uuid_get());
    //  const uint8_t *p_uuid = nrf_mesh_configure_device_uuid_get();
    //  __LOG_XB(LOG_SRC_APP, LOG_LEVEL_INFO, "Device UUID ", p_uuid, NRF_MESH_UUID_SIZE);
      initialize();
      start();
      for (;;) {
  • Hi.
    Great to see that you solved the problem! I would like to wish you good luck with further work!
    Andreas
