Mqtt_simple sample error.
Trying to up load mqtt_simple sample, however getting bus fault on terminal. have browsed after the same issue here, but don't work after doing git pull ect...
here's the output:
***** BUS FAULT *****
Precise data bus error
BFAR Address: 0x4002a514
***** Hardware exception
Current thread ID = 0x2000033c
Faulting instruction address = 0x70b8
Fatal
fault in essential thread! Spinning...
  • yess, am trying to use the command prompt and did it on friday. but now I get an another error there then I got on friday.
    warning: NET_RAW_MODE (defined at subsys\net\ip\Kconfig:12) was assigned the value 'y' but got the
    value 'n'. This symbol has no prompt, meaning assignments in configuration files have no effect on
    it. It can only be set indirectly, via Kconfig defaults (e.g. in a Kconfig.defconfig file) or
    through being 'select'ed or 'imply'd (note: try to avoid Kconfig 'select's except for trivial
    promptless "helper" symbols without dependencies, as it ignores dependencies and forces symbols on).
    YouParsing Kconfig tree in C:/Nordic/ncs/zephyr/Kconfig
    Loading C:/Nordic/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090_defconfig as base
    Merging C:/Nordic/ncs/nrf/samples/nrf9160/at_client/prj.conf
     can check symbol information (including dependencies) in the 'menuconfig' interface (see the
    Application Development Primer section of the manual), or in the Kconfig reference at
    docs.zephyrproject.org/.../CONFIG_NET_RAW_MODE.html (which is updated
    regularly from the master branch). See the 'Setting configuration values' section of the Board
    Porting Guide as well. It covers Kconfig.defconfig files.
    C:/Nordic/ncs/nrf/samples/nrf9160/at_client/prj.conf:1: warning: attempt to assign the value 'y' to the undefined symbol BSD_LIBRARY
    C:/Nordic/ncs/nrf/samples/nrf9160/at_client/prj.conf:6: warning: attempt to assign the value 'y' to the undefined symbol AT_HOST_LIBRARY
    Error: Aborting due to non-whitelisted Kconfig warning
    'C:/Nordic/ncs/nrf/samples/nrf9160/at_client/prj.conf:1: warning: attempt to assign the value 'y' to
    the undefined symbol BSD_LIBRARY'. Note: If this warning doesn't point to an actual problem, you can
    add it to the whitelist at the top of C:/Nordic/ncs/zephyr/scripts/kconfig/kconfig.py.
    CMake Error at C:/Nordic/ncs/zephyr/cmake/kconfig.cmake:191 (message):
      command failed with return code: 1
      C:/Nordic/ncs/zephyr/cmake/app/boilerplate.cmake:397 (include)
      CMakeLists.txt:9 (include)
    here am trying to flash AT_client, and is the same error on mqtt_simple and others.
    and if i use mqtt_simple with SES I'll get bus fault on the mqtt.
    regards
    Henning
  • Ok, that was not what I expected.
    Can you please elaborate your steps up to this point?
    What versions of git repositories are you using? Remember, there are two repository tags that can be used for fw-nrfconnect-nrf: tag v0.3.0 or 0.3.99 (master branch).
    Maybe it is good to start from scratch. What did you use to start with the nRF9160 DK? Getting Started with the nRF91DK, nRF Connect SDK v0.3.0 documentation or  nRF Connect SDK v0.3.99 documentation? The latter yields the issue as mentioned in the previous post (not able to use the master branch with Segger Embedded Studio (SES)). I would recommend using the first one (Getting Started....), which lets you use SES.
    Thank you,
    Øyvind
  • I've updated the master branch, git pull etc... when I flash it, I'm doing it exactly like the thread u posted. even tried to flash the cmake .. -DBOARD=nrf9160_pca10090ns -GNinja and cmake .. -DBOARD=nrf9160_pca10090 -GNinja.
    I think it's odd because I've erased and done everything from the start, but it will not flash the new one.
    So I tried to flash the old one v0.3.0 with a prompter, it works rigth away.
    i've stated with Getting Started with the nRF91DK,  I started with the nrf connect v2.6.2, and done everything there even verified all.
    I only have problem with the new v0.3.99
    regards
    Henning
  • I need to use mqtt_simple in my project. or do u have an another sample to transmitt data to a server?
    -Henning
     Can you please share the command prompt output when you run these commands? Are you in the correct folders when running these commands?
    So I tried to flash the old one v0.3.0 with a prompter, it works away.
    I need to use mqtt_simple in my project. or do u have sample to data to a server?
    Did you try to copy the mqtt_simple example to the v0.3.0 samples folder? Ensuring that you were using v0.3.0?
    Did you try to open this example using Segger Embedded Studio Nordic Edition?
