nRF52 Rx/Tx packet loss
I need to be able to count the number of packet Tx and Rx from one board to another in order to compute a packet loss ratio for certification purpose.
To achieve this, I started by slightly modify the DTM example of the nRF52 14.2.0 SDK. I use Keil µVision IDE (on Windows 10 64bits) to build the firmware, and then I used a modified version of the DTM python script example from nAN34 to test it.
I tried it with two PCA10056 and got mitigated results.
With the default settings, if the boards are next to each other (less than 5cm apart), I don't lose any packets, but when I slightly increase the distance between the boards (even less than 1 meter), I start losing packets.
Then, I tried the same experimentation with the plain “transmitter” and “receiver” firmware from the peripheral/radio example, and got the same results.
So my question is, is it normal to have packet loss with such a small distance between two boards ? If not, what could be the reason ?
Thanks in advance,
Mehdi
 * Copyright (c) 2012 - 2017, Nordic Semiconductor ASA
 * All rights reserved.
#include "sdk_common.h"
#if NRF_MODULE_ENABLED(BLE_DTM)
#include "ble_dtm.h"
#include "ble_dtm_hw.h"
#include <stdbool.h>
#include <string.h>
#include "nrf.h"
#define DTM_HEADER_OFFSET        0                                         /**< Index where the header of the pdu is located. */
#define DTM_HEADER_SIZE          2                                         /**< Size of PDU header. */
#define DTM_PAYLOAD_MAX_SIZE     255                                       /**< Maximum payload size allowed during dtm execution. */
#define DTM_LENGTH_OFFSET        (DTM_HEADER_OFFSET + 1)                   /**< Index where the length of the payload is encoded. */
#define DTM_PDU_MAX_MEMORY_SIZE  (DTM_HEADER_SIZE + DTM_PAYLOAD_MAX_SIZE)  /**< Maximum PDU size allowed during dtm execution. */
#define DTM_ON_AIR_OVERHEAD_SIZE 10                                        /**< Size of the packet on air without the payload (preamble + sync word + type + RFU + length + CRC). */
#define RX_MODE          true   /**< Constant defining RX mode for radio during dtm test. */
#define TX_MODE          false  /**< Constant defining TX mode for radio during dtm test. */
#define PHYS_CH_MAX      39     /**< Maximum number of valid channels in BLE. */
// Values that for now are "constants" - they could be configured by a function setting them,
// but most of these are set by the BLE DTM standard, so changing them is not relevant.
#define RFPHY_TEST_0X0F_REF_PATTERN  0x0f  /**<  RF-PHY test packet patterns, for the repeated octet packets. */
#define RFPHY_TEST_0X55_REF_PATTERN  0x55  /**<  RF-PHY test packet patterns, for the repeated octet packets. */
#define RFPHY_TEST_0XFF_REF_PATTERN  0xFF  /**<  RF-PHY test packet patterns, for the repeated octet packets. */
#define PRBS9_CONTENT  {0xFF, 0xC1, 0xFB, 0xE8, 0x4C, 0x90, 0x72, 0x8B,   \
                        0xE7, 0xB3, 0x51, 0x89, 0x63, 0xAB, 0x23, 0x23,   \
                        0x02, 0x84, 0x18, 0x72, 0xAA, 0x61, 0x2F, 0x3B,   \
                        0x51, 0xA8, 0xE5, 0x37, 0x49, 0xFB, 0xC9, 0xCA,   \
                        0x0C, 0x18, 0x53, 0x2C, 0xFD, 0x45, 0xE3, 0x9A,   \
                        0xE6, 0xF1, 0x5D, 0xB0, 0xB6, 0x1B, 0xB4, 0xBE,   \
                        0x2A, 0x50, 0xEA, 0xE9, 0x0E, 0x9C, 0x4B, 0x5E,   \
                        0x57, 0x24, 0xCC, 0xA1, 0xB7, 0x59, 0xB8, 0x87,   \
                        0xFF, 0xE0, 0x7D, 0x74, 0x26, 0x48, 0xB9, 0xC5,   \
                        0xF3, 0xD9, 0xA8, 0xC4, 0xB1, 0xD5, 0x91, 0x11,   \
                        0x01, 0x42, 0x0C, 0x39, 0xD5, 0xB0, 0x97, 0x9D,   \
                        0x28, 0xD4, 0xF2, 0x9B, 0xA4, 0xFD, 0x64, 0x65,   \
                        0x06, 0x8C, 0x29, 0x96, 0xFE, 0xA2, 0x71, 0x4D,   \
                        0xF3, 0xF8, 0x2E, 0x58, 0xDB, 0x0D, 0x5A, 0x5F,   \
                        0x15, 0x28, 0xF5, 0x74, 0x07, 0xCE, 0x25, 0xAF,   \
                        0x2B, 0x12, 0xE6, 0xD0, 0xDB, 0x2C, 0xDC, 0xC3,   \
                        0x7F, 0xF0, 0x3E, 0x3A, 0x13, 0xA4, 0xDC, 0xE2,   \
                        0xF9, 0x6C, 0x54, 0xE2, 0xD8, 0xEA, 0xC8, 0x88,   \
                        0x00, 0x21, 0x86, 0x9C, 0x6A, 0xD8, 0xCB, 0x4E,   \
                        0x14, 0x6A, 0xF9, 0x4D, 0xD2, 0x7E, 0xB2, 0x32,   \
                        0x03, 0xC6, 0x14, 0x4B, 0x7F, 0xD1, 0xB8, 0xA6,   \
                        0x79, 0x7C, 0x17, 0xAC, 0xED, 0x06, 0xAD, 0xAF,   \
                        0x0A, 0x94, 0x7A, 0xBA, 0x03, 0xE7, 0x92, 0xD7,   \
                        0x15, 0x09, 0x73, 0xE8, 0x6D, 0x16, 0xEE, 0xE1,   \
                        0x3F, 0x78, 0x1F, 0x9D, 0x09, 0x52, 0x6E, 0xF1,   \
                        0x7C, 0x36, 0x2A, 0x71, 0x6C, 0x75, 0x64, 0x44,   \
                        0x80, 0x10, 0x43, 0x4E, 0x35, 0xEC, 0x65, 0x27,   \
                        0x0A, 0xB5, 0xFC, 0x26, 0x69, 0x3F, 0x59, 0x99,   \
                        0x01, 0x63, 0x8A, 0xA5, 0xBF, 0x68, 0x5C, 0xD3,   \
                        0x3C, 0xBE, 0x0B, 0xD6, 0x76, 0x83, 0xD6, 0x57,   \
                        0x05, 0x4A, 0x3D, 0xDD, 0x81, 0x73, 0xC9, 0xEB,   \
                        0x8A, 0x84, 0x39, 0xF4, 0x36, 0x0B, 0xF7}           /**< The PRBS9 sequence used as packet payload.
        The bytes in the sequence is in the right order, but the bits of each byte in the array is reverse.
        of that found by running the PRBS9 algorithm. This is because of the endianess of the nRF5 radio. */
/**@brief Structure holding the PDU used for transmitting/receiving a PDU.
typedef struct
    uint8_t content[DTM_HEADER_SIZE + DTM_PAYLOAD_MAX_SIZE];                 /**< PDU packet content. */
} pdu_type_t;
/**@brief States used for the DTM test implementation.
typedef enum
    STATE_UNINITIALIZED,                                                     /**< The DTM is uninitialized. */
    STATE_IDLE,                                                              /**< State when system has just initialized, or current test has completed. */
    STATE_TRANSMITTER_TEST,                                                  /**< State used when a DTM Transmission test is running. */
    STATE_CARRIER_TEST,                                                      /**< State used when a DTM Carrier test is running (Vendor specific test). */
    STATE_RECEIVER_TEST                                                      /**< State used when a DTM Receive test is running. */
} state_t;
// Internal variables set as side effects of commands or events.
static state_t           m_state = STATE_UNINITIALIZED;                      /**< Current machine state. */
static uint16_t          m_rx_pkt_count;                                     /**< Number of valid packets received. */
static uint16_t          m_tx_pkt_count;                                     /**< Number of valid packets sent. */
static pdu_type_t        m_pdu;                                              /**< PDU to be sent. */
static uint16_t          m_event;                                            /**< current command status - initially "ok", may be set if error detected, or to packet count. */
static bool              m_new_event;                                        /**< Command has been processed - number of not yet reported event bytes. */
static uint32_t          m_packet_length;                                    /**< Payload length of transmitted PDU, bits 2:7 of 16-bit dtm command. */
static dtm_pkt_type_t    m_packet_type;                                      /**< Bits 0..1 of 16-bit transmit command, or 0xFFFFFFFF. */
static dtm_freq_t        m_phys_ch;                                          /**< 0..39 physical channel number (base 2402 MHz, Interval 2 MHz), bits 8:13 of 16-bit dtm command. */
static uint32_t          m_current_time = 0;                                 /**< Counter for interrupts from timer to ensure that the 2 bytes forming a DTM command are received within the time window. */
// Nordic specific configuration values (not defined by BLE standard).
// Definition of initial values found in ble_dtm.h
static int32_t           m_tx_power          = DEFAULT_TX_POWER;             /**< TX power for transmission test, default to maximum value (+4 dBm). */
static NRF_TIMER_Type *  mp_timer            = DEFAULT_TIMER;                /**< Timer to be used. */
static IRQn_Type         m_timer_irq         = DEFAULT_TIMER_IRQn;           /**< which interrupt line to clear on every timeout */
static uint8_t const     m_prbs_content[]    = PRBS9_CONTENT;                /**< Pseudo-random bit sequence defined by the BLE standard. */
static uint8_t           m_packetHeaderLFlen = 8;                            /**< Length of length field in packet Header (in bits). */
static uint8_t           m_packetHeaderS0len = 1;                            /**< Length of S0 field in packet Header (in bytes). */
static uint8_t           m_packetHeaderS1len = 0;                            /**< Length of S1 field in packet Header (in bits). */
static uint8_t           m_packetHeaderPlen  = RADIO_PCNF0_PLEN_8bit;        /**< Length of the preamble. */
static uint8_t           m_crcConfSkipAddr   = 1;                            /**< Leave packet address field out of CRC calculation. */
static uint8_t           m_static_length     = 0;                            /**< Number of bytes sent in addition to the var.length payload. */
static uint32_t          m_balen             = 3;                            /**< Base address length in bytes. */
static uint32_t          m_endian            = RADIO_PCNF1_ENDIAN_Little;    /**< On air endianess of packet, this applies to the S0, LENGTH, S1 and the PAYLOAD fields. */
static uint32_t          m_whitening         = RADIO_PCNF1_WHITEEN_Disabled; /**< Whitening disabled. */
static uint8_t           m_crcLength         = RADIO_CRCCNF_LEN_Three;       /**< CRC Length (in bytes). */
static uint32_t          m_address           = 0x71764129;                   /**< Address. */
static uint32_t          m_crc_poly          = 0x0000065B;                   /**< CRC polynomial. */
static uint32_t          m_crc_init          = 0x00555555;                   /**< Initial value for CRC calculation. */
static uint8_t           m_radio_mode        = RADIO_MODE_MODE_Ble_1Mbit;    /**< nRF51 specific radio mode value. */
static uint32_t          m_txIntervaluS      = 2500;                          /**< Time between start of Tx packets (in uS). */
/**@brief Function for verifying that a received PDU has the expected structure and content.
static bool check_pdu(void)
    uint8_t        k;                // Byte pointer for running through PDU payload
    uint8_t        pattern;          // Repeating octet value in payload
    dtm_pkt_type_t pdu_packet_type;  // Note: PDU packet type is a 4-bit field in HCI, but 2 bits in BLE DTM
    uint32_t       length = 0;
    pdu_packet_type = (dtm_pkt_type_t)(m_pdu.content[DTM_HEADER_OFFSET] & 0x0F);
    length          = m_pdu.content[DTM_LENGTH_OFFSET];
    // Check that the length is valid.
    if (length > DTM_PAYLOAD_MAX_SIZE)
        return false;
    // If the 1Mbit or 2Mbit radio mode is active, check that one of the three valid uncoded DTM packet types are selected.
    if ((m_radio_mode == RADIO_MODE_MODE_Ble_1Mbit || m_radio_mode == RADIO_MODE_MODE_Ble_2Mbit) && (pdu_packet_type > (dtm_pkt_type_t)DTM_PKT_0X55))
        return false;
#ifdef NRF52840_XXAA
    // If a long range radio mode is active, check that one of the four valid coded DTM packet types are selected.
    if ((m_radio_mode == RADIO_MODE_MODE_Ble_LR500Kbit || m_radio_mode == RADIO_MODE_MODE_Ble_LR125Kbit) && (pdu_packet_type > (dtm_pkt_type_t)DTM_PKT_0XFF))
        return false;
    if (pdu_packet_type == DTM_PKT_PRBS9)
        // Payload does not consist of one repeated octet; must compare ir with entire block into
        return (memcmp(m_pdu.content + DTM_HEADER_SIZE, m_prbs_content, length) == 0);
    if (pdu_packet_type == DTM_PKT_0X0F)
        pattern = RFPHY_TEST_0X0F_REF_PATTERN;
    else if (pdu_packet_type == DTM_PKT_0X55)
        pattern = RFPHY_TEST_0X55_REF_PATTERN;
    else if (pdu_packet_type == DTM_PKT_0XFF)
        pattern = RFPHY_TEST_0XFF_REF_PATTERN;
        // No valid packet type set.
        return false;
    for (k = 0; k < length; k++)
        // Check repeated pattern filling the PDU payload
        if (m_pdu.content[k + 2] != pattern)
            return false;
    return true;
/**@brief Function for turning off the radio after a test.
 *        Also called after test done, to be ready for next test.
static void radio_reset(void)
    NRF_PPI->CHENCLR = PPI_CHENCLR_CH0_Msk | PPI_CHENCLR_CH1_Msk;
    NRF_RADIO->SHORTS          = 0;
    NRF_RADIO->EVENTS_DISABLED = 0;
    NRF_RADIO->TASKS_DISABLE   = 1;
    while (NRF_RADIO->EVENTS_DISABLED == 0)
        // Do nothing
    NRF_RADIO->TASKS_RXEN      = 0;
    NRF_RADIO->TASKS_TXEN      = 0;
/**@brief Function for initializing the radio for DTM.
static uint32_t radio_init(void)
    if (dtm_radio_validate(m_tx_power, m_radio_mode) != DTM_SUCCESS)
        m_event = LE_TEST_STATUS_EVENT_ERROR;
        return DTM_ERROR_ILLEGAL_CONFIGURATION;
    // Turn off radio before configuring it
    radio_reset();
    NRF_RADIO->TXPOWER = m_tx_power;
    NRF_RADIO->MODE    = m_radio_mode << RADIO_MODE_MODE_Pos;
    // Set the access address, address0/prefix0 used for both Rx and Tx address
    NRF_RADIO->PREFIX0    &= ~RADIO_PREFIX0_AP0_Msk;
    NRF_RADIO->PREFIX0    |= (m_address >> 24) & RADIO_PREFIX0_AP0_Msk;
    NRF_RADIO->BASE0       = m_address << 8;
    NRF_RADIO->RXADDRESSES = RADIO_RXADDRESSES_ADDR0_Enabled << RADIO_RXADDRESSES_ADDR0_Pos;
    NRF_RADIO->TXADDRESS   = (0x00 << RADIO_TXADDRESS_TXADDRESS_Pos) & RADIO_TXADDRESS_TXADDRESS_Msk;
    // Configure CRC calculation
    NRF_RADIO->CRCCNF = (m_crcConfSkipAddr << RADIO_CRCCNF_SKIP_ADDR_Pos) |
                        (m_crcLength << RADIO_CRCCNF_LEN_Pos);
    if (m_radio_mode == RADIO_MODE_MODE_Ble_1Mbit || m_radio_mode == RADIO_MODE_MODE_Ble_2Mbit)
        // Non-coded PHY
        NRF_RADIO->PCNF0 = (m_packetHeaderS1len << RADIO_PCNF0_S1LEN_Pos) |
                           (m_packetHeaderS0len << RADIO_PCNF0_S0LEN_Pos) |
                           (m_packetHeaderLFlen << RADIO_PCNF0_LFLEN_Pos) |
                           (m_packetHeaderPlen << RADIO_PCNF0_PLEN_Pos);
        // Coded PHY (Long range)
                       (3 << RADIO_PCNF0_TERMLEN_Pos) |
                       (2 << RADIO_PCNF0_CILEN_Pos) |
    NRF_RADIO->PCNF1 = (m_whitening          << RADIO_PCNF1_WHITEEN_Pos) |
                       (m_endian             << RADIO_PCNF1_ENDIAN_Pos)  |
                       (m_balen              << RADIO_PCNF1_BALEN_Pos)   |
                       (m_static_length      << RADIO_PCNF1_STATLEN_Pos) |
                       (DTM_PAYLOAD_MAX_SIZE << RADIO_PCNF1_MAXLEN_Pos);
    return DTM_SUCCESS;
/**@brief Function for preparing the radio. At start of each test: Turn off RF, clear interrupt flags of RF, initialize the radio
 *        at given RF channel.
 *@param[in] rx     boolean indicating if radio should be prepared in rx mode (true) or tx mode.
static void radio_prepare(bool rx)
    dtm_turn_off_test();
    NRF_RADIO->CRCPOLY      = m_crc_poly;
    NRF_RADIO->CRCINIT      = m_crc_init;
    NRF_RADIO->FREQUENCY    = (m_phys_ch << 1) + 2;                  // Actual frequency (MHz): 2400 + register value
    NRF_RADIO->PACKETPTR    = (uint32_t)&m_pdu;                      // Setting packet pointer will start the radio
    NRF_RADIO->EVENTS_READY = 0;
    NRF_RADIO->SHORTS       = (1 << RADIO_SHORTS_READY_START_Pos) |  // Shortcut between READY event and START task
                              (1 << RADIO_SHORTS_END_DISABLE_Pos);   // Shortcut between END event and DISABLE task
    if (rx)
        NRF_RADIO->EVENTS_END = 0;
        NRF_RADIO->TASKS_RXEN = 1;  // shorts will start radio in RX mode when it is ready
    else // tx
/**@brief Function for terminating the ongoing test (if any) and closing down the radio.
static void dtm_test_done(void)
    NRF_PPI->CHENCLR = 0x01;
    NRF_PPI->CH[0].EEP = 0;     // Break connection from timer to radio to stop transmit loop
    NRF_PPI->CH[0].TEP = 0;
    radio_reset();
    m_state = STATE_IDLE;
/**@brief Function for configuring the timer for 625us cycle time.
static uint32_t timer_init(void)
    // Use 16MHz from external crystal
    // This could be customized for RC/Xtal, or even to use a 32 kHz crystal
    NRF_CLOCK->TASKS_HFCLKSTART    = 1;
    while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0)
        // Do nothing while waiting for the clock to start
    mp_timer->TASKS_STOP        = 1;                      // Stop timer, if it was running
    mp_timer->TASKS_CLEAR       = 1;
    mp_timer->MODE              = TIMER_MODE_MODE_Timer;  // Timer mode (not counter)
    mp_timer->EVENTS_COMPARE[0] = 0;                      // clean up possible old events
    mp_timer->EVENTS_COMPARE[1] = 0;
    mp_timer->EVENTS_COMPARE[2] = 0;
    mp_timer->EVENTS_COMPARE[3] = 0;
    // Timer is polled, but enable the compare0 interrupt in order to wakeup from CPU sleep
    mp_timer->INTENSET    = TIMER_INTENSET_COMPARE0_Msk;
    mp_timer->SHORTS      = 1 << TIMER_SHORTS_COMPARE0_CLEAR_Pos;  // Clear the count every time timer reaches the CCREG0 count
    mp_timer->PRESCALER   = 4;                                     // Input clock is 16MHz, timer clock = 2 ^ prescale -> interval 1us
    mp_timer->CC[0]       = m_txIntervaluS;                        // 625uS with 1MHz clock to the timer
    mp_timer->CC[1]       = UART_POLL_CYCLE;                       // Depends on the baud rate of the UART. Default baud rate of 19200 will result in a 260uS time with 1MHz clock to the timer
    mp_timer->TASKS_START = 1;                                     // Start the timer - it will be running continuously
    m_current_time        = 0;
    return DTM_SUCCESS;
/**@brief Function for handling vendor specific commands.
 *        Used when packet type is set to Vendor specific.
 *        The length field is used for encoding vendor specific command.
 *        The frequency field is used for encoding vendor specific options to the command.
 * @param[in]   vendor_cmd      Vendor specific command to be executed.
 * @param[in]   vendor_option   Vendor specific option to the vendor command.
 * @return      DTM_SUCCESS or one of the DTM_ERROR_ values
static uint32_t dtm_vendor_specific_pkt(uint32_t vendor_cmd, dtm_freq_t vendor_option)
    switch (vendor_cmd)
        // nRFgo Studio uses CARRIER_TEST_STUDIO to indicate a continuous carrier without
        // a modulated signal.
        case CARRIER_TEST:
        case CARRIER_TEST_STUDIO:
            // Not a packet type, but used to indicate that a continuous carrier signal
            // should be transmitted by the radio.
            radio_prepare(TX_MODE);
            dtm_constant_carrier();
            NRF_RADIO->SHORTS = 1 << RADIO_SHORTS_READY_START_Pos;
            // Shortcut will start radio in Tx mode when it is ready
            NRF_RADIO->TASKS_TXEN = 1;
            m_state               = STATE_CARRIER_TEST;
        case SET_TX_POWER:
            if (!dtm_set_txpower(vendor_option))
        case SELECT_TIMER:
            if (!dtm_set_timer(vendor_option))
    // Event code is unchanged, successful
    return DTM_SUCCESS;
static uint32_t dtm_packet_interval_calculate(uint32_t test_payload_length, uint32_t mode)
    uint32_t test_packet_length = 0; // [us] NOTE: bits are us at 1Mbit
    uint32_t packet_interval    = 0; // us
    uint32_t overhead_bits      = 0; // bits
    /* packet overhead
     * see BLE [Vol 6, Part F] page 213
     * 4.1 LE TEST PACKET FORMAT */
    if (mode == RADIO_MODE_MODE_Ble_2Mbit)
        // 16 preamble
        // 32 sync word
        //  8 PDU header, actually packetHeaderS0len * 8
        //  8 PDU length, actually packetHeaderLFlen
        // 24 CRC
        overhead_bits = 88; // 11 bytes
    else if (mode == RADIO_MODE_MODE_Ble_1Mbit)
        //  8 preamble
        // 32 sync word
        // 24 CRC
        overhead_bits = 80; // 10 bytes
    else if (mode == RADIO_MODE_MODE_Ble_LR125Kbit)
        // 80     preamble
        // 32 * 8 sync word coding=8
        //  2 * 8 Coding indicator, coding=8
        //  3 * 8 TERM1 coding=8
        //  8 * 8 PDU header, actually packetHeaderS0len * 8 coding=8
        //  8 * 8 PDU length, actually packetHeaderLFlen coding=8
        // 24 * 8 CRC coding=8
        //  3 * 8 TERM2 coding=8
        overhead_bits = 720; // 90 bytes
    else if (mode == RADIO_MODE_MODE_Ble_LR500Kbit)
        // 80     preamble
        //  3 * 8 TERM 1 coding=8
        //  8 * 2 PDU header, actually packetHeaderS0len * 8 coding=2
        //  8 * 2 PDU length, actually packetHeaderLFlen coding=2
        // 24 * 2 CRC coding=2
        //  3 * 2 TERM2 coding=2
        // NOTE: this makes us clock out 46 bits for CI + TERM1 + TERM2
        //       assumption the radio will handle this
        overhead_bits = 462; // 57.75 bytes
    /* add PDU payload test_payload length */
    test_packet_length = (test_payload_length * 8); // in bits
    // account for the encoding of PDU
        test_packet_length *= 8; // 1 to 8 encoding
        test_packet_length *= 2; //  1 to 2 encoding
    // add overhead calculated above
    test_packet_length += overhead_bits;
    // we remember this bits are us in 1Mbit
        test_packet_length /= 2; // double speed
     * packet_interval = ceil((test_packet_length+249)/625)*625
     * NOTE: To avoid floating point an equivalent calculation is used.
    uint32_t i       = 0;
    uint32_t timeout = 0;
    do
        i++;
        timeout = i * 625;
    } while (test_packet_length + 249 > timeout);
    packet_interval = i * 625;
    return packet_interval;
uint32_t dtm_init(void)
    if ((timer_init() != DTM_SUCCESS) || (radio_init() != DTM_SUCCESS))
    m_new_event     = false;
    m_packet_length = 0;
    // Enable wake-up on event
    SCB->SCR |= SCB_SCR_SEVONPEND_Msk;
    return DTM_SUCCESS;
uint32_t dtm_wait(void)
    for (;;)
        // Event may be the reception of a packet -
        // handle radio first, to give it highest priority:
        if (NRF_RADIO->EVENTS_END != 0)
            NVIC_ClearPendingIRQ(RADIO_IRQn);
            if (m_state == STATE_RECEIVER_TEST)
                if ((NRF_RADIO->CRCSTATUS == 1) && check_pdu())
                    // Count the number of successfully received packets
                    m_rx_pkt_count++;
                // Note that failing packets are simply ignored (CRC or contents error).
                // Zero fill all pdu fields to avoid stray data
                memset(&m_pdu, 0, DTM_PDU_MAX_MEMORY_SIZE);
            // If no RECEIVER_TEST is running, ignore incoming packets (but do clear IRQ!)
        // Check for timeouts:
        if (mp_timer->EVENTS_COMPARE[0] != 0)
            m_tx_pkt_count++;
        else if (mp_timer->EVENTS_COMPARE[1] != 0)
            // Reset timeout event flag for next iteration.
            NVIC_ClearPendingIRQ(m_timer_irq);
            return ++m_current_time;
        // Other events: No processing
uint32_t dtm_cmd(dtm_cmd_t cmd, dtm_freq_t freq, uint32_t length, dtm_pkt_type_t payload)
    // Save specified packet in static variable for tx/rx functions to use.
    // Note that BLE conformance testers always use full length packets.
    m_packet_length = (m_packet_length & 0xC0) | ((uint8_t)length & 0x3F);
    m_packet_type   = payload;
    m_phys_ch       = freq;
    // If 1 Mbit or 2 Mbit radio mode is in use check for Vendor Specific payload.
    if ((m_radio_mode == RADIO_MODE_MODE_Ble_1Mbit || m_radio_mode == RADIO_MODE_MODE_Ble_2Mbit) && payload == DTM_PKT_VENDORSPECIFIC)
        /* Note that in a HCI adaption layer, as well as in the DTM PDU format,
           the value 0x03 is a distinct bit pattern (PRBS15). Even though BLE does not
           support PRBS15, this implementation re-maps 0x03 to DTM_PKT_VENDORSPECIFIC,
           to avoid the risk of confusion, should the code be extended to greater coverage.
        m_packet_type = DTM_PKT_TYPE_VENDORSPECIFIC;
    // Clean out any non-retrieved event that might linger from an earlier test
    m_new_event     = true;
    // Set default event; any error will set it to LE_TEST_STATUS_EVENT_ERROR
    m_event         = LE_TEST_STATUS_EVENT_SUCCESS;
    if (m_state == STATE_UNINITIALIZED)
        // Application has not explicitly initialized DTM,
        return DTM_ERROR_UNINITIALIZED;
    if (cmd == LE_TEST_SETUP)
        // Note that timer will continue running after a reset
        dtm_test_done();
        if (freq == LE_TEST_SETUP_RESET)
            if (length != 0x00)
            // Reset the packet length upper bits.
            // Reset the selected PHY to 1Mbit
            // Workaround for Errata ID 164
            *(volatile uint32_t *)0x4000173C &= ~0x80000000;
        else if (freq == LE_TEST_SETUP_SET_UPPER)
            if (length > 0x03)
            m_packet_length = length << 6;
        else if (freq == LE_TEST_SETUP_SET_PHY)
            switch (length)
                case LE_PHY_1M:
                    return radio_init();
                case LE_PHY_2M:
                    m_radio_mode        = RADIO_MODE_MODE_Ble_2Mbit;
                    m_packetHeaderPlen  = RADIO_PCNF0_PLEN_16bit;
                case LE_PHY_LE_CODED_S8:
                    m_radio_mode        = RADIO_MODE_MODE_Ble_LR125Kbit;
                    m_packetHeaderPlen  = RADIO_PCNF0_PLEN_LongRange;
                    *(volatile uint32_t *)0x4000173C |= 0x80000000;
                    *(volatile uint32_t *)0x4000173C = ((*(volatile uint32_t *)0x4000173C & 0xFFFFFF00) | 0x5C);
#else
#endif // NRF52840_XXAA
                case LE_PHY_LE_CODED_S2:
                    m_radio_mode        = RADIO_MODE_MODE_Ble_LR500Kbit;
#else
        else if(freq == LE_TEST_SETUP_SELECT_MODULATION)
            if (length > 0x01)
            // Only standard modulation is supported.
        else if (freq == LE_TEST_SETUP_READ_SUPPORTED)
            if (length != 0x00)
            // 0XXXXXXXXXXX0110 indicate that 2Mbit and DLE is supported and stable modulation is not supported (No nRF5 device supports this).
            m_event = 0x0006;
        else if (freq == LE_TEST_SETUP_READ_MAX)
            // Read max supported value.
            switch (length)
                case 0x00:
                    // Read supportedMaxTxOctets
                    m_event = 0x01FE;
                case 0x01:
                    // Read supportedMaxTxTime
                    m_event = 0x4290;
                case 0x02:
                    // Read supportedMaxRxOctets
                    m_event = 0x01FE;
                case 0x03:
                    // Read supportedMaxRxTime
                    m_event = 0x4290;
        return DTM_SUCCESS;
    if (cmd == LE_TEST_END)
        state_t current_state = m_state;
        if (m_state == STATE_IDLE)
            // Sequencing error - only rx or tx test may be ended!
            return DTM_ERROR_INVALID_STATE;
        dtm_test_done();
        switch(current_state)
            case STATE_TRANSMITTER_TEST:
                m_event = LE_PACKET_REPORTING_EVENT | m_tx_pkt_count;
                m_event = LE_PACKET_REPORTING_EVENT | m_rx_pkt_count;
        return DTM_SUCCESS;
    if (m_state != STATE_IDLE)
        // Sequencing error - only TEST_END/RESET are legal while test is running
        // Note: State is unchanged; ongoing test not affected
    // Check for illegal values of m_phys_ch. Skip the check if the packet is vendor spesific.
    if (payload != DTM_PKT_VENDORSPECIFIC && m_phys_ch > PHYS_CH_MAX)
        // Parameter error
        return DTM_ERROR_ILLEGAL_CHANNEL;
    m_rx_pkt_count = 0;
    m_tx_pkt_count = 0;
    if (cmd == LE_RECEIVER_TEST)
        // Zero fill all pdu fields to avoid stray data from earlier test run
        radio_prepare(RX_MODE);                      // Reinitialize "everything"; RF interrupts OFF
        m_state = STATE_RECEIVER_TEST;
        return DTM_SUCCESS;
    if (cmd == LE_TRANSMITTER_TEST)
        // Check for illegal values of m_packet_length. Skip the check if the packet is vendor spesific.
        if (m_packet_type != DTM_PKT_TYPE_VENDORSPECIFIC && m_packet_length > DTM_PAYLOAD_MAX_SIZE)
            // Parameter error
            return DTM_ERROR_ILLEGAL_LENGTH;
        m_pdu.content[DTM_LENGTH_OFFSET] = m_packet_length;
        // Note that PDU uses 4 bits even though BLE DTM uses only 2 (the HCI SDU uses all 4)
        switch (m_packet_type)
            case DTM_PKT_PRBS9:
                m_pdu.content[DTM_HEADER_OFFSET] = DTM_PDU_TYPE_PRBS9;
                // Non-repeated, must copy entire pattern to PDU
                memcpy(m_pdu.content + DTM_HEADER_SIZE, m_prbs_content, m_packet_length);
            case DTM_PKT_0X0F:
                m_pdu.content[DTM_HEADER_OFFSET] = DTM_PDU_TYPE_0X0F;
                // Bit pattern 00001111 repeated
                memset(m_pdu.content + DTM_HEADER_SIZE, RFPHY_TEST_0X0F_REF_PATTERN, m_packet_length);
            case DTM_PKT_0X55:
                m_pdu.content[DTM_HEADER_OFFSET] = DTM_PDU_TYPE_0X55;
                // Bit pattern 01010101 repeated
                memset(m_pdu.content + DTM_HEADER_SIZE, RFPHY_TEST_0X55_REF_PATTERN, m_packet_length);
            case DTM_PKT_0XFF:
                m_pdu.content[DTM_HEADER_OFFSET] = DTM_PDU_TYPE_0XFF;
                // Bit pattern 11111111 repeated. Only available in coded PHY (Long range).
                memset(m_pdu.content + DTM_HEADER_SIZE, RFPHY_TEST_0XFF_REF_PATTERN, m_packet_length);
            case DTM_PKT_TYPE_VENDORSPECIFIC:
                // The length field is for indicating the vendor specific command to execute.
                // The frequency field is used for vendor specific options to the command.
                return dtm_vendor_specific_pkt(length, freq);
                // Parameter error
        // Initialize CRC value, set channel:
        // Set the timer to the correct period. The delay between each packet is described in the
        // Bluetooth Core Spsification version 4.2 Vol. 6 Part F Section 4.1.6.
        mp_timer->CC[0] = dtm_packet_interval_calculate(m_packet_length, m_radio_mode);
        // Configure PPI so that timer will activate radio every 625 us
        NRF_PPI->CH[0].EEP = (uint32_t)&mp_timer->EVENTS_COMPARE[0];
        NRF_PPI->CH[0].TEP = (uint32_t)&NRF_RADIO->TASKS_TXEN;
        NRF_PPI->CHENSET   = 0x01;
        m_state            = STATE_TRANSMITTER_TEST;
    return DTM_SUCCESS;
bool dtm_event_get(dtm_event_t *p_dtm_event)
    bool was_new = m_new_event;
    // mark the current event as retrieved
    *p_dtm_event = m_event;
    // return value indicates whether this value was already retrieved.
    return was_new;
// Configuration functions (only for parameters not definitely determined by the BLE DTM standard).
// These functions return true if successful, false if value could not be set
/**@brief Function for configuring the output power for transmitter test.
          This function may be called directly, or through dtm_cmd() specifying
          DTM_PKT_VENDORSPECIFIC as payload, SET_TX_POWER as length, and the dBm value as frequency.
bool dtm_set_txpower(uint32_t new_tx_power)
    // radio->TXPOWER register is 32 bits, low octet a signed value, upper 24 bits zeroed
    int8_t new_power8 = (int8_t)(new_tx_power & 0xFF);
    // The two most significant bits are not sent in the 6 bit field of the DTM command.
    // These two bits are 1's if and only if the tx_power is a negative number.
    // All valid negative values have the fourth most significant bit as 1.
    // All valid positive values have the fourth most significant bit as 0.
    // By checking this bit, the two most significant bits can be determined.
    new_power8 = (new_power8 & 0x30) != 0 ? (new_power8 | 0xC0) : new_power8;
    if (m_state > STATE_IDLE)
        // radio must be idle to change the tx power
        return false;
    m_tx_power = new_power8;
    return true;
/**@brief Function for selecting a timer resource.
 *        This function may be called directly, or through dtm_cmd() specifying
 *        DTM_PKT_VENDORSPECIFIC as payload, SELECT_TIMER as length, and the timer as freq
 * @param[in] new_timer     Timer id for the timer to use: 0, 1, or 2.
 * @return true if the timer was successfully changed, false otherwise.
bool dtm_set_timer(uint32_t new_timer)
        return false;
    return dtm_hw_set_timer(&mp_timer, &m_timer_irq, new_timer);
#endif // NRF_MODULE_ENABLED(BLE_DTM)
# Copyright (c) 2013 Nordic Semiconductor. All Rights Reserved.
# The information contained herein is property of Nordic Semiconductor ASA.
# Terms and conditions of usage are described in detail in NORDIC
# SEMICONDUCTOR STANDARD SOFTWARE LICENSE AGREEMENT.
# Licensees are granted free, non-transferable use of the information. NO
# WARRANTY of ANY KIND is provided. This heading must NOT be removed from
# the file.
import sys, os, serial, time
PRBS9				= 0
FOUR_ONE_FOUR_ZERO	= 1
ONE_ZERO			= 2
CONSTANT_CARRIER	= 3
LE_RESET			= 0
LE_RECEIVER_TEST	= 1
LE_TRANSMITTER_TEST = 2
LE_TEST_END			= 3
LE_TEST_STATUS_EVENT	  = 0
LE_PACKET_REPORTING_EVENT = 1
STATUS_SUCCESS	= 0
STATUS_ERROR	= 1
class DTMError(Exception):
	def __init__(self, testname, operation, message):
		self.testname = testname
		self.operation = operation
		self.message = message
	def errormessage(self):
		return "%s %s %s" % (self.testname, self.operation, self.message)
class ConnectionError(DTMError):
	pass
class MessageError(DTMError):
	pass
class PERError(DTMError):
	pass
class DTM(object):
	def __init__(self, setup):
		self.txportname = setup['TestSerialPortName']
		self.rxportname = setup['GoldenSerialPortName']
		self.frequency = setup['Frequency']
		self.bytepattern = setup['Bitpattern']
		self.length = setup['Length']
		self.runtimeinms = setup['Runtime']
		self.debug = setup.get('debug', False)
		self.perlimit = setup.get('PERLimit', 30)
		self.teststartdelay = setup.get('TestPause', 0)
		self.baudrate = 19200
		self.parity = serial.PARITY_NONE
		self.stopbits = serial.STOPBITS_ONE
		self.bytesize = serial.EIGHTBITS
		self.txper = "N/A"
		self.rxper = "N/A"
		self.txserialport = 0
		self.rxserialport = 0
	def __del__(self):
		self._disconnect(self.txserialport)
		self._disconnect(self.rxserialport)
	def _debug(self, printmessage):
		if self.debug:
			print printmessage
	def _connect(self, portname):
		"""Sets up and connects a serialport"""
		self._debug ("Connect to port: " + portname)
		try:
			port = serial.serial_for_url(portname, baudrate = self.baudrate, parity=self.parity, bytesize=self.bytesize, stopbits=self.stopbits, timeout=1)
		except serial.SerialException as error:
			raise ConnectionError (self._testname, "Connect", "Serialport error " + error.message)
		return (port)
	def _disconnect(self, serialport):
		"""Disconnects a serialport"""
		if isinstance (serialport, serial.Serial):
			serialport.close()
	def _startTX(self):
		"""Starts the Transmitter part of the test"""
		self._debug ("Start TX")
		self._debug ("Com port: " + self.txportname)
		self.txserialport = self._connect(self.txportname)
		self._reset(self.txserialport, "TX")
		self._sendCommand(self.txserialport, LE_TRANSMITTER_TEST, self.frequency, self.length, self.bytepattern, "TX start")
		self._receiveEvent(self.txserialport, "TX start")
	def _stopTX(self):
		"""Stops the Transmitter part of the test"""
		self._sendCommand(self.txserialport, LE_TEST_END, 0, 0, 0, "TX end")
		data = self._receiveEvent(self.txserialport, "TX end")
		return (data)
	def _runRX(self):
		"""Runs the RX part of the test and returns the number of received packages"""
		self._debug("Start RX")
		self._debug("Com port: " + self.rxportname)
		self.rxserialport = self._connect(self.rxportname)
		self._reset(self.rxserialport, "RX")
		self._startTimer()
		self._sendCommand(self.rxserialport, LE_RECEIVER_TEST, self.frequency, self.length, self.bytepattern, "RX start")
		self._receiveEvent(self.rxserialport, "RX start")
		while not self._timedOut(self.endtime):
			pass
		self._sendCommand(self.rxserialport, LE_TEST_END, 0, 0, 0, "RX end")
		data = self._receiveEvent(self.rxserialport, "RX end")
		return (data)
	def _calculateTimeForPackage (self):
		"""Calculate how long time from start of one package to the start of next"""
		return 0.625
	def _calculatePER(self, receivedPackages):
		"""Calculates the PER"""
		maxpackages = int (round(self.runtimeinms / self._calculateTimeForPackage ()))
		lostpackages = maxpackages - receivedPackages
		lostpackages = max(0, lostpackages)
		self._debug("Received: %s Max: %s Lost: %s" % (receivedPackages, maxpackages, lostpackages))
		per = int (round((float(lostpackages) / float(maxpackages)) * 100))
		return per
	def _reset(self, serialport, printmessage):
		"""Resets a connection"""
		self._sendCommand(serialport, LE_RESET, 0, 0, PRBS9, "Reset " + printmessage)
		self._receiveEvent(serialport, "Reset " + printmessage)
	def _sendCommand(self, serialport, commandtype, data1, data2, packettype, printmessage=""):
		"""Sends a package.
		Parameters:
			* serialport - the port to send on
			* commandtype - contents of upper 2 bits of MSByte - one of LE_RESET, LE_RECEIVER_TEST, LE_TRANSMITTER_TEST, LE_TEST_END
			* data1 - contents of lower 6 bits of MSByte
			* data2 - contents of upper 6 bits of LSByte
			* packettype - contents of lower 2 bits of LSByte - one of PRBS9, FOUR_ONE_FOUR_ZERO, ONE_ZERO, CONSTANT_CARRIER"""
		serialport.flushInput()
		self._debug("Sending command " + printmessage)
		data1 = data1 + (commandtype << 6)
		data2 = (data2 << 2) + packettype
		self._debug("1: %s %s %s 2: %s %s %s" % (data1, bin(data1), chr(data1), data2, bin(data2), chr(data2)))
		command = chr(data1) + chr(data2)
		self._debug("Command: %s Result: %s" % (command, serialport.write(command)))
	def _receiveEvent(self, serialport, printmessage):
		"""Receives an event
		Parameters:
			* serialport - the port tp receive on
		Returns:
			For Receive test: the number of packages received
			For other: 0
		Will throw an exception if result is error"""
		self._debug("Receive event: " + printmessage)
		data = serialport.read(2)
		returndata = 0
		if len(data) < 2:
			raise ConnectionError(self._testname, printmessage, "Received less data than expected")
		self._debug("Bytes received: %s" % (len (data)))
		event = ord(data[0])
		event = event & 0x80
		event = event >> 7
		if event == LE_TEST_STATUS_EVENT:
			self._debug("Status event")
			statusbyte = ord(data[1])
			returndata = statusbyte & 0x01
			if (not returndata == 0):
				raise MessageError(self._testname, printmessage, "Event Error")
		else:
			self._debug("other event")
			packetcountMSByte = ord(data[0])
			packetcountMSByte = packetcountMSByte & 0x7F
			packetcountMSByte = packetcountMSByte << 8
			packetcountLSByte = ord(data[1])
			returndata = packetcountMSByte + packetcountLSByte
		self._debug(returndata)
		return returndata
	def _getms(self):
		"""Get current number of ms since epoch"""
		millis = int(round(time.time() * 1000))
		return millis
	def _startTimer(self):
		"""Gets current time and sets the appropriate endtime"""
		self.timestarted = self._getms()
		self.endtime = self.timestarted + self.runtimeinms
	def _timedOut(self, endtime):
		"""Checks if timer has run out"""
		currentMs = self._getms()
		isTimedOut = endtime < currentMs
		return (isTimedOut)
	def _delay(self):
		"""Inserts a short delay"""
		delaystarted = self._getms()
		delayend = delaystarted + self.teststartdelay
		while not self._timedOut(delayend):
			pass
	def runTest(self):
		"""Runs the test"""
		self._startTX()
		receivedPackages = self._runRX()
		self._stopTX()
		per = self._calculatePER(receivedPackages)
		if per > self.perlimit:
			raise PERError(self._testname, "", "Packeterrorrate to high at %s%%" % (per))
		return per
	def runTransmitterTest(self):
		"""Runs transmitter tests"""
		self._testname = "Transmitter test"
		self._delay ()
		self.txper = self.runTest()
		return self.txper
	def runReceiverTest(self):
		"""Runs receiver tests"""
		originalTXPortname = self.txportname
		originalRXPortname = self.rxportname
		self.txportname = originalRXPortname
		self.rxportname = originalTXPortname
		self._testname = "Receiver test"
		self._delay ()
		self.rxper = self.runTest()
		self.txportname = originalTXPortname
		self.rxportname = originalRXPortname
		return self.rxper
	def runBothRXandTXTests(self):
		"""Runs tests first in normal defined order (DUT as TX, Golden as RX). Then runs in reversed order (DUT as RX, Golden as TX)"""
		self.runTransmitterTest()
		self.runReceiverTest()
	def startRX(self):
		self._startTimer()
	def stopRX(self):
		return (data)
	def runCustomTest(self):
		self.startRX()
		self._startTX()
		self._startTimer()
			pass
		txcnt = (self._stopTX() - 1)
		rxcnt = self.stopRX()
		return (txcnt, rxcnt)
	def runTestTxCustom(self):
		return self.runCustomTest()
	def runTestRxCustom(self):
		cnt = self.runCustomTest()
		return cnt
# the file.
import dtm
def main():
	#General setup
	setup = dict ()
	setup['TestSerialPortName'] = "COM9"			#DUT (Device Under Test)
	setup['GoldenSerialPortName'] = "COM5"			#Golden sample
	setup['Frequency'] = 1							#Frequency the test should be run on
	setup['Bitpattern'] = dtm.FOUR_ONE_FOUR_ZERO	#The bit pattern used for the test. PRBS9, 11110000 (FOUR_ONE_FOUR_ZERO), 10101010 (ONE_ZERO), CONSTANT_CARRIER
	setup['Length'] = 10							#Length of the test package
	setup['Runtime'] = 100							#How long the Receiver should be receiving. In ms
	setup['PERLimit'] = 100							#The packet error limit in percent. Default 30
	#Run tests on a series of channels
	channels = [37, 17, 39]
	for channel in channels:
		print "\nChannel %s" % channel
		setup['Frequency'] = channel
		dtmObject = dtm.DTM(setup)
		try:
			cnt = dtmObject.runTestTxCustom()
			print "TX:%s\tRX:%s" % cnt
			print "Lost:%s" % (cnt[0] - cnt[1])
			cnt = dtmObject.runTestRxCustom()
			print "\nTX:%s\tRX:%s" % cnt
		except dtm.DTMError as error:
			print error.errormessage()
		del dtmObject
if __name__ == '__main__':
	main()
    It depends on the environment, if you have nearby WiFI, BT, og other 2.4GHz noise (e.g. USB3.0, microwave oven), then yes, you can experience packet loss due to interference.
    Kenneth
  • Hi Kenneth,
    Thanks for your answer.
    I knew that this could be a reason for such loss, but I thought that there was no notable noise source in my test environment (some WIFI, some BT, but nothing to close or intensive).
    I was probably wrong since the same tests today give wonderful results. There was probably some unsuspected active noise source yesterday. I'll investigate further if the problem occurs again.
    Thanks again for your help and sorry for the trouble.
    Mehdi
  • Hi Mehdi
    I hope you are good. I have a question that in ¨peripheral/radio example¨ how you manage to get numbers of packet loss.
    I want to know that what are the modifications you did in the codes.
    thanks
  • Hi usman,
    I'm good thanks, and I hope you too.
    I think I copied the code to send/read packets from another example (maybe the DTM) and added them to the radio_test example (in an ugly blocking way...). Be careful to reconfigure the radio according to the mode you want to use.
    You'll find enclosed the extract from a patch that should let you know what to do. Be aware that this was done with SDK 14.2.0 and should be modified further for it to fully work with nRF52810 and nRF52840 (that have more/different features and use different preprocessor symbol for example...).
    Let me know if anything is unclear,
    Mehdi
    /examples/peripheral/radio_test/main.c
    @@ -58,6 +58,7 @@
     #include "app_uart.h"
     #include "app_error.h"
     #include "nordic_common.h"
    +#include "radio_config.h"
    +static void send_packet(uint32_t pckt)
    +    static uint32_t _packet = 0;
    +    _packet = pckt;
    +    NRF_RADIO->PACKETPTR = (uint32_t)&_packet;
    +    // send the packet:
    +    NRF_RADIO->EVENTS_READY = 0U;
    +    NRF_RADIO->TASKS_TXEN   = 1;
    +    while (NRF_RADIO->EVENTS_READY == 0U)
    +        // wait
    +    NRF_RADIO->EVENTS_END  = 0U;
    +    NRF_RADIO->TASKS_START = 1U;
    +    while (NRF_RADIO->EVENTS_END == 0U)
    +        // wait
    +    NRF_RADIO->EVENTS_DISABLED = 0U;
    +    // Disable radio
    +    NRF_RADIO->TASKS_DISABLE = 1U;
    +    while (NRF_RADIO->EVENTS_DISABLED == 0U)
    +        // wait
    +static uint32_t read_packet(bool *abort)
    +    (*abort) = false;
    +    uint32_t result = 0;
    +    // Enable radio and wait for ready
    +    NRF_RADIO->TASKS_RXEN = 1U;
    +        // wait
    +    // Start listening and wait for address received event
    +    // Wait for end of packet or buttons state changed
    +        // wait
    +        uint8_t tmp;
    +        if(app_uart_get(&tmp) == NRF_SUCCESS)
    +            (*abort) = true;
    +            break;
    +    if (NRF_RADIO->CRCSTATUS == 1U)
    +        result = _packet;
    +    // Disable radio
    +        // wait
    +    return result;
     /** @brief Function for main application entry.
    @@ -323,7 +406,11 @@ int main(void)
                 case 'h':
                     help();
    +            case 'n':
    +                radio_disable();
    +                radio_configure();
    +                NRF_RADIO->TXPOWER   = (txpower_ << RADIO_TXPOWER_TXPOWER_Pos);
    +                NRF_RADIO->FREQUENCY = channel_start_;
    +                NRF_RADIO->MODE      = (mode_ << RADIO_MODE_MODE_Pos);
    +                printf("Packet count TX started\r\n");
    +                    uint16_t i;
    +                    for(i = 0; i < 100; i++)
    +                        send_packet(i);
    +                    printf("Sent %d packets\r\n", i);
    +                break;
    +            case 'j':
    +                radio_disable();
    +                printf("Packet count RX started\r\n");
    +                    uint32_t tmp = 0;
    +                    bool abort = false;
    +                    while(!abort)
    +                        read_packet(&abort);
    +                        if(!abort)
    +                            tmp++;
    +                    printf("Received %d packets\r\n", tmp);
    +                break;
                     // No implementation needed
    @@ -145,7 +145,7 @@ static void generate_modulated_rf_packet(void)
    -static void radio_disable(void)
    +void radio_disable(void)
    diff --git a/examples/peripheral/radio_test/radio_test.h b/examples/peripheral/radio_test/radio_test.h
    index 9f3150d..e29b44f 100644
    --- a/examples/peripheral/radio_test/radio_test.h
    +++ b/examples/peripheral/radio_test/radio_test.h
    @@ -47,6 +47,7 @@ extern "C" {
    +void radio_disable(void);
     void radio_tx_carrier(uint8_t txpower, uint8_t mode, uint8_t channel);
     void radio_modulated_tx_carrier(uint8_t txpower, uint8_t mode, uint8_t channel);
     void radio_rx_carrier(uint8_t mode, uint8_t channel);
