How to calibrate the nRF51 ADC to correct offset and gain error
According to the nRF51822 PS v3.1, table 51, offset error for the internal ADC is up to 2% and the gain error can be up to 2%. Is it possible to correct this error to obtain better accuracy for the ADC?
  • The offset and gain error is different from IC to IC and may therefore be calibrated for each IC to obtain acceptable accuracy. On nRF51 third revision IC's the offset and gain error has been measured and written into non-volatile memory for 10-bit ADC resolution, see update on this thread from 10.4.2015. To otherwise generally correct the offset and gain error, perform the following steps:
    • Configure the ADC to use 1.2VBG reference voltage and to sample from an analog input pin, use e.g. this code.
    • Connect a voltage source to the configured input pin that provides a steady 0.1V. Read the ADC output (actual ADC output at 0.1V)
    • Set the voltage source to 1.1V and read the ADC output (actual ADC output at 1.1V)
    The transfer function is:
    image description
    Update 10.4.2015 An easier way to apply ADC calibration for third revision nRF51 is to read the gain error and offset error numbers available in memory address 0x10000024. This information is not available for first or second nRF51 revision ICs. For third revision nRF51 devices, the offset and gain error values have been measured for each nRF51 chip after production and have been written to memory address 0x10000024. The register at this memory address is listed below and the gain error and offset error values are valid for 10-bit sampling only. For 8-bit and 9-bit sampling, there are no values available:
    image description
    The ADC offset and gain error are read with the following command:
    nrfjprog --memrd 0x10000024 --n 4
    • If e.g. the perceived value is "0x10000024: FFFF0102" then GAIN_ERROR=1 and OFFSET_ERROR=2.
    • The offset and gain values are two's complement numbers. This means that if e.g. the observed value is 0xFFFF03FF, then GAIN_ERROR=3 and OFFSET_ERROR=-1
    • Similarly, if the observed value is 0xFFFFFEFC, then GAIN_ERROR=-2 and OFFSET_ERROR=-3
    The calibrated value y is obtained for 10-bit ADC sample x with:
    y = x * (1024+GAIN_ERROR) / 1024 + OFFSET_ERROR - 0.5
    where 0.5 LSB is subtracted to compensate for ADC quantization error.
    Update 27.10.2015
    To obtain the offset error and gain error at runtime the FICR value can be read with:
    	static uint32_t ficr_value_32;
    	static int8_t offset_error;
    	static int8_t gain_error;
    	ficr_value_32 = *(uint32_t*)0x10000024;
    	offset_error = ficr_value_32;
    	gain_error = ficr_value_32 >> 8;
  • Stephan, which document contains the above table with the offset and gain error values at offset 0x0024 of the FICR?
  • Hi Philip
    There is unfortunately no official document that contains this information. This information is made public only here on this thread. At this point I am not sure for the reasons for it not to be in official documentation but perhaps because it is limited information, since it only applies for 10 bit sampling. If this information will be in official documentation it will be in a future release of the nRF51 Series Reference Manual.
  • Very useful info. Two related questions:
    • Why that "-0.5" in the formula? I have an example (yours I guess) where that value is ommited.
    • Is there any way we can automatically read this calibration value from code? For example a function that only runs once at the beggining, or similar. So we don't have to manually get the value with nrfjprog. Thanks
    Thanks
