hex file for MCP dongle
I can't seem to find the hex file to download into the PCA10000 in order to use it with the Master Control Panel. Where is this documented in the dev-kit documentation?
  • This would have been a lot better as a separate question, but the answer is most likely that you have programmed the softdevice before trying to flash the Master Emulator firmware. That should not be done, since the Master Emulator firmware doesn't use the softdevice.
    If this does not make it work, I'd be happy if you could post it as a separate question, since it has nothing to do with the original question here.
