I’m searching for some more detailed information of the SAADC input impedance.
Please see attached file for details and questions.
Sorry, I thought I got it, but now I feel like I'm back to square one... I don't know what SAADC input impedance spec to use for my design...
Lets try to use some more dedicated definitions to avoid mix up things:
I think I understand that the SAADC input impedance (lets call this Z_SAADC) consist of the DC leakage (lets call this R_DC) and the equivalent impedance because of the switched capacitor Csample (lets call this Z_CAP).
a) The specification in the datasheet "Input resistance - Rinput>1Mohm (typically)", how shall this be interpreted then?
Above, you clearly say that this datasheet term "Rinput" is NOT related at all to Z_CAP.
If the datasheet term "Rinput" is supposed to be interpreted as the R_DC, then I have to deal with a worst case DC input impedance of 1Mohm, which cannot be the case according to the referred battery monitor application. https://devzone.nordicsemi.com/b/blog/posts/measuring-lithium-battery-voltage-with-nrf52
I'm confused. Please clarify!
For my design I need to know what worst case load the SAADC can put onto the circuit connected to the SAADC port.
b) Regarding temperature conditions for electrical specifications:
I think you misunderstand me. Lets look at an datasheet example, even that my question relates to ALL electrical specifications stated in the datasheet. Lets look at the specification of the pull-up resistance: Min 11kohm, typ 13kohm, max 16kohm.![]()
By which temperature conditions (and supply voltage conditions as well) are these three values stated?
Are all three values only valid for the nominal operational temperature (25degC) and nominal supply voltage (3.0V)?
(In case, how to get values for the temperature range, which is very relevant in many places)
or
Are all three values valid for the recommended operational temperature range (-40degC to 85degC) and supply voltage range (1.7V-3.6V)?
or
Is the typical value valid for 25degC/3.0V, and the min and max values valid for -40degC to 85degC and 1.7V-3.6V?
or
something else?
Would be valuable if this was much more clearly stated in the datasheet. Your competitors often state something like this: "Electrical Characteristics over recommended ranges of supply voltage and operating free-air temperature (unless otherwise noted)"
Thank you for your patience :-)
a) Sorry if this is confusing. I agree that Z_SAADC is a good term, because that would then be Z_SAADC = (R_DC || 1/(f_sample * C_sample)). The datasheet does not say that R_DC = 1MOhm, but says R_DC > 1 MOhm. To qualify this number we have measured the input resistance, and based on those measurements we know that it's > 50 MOhm at typical conditions.
b) For that specific case (pull-up resistance) the min/max would cover voltage, process and temperature variations.
a) Datasheet says that R_INPUT (R_DC) might be as low as 1Mohm. This is what I must design against. Basically, my design cannot rely on what you have measured at so called typical conditions, but what you write in the datasheet (unless there is an error in the datasheet).
And related to the second topic, I don’t know the conditions for the specification "R_INPUT>1Mohm". Does this cover voltage, process and temperature? And even that it is written in the "typical" column, is it supposed to be interpreted as a minimum value?
b) Sorry, but you have to improve on this subject. I was in general asking for the conditions for the electrical specifications stated in the datasheet, as these seems not to be written anywhere. As written, the pull resistor was just an example to illustrate my point and not a specific interest in that parameter.
Your answer can be interpreted in that way, that the conditions for the stated min, typ and max values all over the datasheet changes from subject to subject. I must active request the conditions for each electrical specification then... Come on...
Why are the primary conditions for the electrical specifications not stated in the datasheet?
This is absolutely not what I expect from a serious semiconductor manufacturer.
When you deliver to some commercial designs, they might live with that, but making serious automotive and medical designs, there is no alternative to follow rule number one: Stick to the datasheet!
a) The typical condition (R_INPUT > 1 MOhm) does not cover temperature, process or voltage variation. The typical operating conditions is 3.0 V and 25 C, as specified in Recommended operating conditions
b) See page 10 in https://www.nordicsemi.com/-/media/DocLib/Other/Product_Spec/nRF52832PSv14.pdf?la=en. There you'll find the following text
"Electrical specification tables, containing performance data which apply for the operating conditions
described in Recommended operating conditions on page 20."
That means that if the el-spec table specifies min/max it covers the full voltage range and temperature range.
a) So R_INPUT can be even lower than 1Mohm over operational range?
Can you provide me a minimum specification of R_INPUT (over temperature, process and voltage)?
b) For me it is not obvious that the text "Electrical specification tables, containing performance data which apply for the operating conditions described in Recommended operating conditions on page XX" means the following:
- Typical values is valid for nominal recommended operating conditions.
- Minimum and maximum values are valid for the recommended operating condition range.
I believe I above have tried to mention that enterpretation as an option, but anyway, if thats the general way to read your datasheet, I have learned that now.
Sometimes communication can be difficult.
