Mqtt_simple sample error.
Trying to up load mqtt_simple sample, however getting bus fault on terminal. have browsed after the same issue here, but don't work after doing git pull ect...
here's the output:
***** BUS FAULT *****
Precise data bus error
BFAR Address: 0x4002a514
***** Hardware exception
Current thread ID = 0x2000033c
Faulting instruction address = 0x70b8
Fatal
fault in essential thread! Spinning...
  • here the whole thing:
    USN+103438@S-HVE9127 MINGW64 /c/ncs
    $ export ZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb
    $ export GNUARMEMB_TOOLCHAIN_PATH=/c/gnuarmemb/
    $ source /c/ncs/zephyr/zephyr-env.sh
    $ cd /c/ncs/nrf/samples/nrf9160/mqtt_simple/
    USN+103438@S-HVE9127 MINGW64 /c/ncs/nrf/samples/nrf9160/mqtt_simple (master)
    $ mkdir build && cd build
    mkdir: cannot create directory ‘build’: File exists
    USN+103438@S-HVE9127 MINGW64 /c/ncs/nrf/samples/nrf9160/mqtt_simple/build (master)
    $ cmake .. -DBOARD=nrf9160_pca10090ns -GNinja
    Zephyr version: 1.14.0
    -- Found PythonInterp: C:/Python37/python.exe (found suitable version "3.7.2", minimum required is "3.4")
    -- Selected BOARD nrf9160_pca10090ns
    -- Found west: C:/Python37/Scripts/west.exe (found suitable version "0.5.7", minimum required is "0.5.6")
    -- Loading C:/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090ns.dts as base
    -- Overlaying C:/ncs/zephyr/dts/common/common.dts
    Parsing Kconfig tree in C:/ncs/nrf/samples/nrf9160/mqtt_simple/Kconfig
    Loading C:/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090ns_defconfig as base
    Merging C:/ncs/nrf/samples/nrf9160/mqtt_simple/prj.conf
    C:/ncs/nrf/samples/nrf9160/mqtt_simple/prj.conf:11: warning: attempt to assign the value 'y' to the undefined symbol LTE_LINK_CONTROL
    C:/ncs/nrf/samples/nrf9160/mqtt_simple/prj.conf:12: warning: attempt to assign the value 'n' to the undefined symbol LTE_AUTO_INIT_AND_CONNECT
    C:/ncs/nrf/samples/nrf9160/mqtt_simple/prj.conf:15: warning: attempt to assign the value 'y' to the undefined symbol BSD_LIBRARY
    C:/ncs/nrf/samples/nrf9160/mqtt_simple/prj.conf:19: warning: attempt to assign the value 'y' to the undefined symbol AT_HOST_LIBRARY
    Error: Aborting due to non-whitelisted Kconfig warning
    'C:/ncs/nrf/samples/nrf9160/mqtt_simple/prj.conf:11: warning: attempt to assign the value 'y' to the
    undefined symbol LTE_LINK_CONTROL'. Note: If this warning doesn't point to an actual problem, you
    can add it to the whitelist at the top of C:/ncs/zephyr/scripts/kconfig/kconfig.py.
    CMake Error at C:/ncs/zephyr/cmake/kconfig.cmake:191 (message):
      command failed with return code: 1
      C:/ncs/zephyr/cmake/app/boilerplate.cmake:397 (include)
      CMakeLists.txt:9 (include)
    $ cmake .. -DBOARD=nrf9160_pca10090 -GNinja
    CMake Warning at C:/ncs/zephyr/cmake/app/boilerplate.cmake:155 (message):
    The build directory must be cleaned pristinely when changing boards
    if the rigth folder is build, and before compiling its empty.
    yess, I have tried that, to copy it, tried it first before and tried it agian. however, the bus fault happen. the same bus fault as written at the topic.
    I think I've covered everything here on devzone to find out the issue.
    --Henning
  • I have this issue as well. When the mqtt_simple example is compiled from the master branch using Cmake, the DK will report back a BUS FAULT.
    I have also tried copying the sample (and the Zephyr mqtt.h include file) into a v0.3.0 branch of the nRF connect repos and compiled it using both SEGGER Embedded Studio and Cmake. Both compile and flash but continue to report back BUS FAULTs.
  • Ok, here's and update, I managed to compile and build it over the command prompter, I opened up C:/ncs/zephyr/scripts/kconfig/kconfig.py in notepad and whitelisted the libraries that where in the error.
    # Warnings that won't be turned into errors (but that will still be printed),
    # identified by a substring of the warning. The warning texts from Kconfiglib
    # are guaranteed to not change.
    WARNING_WHITELIST = (
        # Warning generated when a symbol with unsatisfied dependencies is being
        # selected. These should be investigated, but whitelist them for now.
        "y-selected","BSD_LIBRARY","AT_HOST_LIBRARY","LTE_LINK_CONTROL","LTE_AUTO_INIT_AND_CONNECT",
    however, now the ninja flash stop at the end because of.
    FAILED: CMakeFiles/app.dir/src/main.c.obj
    C:\gnuarmemb\bin\arm-none-eabi-gcc.exe -DBUILD_VERSION=v1.13.99-ncs1-5782-g3e02cab5fb0f -DKERNEL -DNRF9160_XXAA -DNRF_TRUSTZONE_NONSECURE -D_FORTIFY_SOURCE=2 -D__ZEPHYR__=1 -IC:/ncs/zephyr/kernel/include -IC:/ncs/zephyr/arch/arm/include -IC:/ncs/zephyr/include -IC:/ncs/zephyr/include/drivers -Izephyr/include/generated -IC:/ncs/zephyr/soc/arm/nordic_nrf/nrf91 -IC:/ncs/zephyr/soc/arm/nordic_nrf/include -IC:/ncs/zephyr/lib/libc/minimal/include -IC:/ncs/zephyr/ext/hal/cmsis/Include -IC:/ncs/zephyr/ext/hal/nordic/nrfx -IC:/ncs/zephyr/ext/hal/nordic/nrfx/drivers/include -IC:/ncs/zephyr/ext/hal/nordic/nrfx/hal -IC:/ncs/zephyr/ext/hal/nordic/nrfx/mdk -IC:/ncs/zephyr/ext/hal/nordic/. -IC:/ncs/zephyr/subsys/net/lib/sockets/. -isystem c:/gnuarmemb/bin/../lib/gcc/arm-none-eabi/7.3.1/include -isystem c:/gnuarmemb/bin/../lib/gcc/arm-none-eabi/7.3.1/include-fixed -Os -nostdinc -g -Wall -Wformat -Wformat-security -Wno-format-zero-length -imacros C:/ncs/nrf/samples/nrf9160/mqtt_simple/build/zephyr/include/generated/autoconf.h -ffreestanding -Wno-main -fno-common -mthumb -mcpu=cortex-m33 -fno-asynchronous-unwind-tables -fno-pie -fno-pic -fno-strict-overflow -Wno-pointer-sign -Wno-unused-but-set-variable -fno-reorder-functions -fno-defer-pop -Werror=implicit-int -Wpointer-arith -ffunction-sections -fdata-sections -mabi=aapcs -march=armv8-m.main+dsp -std=c99 -MD -MT CMakeFiles/app.dir/src/main.c.obj -MF CMakeFiles\app.dir\src\main.c.obj.d -o CMakeFiles/app.dir/src/main.c.obj   -c ../src/main.c
    ../src/main.c:14:10: fatal error: lte_lc.h: No such file or directory
     #include <lte_lc.h>
    compilation terminated.
    [125/133] Building C object zephyr/kernel/CMakeFiles/kernel.dir/poll.c.obj
  • Ok, there is something wrong with your SDK. Seems like the Zephyr is not aware of NRF, as the warnings are configurations that enable the use of nrf drivers/libraries in Zephyr.
     Are you using west to update the master branch of the SDK?
    Be aware that West was introduced after nRF Connect SDK v0.3.0. Therefore, you cannot use it to check out v0.1.0 or v0.3.0. More information here
    Can we try to start from scratch, with a new folder e.g. C:\NCS2
    In this folder run:
    git clone https://github.com/NordicPlayground/fw-nrfconnect-nrf.git nrf
    then
    west init -l nrf
    following with
    west update
    Now you have to setup the building environment:
    In NCS2
    cd zephyr
    zephyr-env.cmd
    Lastly add the file %userprofile%\zephyrrc.cmd with
    set ZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb
    set GNUARMEMB_TOOLCHAIN_PATH=/c/gnuarmemb/
    From this point, you should be able to continue with the mqtt_simple sample using nRF Connect SDK v0.3.99 (master).
    And if that this does not help, then we will find another solution.
    -Øyvind
  • Hi Michael,
    Can you please register a support case for your issue?
    Thank you!
    BR,
    Øyvind
