nRF9160 DK board controller SourceCode
Dear,
I am using nrf9160 DK, we can download hex fiel for boardcontroller
nRF9160 DK board controller firmware
https://www.nordicsemi.com/Software-and-Tools/Development-Kits/nRF9160-DK/Download#infotabs
nRF9160_DK_board_controller_FW.hex
It will be programmed for nRF52 to control nRF9160 DK board
Can you share the source code?
hng
    The board controller fw is currently not available in source code. But as mentioned at this link, it's possible to route some pins differently from what is done in the preprogrammed firmware.
  • Dear Sigurd,
    For example: the LED1234  control
    the info from the backside of nrf9160 DK pcb
    GPIO  Function
    P0.02 LED 1
    P0.03 LED 2
    P0.04 LED 3
    P0.05 LED 4
    P0.06 Button 1
    P0.07 Button 2
    P0.08 Button 3
    P0.09 Button 4
    P0.26 CTS
    P0.27 RTS
    P0.28 RxD
    P0.29 TxD
    On the schematic, Switches are used for selection
    example: pin P0.02 (from nRF91) will select LED1 or D2 (P0.02 on the PCB-P14), and the control pin nRF52_P1.05 (from nRF52)
    So, we need one program for nRF52 to control for GPIO:
    Currently, the pin P0.02 will connect LED1 so pin D2 (P0.02 on the PCB-P14) is floating
    Do we have any option ( for example :  CONFIG_GPIO=y in  prj.conf ) to enable pin D2  (P0.02 on the PCB-P14) ?
    then I can use it as normal gpio
    regards,
    thanks
    hng
  • The nRF9160 DK User Guide v0.7.2 states: «Configurable code examples for the nRF52840 allowing to change the board routing can be found in the nRF Connect SDK».
    I've looked in the applications and samples folder, but I can't find it. Is it still not available? Is there a trace on the PCB I can cut to use P0.02-P0.09 from the pin headers?
  • Hi gregers,
    Take a look at this post. It covers routing UART pins, but the same method is used for the LEDs and buttons. The board controller can be found here. (it's included when you build e.g. hello_world sample for target nrf52840_pca10090, and configurable with kconfig/menuconfig)
