Can't connect to third-party peripheral - BLE_HCI_CONN_FAILED_TO_BE_ESTABLISHED
I'm having issues trying to connect to a third-party peripheral (called iTag from now on).
I have an NRF52832-based device running as a central. My device is running on SDK15, SD 6.0.0.
I can connect to several other third-party peripherals without issues, it's just this one that's giving me problems.
My device scans for the iTag and "connects" successfully to it (i.e. I get the GAP_EVT_CONNECTED). I know that this event just means that the connection request has been sent and that the connection is not necessarily established until the iTag replies. Since apparently this does not happen, I get a disconnection with reason BLE_HCI_CONN_FAILED_TO_BE_ESTABLISHED after a while.
I sniffed the connection and I can see my device sending CONNECT_REQ once and then 5 empty PDUs. After that, the iTag starts advertising again.
Both Android and iOS devices can connect to this iTag without any issues. I tested on phones that support BLE 5.0 just to be sure.
The only difference I see in the sniffed packets is that the CONNECT_REQ of my device has the ChSel bit set to 1. Both the Android phone's and the iPhone X's CONNECT_REQs have it set to 0, even though they support BLE 5.0.
Every thread I've read so far explains that this behavior is attributed to noisy environments, clock issues or filter policies, but I don't think any of those things are the issue. I think the iTag does receive the CONNECT_REQ, since it stops advertising.
Any ideas why this could be happening? My guess is that the iTag doesn't handle the ChSel stuff properly. Is it possible to disable that in the SoftDevice somehow? I know that setting it to 1 is part of the spec, but it's giving me compatibility issues.
I attached the sniffed logs below:
No.     Time     Source                PHY        Protocol Length     Delta time (µs end to start) SN         NESN       More Data  Event counter Info
     16 11.984   ff:ff:c0:18:01:83     LE 1M      LE LL    20         640                                                            0             ADV_IND
Frame 16: 46 bytes on wire (368 bits), 46 bytes captured (368 bits) on interface 0
Nordic BLE Sniffer
Bluetooth Low Energy Link Layer
    Access Address: 0x8e89bed6
    Packet Header: 0x1400 (PDU Type: ADV_IND, ChSel: #1, TxAdd: Public)
        .... 0000 = PDU Type: ADV_IND (0x0)
        ...0 .... = RFU: 0
        ..0. .... = Channel Selection Algorithm: #1
        .0.. .... = Tx Address: Public
        0... .... = Reserved: False
        Length: 20
    Advertising Address: ff:ff:c0:18:01:83 (ff:ff:c0:18:01:83)
    Advertising Data
    CRC: 0xdd16e2
     17 11.984   c4:af:a8:f2:1a:8f     LE 1M      LE LL    34         150                                                            0             CONNECT_REQ
Frame 17: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface 0
Nordic BLE Sniffer
    Packet Header: 0x2265 (PDU Type: CONNECT_REQ, ChSel: #2, TxAdd: Random, RxAdd: Public)
        .... 0101 = PDU Type: CONNECT_REQ (0x5)
        ...0 .... = RFU: 0
        ..1. .... = Channel Selection Algorithm: #2
        .1.. .... = Tx Address: Random
        0... .... = Rx Address: Public
        Length: 34
    Initator Address: c4:af:a8:f2:1a:8f (c4:af:a8:f2:1a:8f)
    Link Layer Data
        Access Address: 0x1b67ed37
        CRC Init: 0x2a1b2a
        Window Size: 5 (6.25 msec)
        Window Offset: 2400 (3000 msec)
        Interval: 2400 (3000 msec)
        Latency: 2
        Timeout: 2000 (20000 msec)
        Channel Map: ffffffff1f
            .... ...1 = RF Channel 1 (2404 MHz - Data - 0): True
            .... ..1. = RF Channel 2 (2406 MHz - Data - 1): True
            .... .1.. = RF Channel 3 (2408 MHz - Data - 2): True
            .... 1... = RF Channel 4 (2410 MHz - Data - 3): True
            ...1 .... = RF Channel 5 (2412 MHz - Data - 4): True
            ..1. .... = RF Channel 6 (2414 MHz - Data - 5): True
            .1.. .... = RF Channel 7 (2416 MHz - Data - 6): True
            1... .... = RF Channel 8 (2418 MHz - Data - 7): True
            .... ...1 = RF Channel 9 (2420 MHz - Data - 8): True
            .... ..1. = RF Channel 10 (2422 MHz - Data - 9): True
            .... .1.. = RF Channel 11 (2424 MHz - Data - 10): True
            .... 1... = RF Channel 13 (2428 MHz - Data - 11): True
            ...1 .... = RF Channel 14 (2430 MHz - Data - 12): True
            ..1. .... = RF Channel 15 (2432 MHz - Data - 13): True
            .1.. .... = RF Channel 16 (2434 MHz - Data - 14): True
            1... .... = RF Channel 17 (2436 MHz - Data - 15): True
            .... ...1 = RF Channel 18 (2438 MHz - Data - 16): True
            .... ..1. = RF Channel 19 (2440 MHz - Data - 17): True
            .... .1.. = RF Channel 20 (2442 MHz - Data - 18): True
            .... 1... = RF Channel 21 (2444 MHz - Data - 19): True
            ...1 .... = RF Channel 22 (2446 MHz - Data - 20): True
            ..1. .... = RF Channel 23 (2448 MHz - Data - 21): True
            .1.. .... = RF Channel 24 (2450 MHz - Data - 22): True
            1... .... = RF Channel 25 (2452 MHz - Data - 23): True
            .... ...1 = RF Channel 26 (2454 MHz - Data - 24): True
            .... ..1. = RF Channel 27 (2456 MHz - Data - 25): True
            .... .1.. = RF Channel 28 (2458 MHz - Data - 26): True
            .... 1... = RF Channel 29 (2460 MHz - Data - 27): True
            ...1 .... = RF Channel 30 (2462 MHz - Data - 28): True
            ..1. .... = RF Channel 31 (2464 MHz - Data - 29): True
            .1.. .... = RF Channel 32 (2466 MHz - Data - 30): True
            1... .... = RF Channel 33 (2468 MHz - Data - 31): True
            .... ...1 = RF Channel 34 (2470 MHz - Data - 32): True
            .... ..1. = RF Channel 35 (2472 MHz - Data - 33): True
            .... .1.. = RF Channel 36 (2474 MHz - Data - 34): True
            .... 1... = RF Channel 37 (2476 MHz - Data - 35): True
            ...1 .... = RF Channel 38 (2478 MHz - Data - 36): True
            ..0. .... = RF Channel 0 (2402 MHz - Reserved for Advertising - 37): False
            .0.. .... = RF Channel 12 (2426 MHz - Reserved for Advertising - 38): False
            0... .... = RF Channel 39 (2480 MHz - Reserved for Advertising - 39): False
        ...0 1111 = Hop: 15
        101. .... = Sleep Clock Accuracy: 31 ppm to 50 ppm (5)
    CRC: 0xbdd292
     18 15.029   Master_0x1b67ed37     LE 1M      LE LL    0          3001204                       0          0          False      0             Empty PDU
Frame 18: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface 0
Nordic BLE Sniffer
    [Master Address: c4:af:a8:f2:1a:8f (c4:af:a8:f2:1a:8f)]
    [Slave Address: ff:ff:c0:18:01:83 (ff:ff:c0:18:01:83)]
    Data Header: 0x0001
    CRC: 0xf2d968
     19 18.013   Master_0x1b67ed37     LE 1M      LE LL    0          2999873                       0          0          False      1             Empty PDU
Frame 19: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface 0
Nordic BLE Sniffer
    Data Header: 0x0001
    CRC: 0xf2d968
     20 20.982   Master_0x1b67ed37     LE 1M      LE LL    0          2999874                       0          0          False      2             Empty PDU
Frame 20: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface 0
Nordic BLE Sniffer
    Data Header: 0x0001
    CRC: 0xf2d968
     21 23.945   Master_0x1b67ed37     LE 1M      LE LL    0          2999873                       0          0          False      3             Empty PDU
Frame 21: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface 0
Nordic BLE Sniffer
    Data Header: 0x0001
    CRC: 0xf2d968
     22 27.005   Master_0x1b67ed37     LE 1M      LE LL    0          2999873                       0          0          False      4             Empty PDU
Frame 22: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface 0
Nordic BLE Sniffer
    Data Header: 0x0001
    CRC: 0xf2d968
     23 29.955   Master_0x1b67ed37     LE 1M      LE LL    0          2999874                       0          0          False      5             Empty PDU
Frame 23: 26 bytes on wire (208 bits), 26 bytes captured (208 bits) on interface 0
Nordic BLE Sniffer
    Data Header: 0x0001
    CRC: 0xf2d968
     24 51.000   ff:ff:c0:18:01:83     LE 1M      LE LL    20         21010146                                                       0             ADV_IND
Frame 24: 46 bytes on wire (368 bits), 46 bytes captured (368 bits) on interface 0
Nordic BLE Sniffer
        ...0 .... = RFU: 0
        Length: 20
    Advertising Data
    CRC: 0xdd16e2
Connection request Android.txt
By the way, I tried connecting to the same iTag using an NRF51822 on SDK12 and the connection seems to work without any issues.
Thanks for your help!
  • Any ideas why this could be happening? My guess is that the iTag doesn't handle the ChSel stuff properly. Is it possible to disable that in the SoftDevice somehow? I know that setting it to 1 is part of the spec, but it's giving me compatibility issues.
    It's the second time I can find report of this, so it is very rare, I will in any case report it internally so we can keep track of it. It may look like the peer host can't handle that the CSA#2 bit is set, and likely assert or fails in some way. It's not much that can be done with this, other than possible check with the peer manufacturer to fix this, there is currently no plan to override/clear CSA#2 bit in the softdevice. Thanks for letting us know.
  • Can I make a feature request then? It should be possible since you do something very similar already:
    Could you create a GAP option ID for a new compatibility mode? You already have the enable compatibility mode 1 option which, according to the documentation, does the following:
    "Compatibility mode 1 enables interoperability with devices that do not support a value of 0 for the WinOffset parameter in the Link Layer CONNECT_IND packet. This applies to a limited set of legacy peripheral devices from another vendor. Enabling this compatibility mode will only have an effect if the local device will act as a central device and initiate a connection to a peripheral device. In that case it may lead to the connection creation taking up to one connection interval longer to complete for all connections."
    I basically need a compatibility mode that enables interoperability with devices that do not support a value of 1 for the ChSel parameter in the Link Layer CONNECT_IND packet.
  • I'm working with Andy on this and also had a closer look, sniffing some more connections to the iTag:
    iPhone 6, iPhone 7, iPhone X (Bluetooth 5), and Xiami Redmi Note 5 (Bluetooth 5) all only ever try to use Channel Selection Algorithm #1.
    We don't know for sure if this is what is causing the incompatibility - would it be possible to get a Beta Softdevice with the the ChSel Bit permanently unset to test with? Can you see anything else in the packets that could cause such a problem?
    TI has the option to set local supported Features, such as whether to support Algorithm #2 or not. This would be a great feature for the next softdevice for us!
    http://dev.ti.com/tirex/content/simplelink_cc2640r2_sdk_1_35_00_33/docs/ble5stack/ble_user_guide/html/ble-stack/channel-selection-algorithm-number-two.html
    Thanks already!
  • I have updated the internal jira case with your additonal findings and suggestions. Though I don't have any news at the moment. If you experience the same issue with other peer devices than iTag let me know.
    Kenneth
