DevBoard as SWD-Programmer for external Hardware -> no target found
Hello all,
I'm trying to connect to custom Board with nRF52840 controler.
nRFgo Studio (V:1.21.2.10) gives error "No device detected, or readback...".
I've also tried several command line interfaces (Nordic and Segger) with reduced speed and stuff. Everything with similar errors: "no target found"-kind.
The Device is running firmware which was flashed with another SWD-programmer, so the nRF52 is not broken, also it's proven that the custom PCB can do it.
I'm using a nRF52840-DK as SWD-Interface: motherboard FW version 7000,  hardware version 1.0.0 2018-33
I'm fairly sure all the connections are correct. (checked 20 times with 6 eyes, and compared with a running setup, also cross checked what is possible, tried two different targets)
I use P20 header with jumper cables . Ground and VDD are connected to the Arduino Pins of the DevBoard
I already added some pull-up/down resisitors as sugested here:
https://devzone.nordicsemi.com/f/nordic-q-a/4775/custom-nrf51822-board-not-showing-in-nrfgo
I sniffed the SWD traffic during nRFgo startup (with Saleae-Logic)  and got something like this:
Time    Type    R/W    AP/DP    Register    Request byte    ACK    WData    WData details
...snip...
4.73813150    Line reset
4.73821050    Operation    read    DebugPort    IDCODE    '165'    OK    '731911287'    DESIGNER='1143', PARTNO='47617', Version='2'
4.73882925    Line reset
4.73890500    Operation    read    DebugPort    IDCODE    '165'    OK    '731911287'    DESIGNER='1143', PARTNO='47617', Version='2'
4.78997875    Line reset
4.79005125    Line reset
4.79012700    Line reset
4.79020600    Operation    read    DebugPort    IDCODE    '165'    OK    '731911287'    DESIGNER='1143', PARTNO='47617', Version='2'
4.79105175    Line reset
4.79112775    Operation    read    DebugPort    IDCODE    '165'    OK    '731911287'    DESIGNER='1143', PARTNO='47617', Version='2'
4.89534500    Operation    read    DebugPort    CTRL/STAT    '141'    OK    '0'    CSYSPWRUPACK=0, CSYSPWRUPREQ=0, CDBGPWRUPACK=0, CDBGPWRUPREQ=0, CDBGRSTACK=0, CDBGRSTREQ=0, TRNCNT='0', MASKLANE='0', WDATAERR=0, READOK=0, STICKYERR=0, STICKYCMP=0, TRNMODE=Normal, STICKYORUN=0, ORUNDETECT=0
4.89591400    Operation    write    DebugPort    ABORT    '129'    OK    '2381717929'    ORUNERRCLR=0, WDERRCLR=1, STKERRCLR=0, STKCMPCLR=0, DAPABORT=1
4.89740550    Operation    write    DebugPort    ABORT    '129'    FAULT
4.89930000    Line reset
...snip... (I could add the whole trace if it's useful?)
This is much different from what I get if I sniff the traffic without a connected device, so I guess the external nRF52 is responding. Also it's almost identical every time I run the target detection.
Any clues what's wrong?
Regards and thanks in advance
Ben
