Two issues with CC310 HW CryptoCell: Linking and hanging
Hi, we stumbled into two issues when we enabled LESC in our application.
Relevant SDK config:
NRF_CRYPTO_ENABLED
NRF_CRYPTO_BACKEND_CC310_ENABLED
NRF_CRYPTO_BACKEND_CC310_RNG_ENABLED
First one is that pm_init() will hang if called when NRF_CRYPTO_BACKEND_CC310_RNG_ENABLED unless we call sd_nvic_critical_region_enter before and then sd_nvic_critical_region_exit after. I can't find anything documentation saying that we need to do that. See attached stacktrace when calling pm_init() without entering critical region. It's the CRYS_RndInit() which hangs and causes the WD to reset.
Second issue I think is related to linking.
I have a theory that the linker does not link cc310_backend_init.o file as the two public functions void cc310_backend_enable(void); and void cc310_backend_disable(void); are
found in cc310_backend_shared.c and therefore CRYPTO_BACKEND_REGISTER does not
place cc310_backend_init and cc310_backend_uninit in the crypto_data section in flash.
Causing that cc310_backend_init() is never called when initiating as it's not found in the.crypto_data
If I add a dummy function to cc310_backend_init.c the two functions are placed in the .crypto_data section in the flash. See the attached patch.txt file.
diff --git a/bsp/nRF5_SDK_15.2.0_9412b96/components/libraries/crypto/backend/cc310/cc310_backend_init.c b/bsp/nRF5_SDK_15.2.0_9412b96/components/libraries/crypto/backend/cc310/cc310_backend_init.c
index e3e77f0b..05f29edb 100644
--- a/bsp/nRF5_SDK_15.2.0_9412b96/components/libraries/crypto/backend/cc310/cc310_backend_init.c
+++ b/bsp/nRF5_SDK_15.2.0_9412b96/components/libraries/crypto/backend/cc310/cc310_backend_init.c
@@ -57,6 +57,18 @@ void cc310_backend_enable(void);
+// patch start
+uint32_t forceLinkingcc310BackendInit()
+    The linker does not link this file as the above two functions are found in cc310_backend_shared.c
+    And therefore CRYPTO_BACKEND_REGISTER does not place cc310_backend_init cc310_backend_uninit
+    in the crypto_data section in flash. This is a workaround for not ignoring this file.
+    return 0;
+//patch end
 static uint32_t init_result_get(uint32_t crys_error)
     uint32_t ret_val = NRF_ERROR_INTERNAL;
--- a/bsp/nRF5_SDK_15.2.0_9412b96/components/libraries/crypto/nrf_crypto_init.c
+++ b/bsp/nRF5_SDK_15.2.0_9412b96/components/libraries/crypto/nrf_crypto_init.c
@@ -79,6 +79,11 @@ ret_code_t nrf_crypto_init(void)
             return ret_val;
+    // patch start
+#if NRF_MODULE_ENABLED(NRF_CRYPTO_BACKEND_CC310)
+    forceLinkingcc310BackendInit();
+#endif
+    // patch end
     // Set nrf_crypto to initialized
     m_state = INITIALIZED;
diff --git a/bsp/nRF5_SDK_15.2.0_9412b96/components/libraries/crypto/nrf_crypto_init.h b/bsp/nRF5_SDK_15.2.0_9412b96/components/libraries/crypto/nrf_crypto_init.h
index 8e10ae13..a90125b0 100644
--- a/bsp/nRF5_SDK_15.2.0_9412b96/components/libraries/crypto/nrf_crypto_init.h
+++ b/bsp/nRF5_SDK_15.2.0_9412b96/components/libraries/crypto/nrf_crypto_init.h
@@ -136,6 +136,10 @@ bool nrf_crypto_is_initialized(void);
 bool nrf_crypto_is_initializing(void);
+// patch start
+uint32_t forceLinkingcc310BackendInit();
+// patch end
 #ifdef __cplusplus
SoftDevice: s140_nrf52_6.1.0
SDK: nRF5_SDK_15.2.0_9412b96
  • Hi, thanks, that is wierd, yes we should use none-eabi. We will update and see if that solves the linking problem.
  • Hi, we have now upgraded to arm-none-eabi 8.3 and still have the exact same problems. So the issue is not with the compiler version.
    Can you check if you see the same issue with GCC ARM Embedded 6.3 2017-q2-update, which is the tested/supported toolchain for SDK 15.2?
  • Hi Einar,
    tried with the 6.3 q2 toolchain without any luck.
    I also tried removing `static` statement from the functions cc310_backend_init and cc310_backend_uninit without any result.
    And also tried adding __attribute__((used)) to the same functions - still they do not show up in the .crypto_data section.
    Tried removing gc-sections from linker flags just to try, but unfortunately this made sections overflow and could not get any leads from this.
    Edit:
    Further investigation indicates that the problem boils down to some issue in the libnrf_cc310_0.9.1.a.
    If I add print-gc-sections to our linker, and diff the output with and without jakkras fix, it turns out that following symbols are garbage collected by the linker without the fix:
    '.text.SaSi_PalInit'
    '.text.SaSi_PalTerminate'
    '.rodata.SaSi_PalInit.str1.4'
    '.text.SaSi_PalDmaInit'
    '.text.SaSi_PalDmaTerminate'
    '.text.SaSi_PalMutexCreate'
    '.text.SaSi_PalMutexDestroy'
    '.rodata.SaSi_PalMutexCreate.str1.4'
    '.text.SaSi_HalInit
    '.text.SaSi_HalTerminate'
    According to docs SaSi_PalInit should be called by SaSi_LibInit. SaSi_LibInit is called from
    static ret_code_t cc310_backend_init(void)
    which in turn is registered as
    CRYPTO_BACKEND_REGISTER(nrf_crypto_backend_info_t const cc310_backend) =
        .init_fn    = cc310_backend_init,
        .uninit_fn  = cc310_backend_uninit,
    in your cc310_backend_init.c.
    It is weird that SaSi_LibInit is not gc'ed but SaSi_PalInit is (without the fix). Again, it suggests something odd in libnrf_cc310_0.9.1.a.
    Cheers / Peter
  • Hi Peter,
    Do you by any chance build the SDK as a library, and then compile your application separately, linking it to the SDK? If so, that could explain this, as section variables require that everything is compiled together, if not they will not be populated.
