UNABLE TO GENERATE PRIVATE KEY
I am following a tutorial in order to learn the procedure for DFU OTA . I installed the nrfutil but still unable to generate the private key.
I have tried several commands like :
nrfutil.exe keys generate private.key
nrfutil.exe keys generate priv.pem
but it did not work
I think i am using the latest version . 5.0.0
I am getting such errors : TypeError: write() argument must be str, not bytes
NameError: name 'raw_input' is not defined
Please suggest.
Could I be in wrong directory while writing these commands ?
C:\Users\ArshdeepMalik>nrfutil.exe keys generate private.key
Thanks much!
  • Yes Of course.
    A1. Generate your own private key : Generated
    A2. Generate your public key based on your private key : Generated
    B1. Compile the uECC library : Compiled, looks like this :
    Then went inside folder \nRF5_SDK_15.0.0_a53641a\external\micro-ecc\nrf52nf_keil\armgcc and typed make.
    B2. Copy the public_key.c file : copied the public_key.c file here \nRF5_SDK_15.0.0_a53641a\examples\dfu\secure_bootloader and built the example successfully.
    Then created a zip folder in Desktop, DFU.zip . Copied the hex file from example SDK ble_app_blinky_pca10056_s140.hex into DFU.zip folder and also copied the private.key in the same folder.
    Then tried to send this DFU.zip folder using nrfConnect app.
  • Hi
     Which command did you use in CMD? :-)
    You have to use nrfutil to generate a DFU packet.
    Andreas
  • Thanks Andreas, I was able to generate the zip folder using the nrfutil but now i am running into 2 new issue ->
    1) After uploading the DFU.zip folder to nrf52840 DK from nrf Connect app, it does not run my application and kind of erases everything from board. The upload goes till 100% and seems like it did upload it successfully.
    2) After I upload the DFU.zip folder, every time i try to flash another program using SES,  it keeps on going in DFU mode. I am unable to exit from DFU mode.
    Please Suggest .
  • Hi.
    Could you please post the nrfutil command that you used to generate the DFU packet? :-)
    Andreas
  • nrfutil pkg generate --hw-version 52 --application-version 3 --application ble_app_blinky_pca10056_s140.hex --sd-req 0xA9 --key-file private.pem app_dfu_package.zip
