I am trying to implement LESC Security Mode 1 Level 4 with a peripheral ble_app_hrs on PCA10040 and a central via pc-ble-driver example heart_rate_collector_v6 with PCA10059.
I am following MSC Bonding: Passkey Entry: User Inputs on Central
My first step is to add sd_ble_gap_authenticate when BLE_GAP_EVT_CONNECTED comes. I have not yet implemented the full bonding sequences.
However, the call of sd_ble_gap_authenticate returns with 0x4
* @retval ::NRF_ERROR_NO_MEM The maximum number of authentication procedures that can run in parallel for the given role is reached.
I am running everything under Ubuntu 18.04.
Peripheral ble_app_hrs is modified based on nRF5_SDK_15.2.0_9412b96 with a little change:
//ble_srv_common.h
/**@brief Security Access enumeration.
* @details This enumeration gives the possible requirements for accessing a characteristic value.
typedef enum
SEC_NO_ACCESS = 0, /**< Not possible to access. */
SEC_OPEN = 1, /**< Access open. */
SEC_JUST_WORKS = 2, /**< Access possible with 'Just Works' security at least. */
SEC_MITM = 3, /**< Access possible with 'MITM' security at least. */
SEC_SIGNED = 4, /**< Access possible with 'signed' security at least. */
SEC_SIGNED_MITM = 5, /**< Access possible with 'signed and MITM' security at least. */
SEC_LESC_MITM = 6 /**< SM1 Level4. */
}security_req_t;
//ble_srv_common.c
/**@brief Function for setting security requirements of a characteristic.
* @param[in] level required security level.
* @param[out] p_perm Characteristic security requirements.
* @return encoded security level and security mode.
static inline void set_security_req(security_req_t level, ble_gap_conn_sec_mode_t * p_perm)
BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(p_perm);
switch (level)
case SEC_NO_ACCESS:
case SEC_OPEN:
BLE_GAP_CONN_SEC_MODE_SET_OPEN(p_perm);
case SEC_JUST_WORKS:
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(p_perm);
case SEC_MITM:
BLE_GAP_CONN_SEC_MODE_SET_ENC_WITH_MITM(p_perm);
case SEC_SIGNED:
BLE_GAP_CONN_SEC_MODE_SET_SIGNED_NO_MITM(p_perm);
case SEC_SIGNED_MITM:
BLE_GAP_CONN_SEC_MODE_SET_SIGNED_WITH_MITM(p_perm);
case SEC_LESC_MITM:
BLE_GAP_CONN_SEC_MODE_SET_LESC_ENC_WITH_MITM(p_perm);
return;
//ble_app_hrs peripheral main.c
#define SEC_PARAM_BOND 1 /**< Perform bonding. */
#define SEC_PARAM_MITM 1 /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC 1 /**< LE Secure Connections enabled. */
#define SEC_PARAM_KEYPRESS 0 /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_DISPLAY_ONLY /**< Display Only. */
#define SEC_PARAM_OOB 0 /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE 7 /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE 16 /**< Maximum encryption key size. */
// Here the sec level for the Heart Rate Service can be changed/increased.
hrs_init.hrm_cccd_wr_sec = SEC_LESC_MITM;
hrs_init.bsl_rd_sec = SEC_LESC_MITM;
Central pc-ble-driver example is modified based on "2019-03-06 08:55 Ken A. Redergård o [master] {origin/HEAD} {origin/master} Support parallel compilation of connectivity (#216)
" (ac78577589550c5757f1095b3380eec1d521976b):
The connectivity firmware for PCA10059 is compiled from source: connectivity_<ver>_usb_with_s140_6.1.0.hex
diff --git a/examples/heart_rate_collector/main.c b/examples/heart_rate_collector/main.c
index 3ee6c9c..d265726 100644
--- a/examples/heart_rate_collector/main.c
+++ b/examples/heart_rate_collector/main.c
@@ -104,6 +104,15 @@ enum
#define STRING_BUFFER_SIZE 50
+#define SEC_PARAM_BOND 1 /**< Perform bonding. */
+#define SEC_PARAM_MITM 1 /**< Man In The Middle protection not required. */
+#define SEC_PARAM_LESC 1 /**< LE Secure Connections enabled. */
+#define SEC_PARAM_KEYPRESS 0 /**< Keypress notifications not enabled. */
+#define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_KEYBOARD_DISPLAY /**< No I/O capabilities. */
+#define SEC_PARAM_OOB 0 /**< Out Of Band data not available. */
+#define SEC_PARAM_MIN_KEY_SIZE 7 /**< Minimum encryption key size. */
+#define SEC_PARAM_MAX_KEY_SIZE 16 /**< Maximum encryption key size. */
typedef struct
uint8_t * p_data; /**< Pointer to data. */
@@ -608,7 +617,26 @@ static void on_connected(const ble_gap_evt_t * const p_ble_gap_evt)
m_connection_handle = p_ble_gap_evt->conn_handle;
m_connection_is_in_progress = false;
- service_discovery_start();
+ ble_gap_sec_params_t m_sec_params; /**< Security requirements for this application. */
+ memset(&m_sec_params, 0, sizeof(m_sec_params));
+ m_sec_params.bond = SEC_PARAM_BOND;
+ m_sec_params.mitm = SEC_PARAM_MITM;
+ m_sec_params.lesc = SEC_PARAM_LESC;
+ m_sec_params.keypress = SEC_PARAM_KEYPRESS;
+ m_sec_params.io_caps = SEC_PARAM_IO_CAPABILITIES;
+ m_sec_params.oob = SEC_PARAM_OOB;
+ m_sec_params.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
+ m_sec_params.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
+ uint32_t error_code = sd_ble_gap_authenticate(m_adapter, m_connection_handle, &m_sec_params);
+ if (error_code != NRF_SUCCESS)
+ printf("sd_ble_gap_authenticate failed with error code: 0x%04X\n", error_code);
+ } else
+ printf("sd_ble_gap_authenticate succeeded\n");
+ fflush(stdout);
/**@brief Function called on BLE_GAP_EVT_ADV_REPORT event.
@@ -854,6 +882,36 @@ static void on_hvx(const ble_gattc_evt_t * const p_ble_gattc_evt)
fflush(stdout);
+#if NRF_SD_BLE_API >= 5
+/**@brief Function called on BLE_GAP_EVT_DATA_LENGTH_UPDATE_REQUEST event.
+ * @details Data length update request
+ * @param[in] p_ble_gap_evt Data length update request Event.
+static void on_conn_data_length_update_request(const ble_gap_evt_t * const p_ble_gap_evt)
+ printf("BLE_GAP_EVT_DATA_LENGTH_UPDATE_REQUEST received: ");
+ ble_gap_data_length_params_t const dlp =
+ .max_rx_octets = 27, /* ref: NRF_SDH_BLE_GAP_DATA_LENGTH in sdk_config.h */
+ .max_tx_octets = 27, /* ref: NRF_SDH_BLE_GAP_DATA_LENGTH in sdk_config.h */
+ .max_rx_time_us = BLE_GAP_DATA_LENGTH_AUTO,
+ .max_tx_time_us = BLE_GAP_DATA_LENGTH_AUTO
+ ble_gap_data_length_limitation_t dll = { 0 };
+ uint32_t err_code = sd_ble_gap_data_length_update(m_adapter, m_connection_handle, &dlp, &dll);
+ if (err_code != NRF_SUCCESS)
+ printf("sd_ble_gap_data_length_update failed, err_code %d\n", err_code);
+ fflush(stdout);
+#endif
/**@brief Function called on BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST event.
* @details Update GAP connection parameters.
@@ -951,6 +1009,26 @@ static void ble_evt_dispatch(adapter_t * adapter, ble_evt_t * p_ble_evt)
on_timeout(&(p_ble_evt->evt.gap_evt));
+ case BLE_GAP_EVT_CONN_SEC_UPDATE:
+ printf("BLE_GAP_EVT_AUTH_STATUS: status=0x%x bond=0x%x lv4: %d kdist_own:0x%x kdist_peer:0x%x\n",
+ p_ble_evt->evt.gap_evt.params.auth_status.auth_status,
+ p_ble_evt->evt.gap_evt.params.auth_status.bonded,
+ p_ble_evt->evt.gap_evt.params.auth_status.sm1_levels.lv4,
+ *((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_own),
+ *((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_peer));
+ fflush(stdout);
+ if (p_ble_evt->evt.gap_evt.params.auth_status.auth_status == BLE_GAP_SEC_STATUS_SUCCESS)
+ service_discovery_start();
+ else
+ printf("Authorization failed with code: %u!\n",
+ p_ble_evt->evt.gap_evt.params.auth_status.auth_status);
+ fflush(stdout);
+ break;
case BLE_GATTC_EVT_PRIM_SRVC_DISC_RSP:
on_service_discovery_response(&(p_ble_evt->evt.gattc_evt));
@@ -971,6 +1049,20 @@ static void ble_evt_dispatch(adapter_t * adapter, ble_evt_t * p_ble_evt)
on_hvx(&(p_ble_evt->evt.gattc_evt));
+ case BLE_GAP_EVT_CONN_PARAM_UPDATE:
+ printf("Connection interval updated: 0x%x, 0x%x.\n",
+ p_ble_evt->evt.gap_evt.params.conn_param_update.conn_params.min_conn_interval,
+ p_ble_evt->evt.gap_evt.params.conn_param_update.conn_params.max_conn_interval);
+ fflush(stdout);
+ } break;
+ #if NRF_SD_BLE_API >= 5
+ case BLE_GAP_EVT_DATA_LENGTH_UPDATE_REQUEST:
+ on_conn_data_length_update_request(&(p_ble_evt->evt.gap_evt));
+ break;
+ #endif
case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
on_conn_params_update_request(&(p_ble_evt->evt.gap_evt));
@@ -1017,7 +1109,7 @@ int main(int argc, char * argv[])
fflush(stdout);
m_adapter = adapter_init(serial_port, baud_rate);
- sd_rpc_log_handler_severity_filter_set(m_adapter, SD_RPC_LOG_INFO);
+ sd_rpc_log_handler_severity_filter_set(m_adapter, SD_RPC_LOG_DEBUG);
error_code = sd_rpc_open(m_adapter, status_handler, ble_evt_dispatch, log_handler);
Detail error log:
$ ./heart_rate_collector_v6 /dev/ttyACM1 Serial port used: /dev/ttyACM1 Baud rate used: 1000000 Info: Successfully opened /dev/ttyACM1. Baud rate: 1000000. Flow control: none. Parity: none. Log: State change: STATE_START -> STATE_RESET Log: 1 -> [N/A] type: RESERVED_5 reliable: no seq#:0 ack#:0 payload_length:0 data_integrity:0 err_code:0x0 Status: 6, message: Target Reset performed Log: State change: STATE_RESET -> STATE_UNINITIALIZED Log: 2 -> [01 7e ] type: LINK_CONTROL_PACKET reliable: no seq#:0 ack#:0 payload_length:2 data_integrity:0 err_code:0x0 [SYNC] Log: 1/ 0 <- [02 7d ] type: LINK_CONTROL_PACKET reliable: no seq#:0 ack#:0 payload_length:2 data_integrity:0 err_code:0x0 [SYNC_RESP] Log: State change: STATE_UNINITIALIZED -> STATE_INITIALIZED Log: 3 -> [03 fc 11 ] type: LINK_CONTROL_PACKET reliable: no seq#:0 ack#:0 payload_length:3 data_integrity:0 err_code:0x0 [CONFIG [ sliding-window-size:1 out-of-frame:0 data-integrity-check-type:1 version-number:0 ]] Log: 4 -> [03 fc 11 ] type: LINK_CONTROL_PACKET reliable: no seq#:0 ack#:0 payload_length:3 data_integrity:0 err_code:0x0 [CONFIG [ sliding-window-size:1 out-of-frame:0 data-integrity-check-type:1 version-number:0 ]] Log: 5 -> [03 fc 11 ] type: LINK_CONTROL_PACKET reliable: no seq#:0 ack#:0 payload_length:3 data_integrity:0 err_code:0x0 [CONFIG [ sliding-window-size:1 out-of-frame:0 data-integrity-check-type:1 version-number:0 ]] Log: 6 -> [03 fc 11 ] type: LINK_CONTROL_PACKET reliable: no seq#:0 ack#:0 payload_length:3 data_integrity:0 err_code:0x0 [CONFIG [ sliding-window-size:1 out-of-frame:0 data-integrity-check-type:1 version-number:0 ]] Log: 2/ 0 <- [01 7e ] type: LINK_CONTROL_PACKET reliable: no seq#:0 ack#:0 payload_length:2 data_integrity:0 err_code:0x0 [SYNC] Log: 7 -> [02 7d ] type: LINK_CONTROL_PACKET reliable: no seq#:0 ack#:0 payload_length:2 data_integrity:0 err_code:0x0 [SYNC_RESP] Log: 8 -> [03 fc 11 ] type: LINK_CONTROL_PACKET reliable: no seq#:0 ack#:0 payload_length:3 data_integrity:0 err_code:0x0 [CONFIG [ sliding-window-size:1 out-of-frame:0 data-integrity-check-type:1 version-number:0 ]] Log: 3/ 0 <- [03 fc 11 ] type: LINK_CONTROL_PACKET reliable: no seq#:0 ack#:0 payload_length:3 data_integrity:0 err_code:0x0 [CONFIG [ sliding-window-size:1 out-of-frame:0 data-integrity-check-type:1 version-number:0 ]] Log: 9 -> [04 7b 11 ] type: LINK_CONTROL_PACKET reliable: no seq#:0 ack#:0 payload_length:3 data_integrity:0 err_code:0x0 [CONFIG_RESP [ sliding-window-size:1 out-of-frame:0 data-integrity-check-type:1 version-number:0 ]] Log: 10 -> [03 fc 11 ] type: LINK_CONTROL_PACKET reliable: no seq#:0 ack#:0 payload_length:3 data_integrity:0 err_code:0x0 [CONFIG [ sliding-window-size:1 out-of-frame:0 data-integrity-check-type:1 version-number:0 ]] Log: 4/ 0 <- [04 7b 11 ] type: LINK_CONTROL_PACKET reliable: no seq#:0 ack#:0 payload_length:3 data_integrity:0 err_code:0x0 [CONFIG_RESP [ sliding-window-size:1 out-of-frame:0 data-integrity-check-type:1 version-number:0 ]] Log: State change: STATE_INITIALIZED -> STATE_ACTIVE Status: 7, message: Connection active Log: 11 -> [00 69 40 00 00 00 01 00 01 00 01 00 ] type: VENDOR_SPECIFIC reliable:yes seq#:0 ack#:0 payload_length:c data_integrity:1 header_checksum:72 err_code:0x0 Log: 5/ 0 <- [N/A] type: ACK reliable: no seq#:0 ack#:1 payload_length:0 data_integrity:0 err_code:0x0 Log: 6/ 0 <- [01 69 00 00 00 00 ] type: VENDOR_SPECIFIC reliable:yes seq#:0 ack#:1 payload_length:6 data_integrity:1 header_checksum:ca err_code:0x0 Log: 12 -> [N/A] type: ACK reliable: no seq#:0 ack#:1 payload_length:0 data_integrity:0 err_code:0x0 Log: 13 -> [00 69 23 00 00 00 01 01 96 00 ] type: VENDOR_SPECIFIC reliable:yes seq#:1 ack#:1 payload_length:a data_integrity:1 header_checksum:89 err_code:0x0 Log: 7/ 0 <- [N/A] type: ACK reliable: no seq#:0 ack#:2 payload_length:0 data_integrity:0 err_code:0x0 Log: 8/ 0 <- [01 69 00 00 00 00 ] type: VENDOR_SPECIFIC reliable:yes seq#:1 ack#:2 payload_length:6 data_integrity:1 header_checksum:c1 err_code:0x0 Log: 14 -> [N/A] type: ACK reliable: no seq#:0 ack#:2 payload_length:0 data_integrity:0 err_code:0x0 Log: 15 -> [00 60 ] type: VENDOR_SPECIFIC reliable:yes seq#:2 ack#:2 payload_length:2 data_integrity:1 header_checksum:0 err_code:0x0 Log: 9/ 0 <- [N/A] type: ACK reliable: no seq#:0 ack#:3 payload_length:0 data_integrity:0 err_code:0x0 Log: 10/ 0 <- [01 60 00 00 00 00 ] type: VENDOR_SPECIFIC reliable:yes seq#:2 ack#:3 payload_length:6 data_integrity:1 header_checksum:b8 err_code:0x0 Log: 16 -> [N/A] type: ACK reliable: no seq#:0 ack#:3 payload_length:0 data_integrity:0 err_code:0x0 Log: 17 -> [00 8a 01 00 01 01 00 00 00 00 00 a0 00 50 00 00 00 01 01 00 00 00 64 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ] type: VENDOR_SPECIFIC reliable:yes seq#:3 ack#:3 payload_length:7d data_integrity:1 header_checksum:40 err_code:0x0 Log: 11/ 0 <- [N/A] type: ACK reliable: no seq#:0 ack#:4 payload_length:0 data_integrity:0 err_code:0x0 Log: 12/ 0 <- [01 8a 00 00 00 00 ] type: VENDOR_SPECIFIC reliable:yes seq#:3 ack#:4 payload_length:6 data_integrity:1 header_checksum:af err_code:0x0 Log: 18 -> [N/A] type: ACK reliable: no seq#:0 ack#:4 payload_length:0 data_integrity:0 err_code:0x0 Scan started Log: 70/ 0 <- [02 1d 00 ff ff 03 00 02 22 f2 31 33 9a f6 fe 00 00 00 00 00 00 01 ff 7f d0 26 ff 00 00 01 00 00 00 1b 00 01 03 19 41 03 02 01 06 07 03 0d 18 0f 18 0a 18 0b 09 4e 6f 72 64 69 63 5f 48 52 4d 00 00 00 ] type: VENDOR_SPECIFIC reliable:yes seq#:2 ack#:7 payload_length:42 data_integrity:1 header_checksum:d4 err_code:0x0 Log: 76 -> [N/A] type: ACK reliable: no seq#:0 ack#:3 payload_length:0 data_integrity:0 err_code:0x0 Received advertisement report with device address: 0xF69A3331F222 Log: 77 -> [00 8c 01 02 22 f2 31 33 9a f6 01 00 01 01 00 00 00 00 00 a0 00 50 00 00 00 01 06 00 06 00 00 00 90 01 01 ] type: VENDOR_SPECIFIC reliable:yes seq#:7 ack#:3 payload_length:23 data_integrity:1 header_checksum:e1 err_code:0x0 Log: 71/ 0 <- [N/A] type: ACK reliable: no seq#:0 ack#:0 payload_length:0 data_integrity:0 err_code:0x0 Log: 72/ 0 <- [01 8c 00 00 00 00 ] type: VENDOR_SPECIFIC reliable:yes seq#:3 ack#:0 payload_length:6 data_integrity:1 header_checksum:cf err_code:0x0 Log: 78 -> [N/A] type: ACK reliable: no seq#:0 ack#:4 payload_length:0 data_integrity:0 err_code:0x0 Log: 73/ 0 <- [02 10 00 00 00 02 22 f2 31 33 9a f6 02 06 00 06 00 00 00 90 01 ff 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ] type: VENDOR_SPECIFIC reliable:yes seq#:4 ack#:0 payload_length:24 data_integrity:1 header_checksum:ec err_code:0x0 Log: 79 -> [N/A] type: ACK reliable: no seq#:0 ack#:5 payload_length:0 data_integrity:0 err_code:0x0 Connection established Log: 80 -> [00 7e 00 00 01 43 07 10 00 00 ] type: VENDOR_SPECIFIC reliable:yes seq#:0 ack#:5 payload_length:a data_integrity:1 header_checksum:6a err_code:0x0 Log: 74/ 0 <- [N/A] type: ACK reliable: no seq#:0 ack#:1 payload_length:0 data_integrity:0 err_code:0x0 Log: 75/ 0 <- [01 7e 04 00 00 00 ] type: VENDOR_SPECIFIC reliable:yes seq#:5 ack#:1 payload_length:6 data_integrity:1 header_checksum:c5 err_code:0x0 Log: 81 -> [N/A] type: ACK reliable: no seq#:0 ack#:6 payload_length:0 data_integrity:0 err_code:0x0 sd_ble_gap_authenticate failed with error code: 0x0004 Log: 76/ 0 <- [02 55 00 00 00 f7 00 ] type: VENDOR_SPECIFIC reliable:yes seq#:6 ack#:1 payload_length:7 data_integrity:1 header_checksum:b4 err_code:0x0 Log: 82 -> [N/A] type: ACK reliable: no seq#:0 ack#:7 payload_length:0 data_integrity:0 err_code:0x0 Log: 83 -> [00 b5 00 00 17 00 ] type: VENDOR_SPECIFIC reliable:yes seq#:1 ack#:7 payload_length:6 data_integrity:1 header_checksum:99 err_code:0x0 Log: 77/ 0 <- [N/A] type: ACK reliable: no seq#:0 ack#:2 payload_length:0 data_integrity:0 err_code:0x0 Log: 78/ 0 <- [01 b5 00 00 00 00 ] type: VENDOR_SPECIFIC reliable:yes seq#:7 ack#:2 payload_length:6 data_integrity:1 header_checksum:bb err_code:0x0 Log: 84 -> [N/A] type: ACK reliable: no seq#:0 ack#:0 payload_length:0 data_integrity:0 err_code:0x0 Log: 79/ 0 <- [02 23 00 00 00 fb 00 fb 00 48 08 48 08 ] type: VENDOR_SPECIFIC reliable:yes seq#:0 ack#:2 payload_length:d data_integrity:1 header_checksum:52 err_code:0x0 Log: 85 -> [N/A] type: ACK reliable: no seq#:0 ack#:1 payload_length:0 data_integrity:0 err_code:0x0 BLE_GAP_EVT_DATA_LENGTH_UPDATE_REQUEST received: Log: 86 -> [00 90 00 00 01 1b 00 1b 00 00 00 00 00 01 ] type: VENDOR_SPECIFIC reliable:yes seq#:2 ack#:1 payload_length:e data_integrity:1 header_checksum:48 err_code:0x0 Log: 80/ 0 <- [N/A] type: ACK reliable: no seq#:0 ack#:3 payload_length:0 data_integrity:0 err_code:0x0 Log: 81/ 0 <- [01 90 00 00 00 00 01 00 00 00 00 00 00 ] type: VENDOR_SPECIFIC reliable:yes seq#:1 ack#:3 payload_length:d data_integrity:1 header_checksum:49 err_code:0x0 Log: 87 -> [N/A] type: ACK reliable: no seq#:0 ack#:2 payload_length:0 data_integrity:0 err_code:0x0 Log: 82/ 0 <- [02 24 00 00 00 1b 00 1b 00 5a 05 5a 05 ] type: VENDOR_SPECIFIC reliable:yes seq#:2 ack#:3 payload_length:d data_integrity:1 header_checksum:48 err_code:0x0 Log: 88 -> [N/A] type: ACK reliable: no seq#:0 ack#:3 payload_length:0 data_integrity:0 err_code:0x0 Received an un-handled event with ID: 36
Could anyone please help me on how should I initiate with sd_ble_gap_authenticate properly with pc-ble-driver?
Thanks and best regards!
Chencheng
