Lost ncs/nrf/lib/gps_sim folder after latest update in the nRF9160 master branch
I wanted to get Simple MQTT example and followed Case ID: 222137
Hi! I just saw the MQTT example that has been merged in the master branch and tried to run it on my DK (NB-IoT). Without changing anything in the code or configuration the execution leads to the following…
By in Nordic DevZone > Nordic Q&A
I followed Martin Lesund's suggestion to get the latest updates in the master branch to nrf.  I am using Windows 10 and MINGW64:c/nRF91/ncs
master upgrade log.txt
I encountered two problems. My first problem is :
Since I made some changes in Kconfig and gps_sim.c files, I got the following messages when I updated to master branch;  please see lines 1887 to 1890 in the attached file.
error: Your local changes to the following files would be overwritten by checkout:
        lib/gps_sim/Kconfig
        lib/gps_sim/gps_sim.c
Please commit your changes or stash them before you switch branches.
Aborting
After I completed the master branch updates, I lost the ncs/nrf/lib/gps_sim folder completely
Without the gps_sim folder, can I still run asset_tracker and lte_ble_gateway samples?
Did I mess up somethings?  Please advise.
  • Please see item 7) above, I already used command line tools to build mqtt_simple sample and have CMake error.  Please let me know how to fix CMake error.  In additional, I need your guidance on how to successfully build and run this mqtt_simple sample, not just fixing one problem at a time that will take forever to get one sample work.
    P.S. I assumed your command line tools referred to the black window - Command Prompt on item 7) above, otherwise please let me know what is command line tools.
     You need to be in the "build" directory to run the command you are using. ".." is referring to the parent directory "mqtt_simple", which contains CMakeLists.txt.
    To build it, run "Ninja" from the build directory.
    To flash the application to your device, run "nrfjprog --program zephyr.hex -f nrf91 --sectorerase -r --verify" from "mqtt_simple\build\zephyr", or simply "Ninja flash".
