Multilink Central UART - Restarting when connected to 2 more more peripherals
Hi all,
I am trying to implement a multilink central with UART. I had looked through the forum on all discussions in about this and followed this thread to come up with the program https://devzone.nordicsemi.com/f/nordic-q-a/41189/multilink-ble_app_uart---ble_app_multilink_central-3
I am running my central on a NFR52DK and using SDK15.2.0 with softdevice S132. I have 2 peripherial (Nordic Thingy) running the default  ble_app_uart program.
My program complies without errors and the multi-link central can also connect to 1 peripheral running the default  ble_app_uart program.
This is the RTT log:
0> <info> app: Multilink example started.
0> <info> app: Start scanning for device...
0> <info> app: Connecting to target 461B790D58E6
0> <info> app: Connection 0x0 established, starting DB discovery.
0> <info> app: ATT MTU exchange completed.
0> <info> app: Ble NUS max data length set to 0xF4(244)
0> <info> app: Discovery complete.
0> <info> app: Connected to device with Nordic UART Service.
However, if I try to turn on another uart peripheral, the multi-link central gives a FATAL error.
I put a break point inside app_errpr_handler_bare. And the error code 0x00000012 is pass into this function. Inside, error_info is as follows:
error_info.line_num = 0x200080E8
error_info.p_file_name: 0x00000003
error_info.error_code: 0x00000006
I am attaching my codes here. Hope to get some advise on how to proceed forward. Thanks in advance!
 * Copyright (c) 2016 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "app_timer.h"
#include "bsp_btn_ble.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "ble_db_discovery.h"
#include "ble_conn_state.h"
#include "ble_advdata.h"
#include "nrf_ble_gatt.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_ble_scan.h"
#include <string.h>
#include <stdbool.h>
#include "app_error.h"
#include "app_uart.h"
#include "app_util.h"
#include "ble_gap.h"
#include "nrf_sdh_soc.h"
#include "ble_nus_c.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define APP_BLE_CONN_CFG_TAG      1                                     /**< Tag that refers to the BLE stack configuration that is set with @ref sd_ble_cfg_set. The default tag is @ref APP_BLE_CONN_CFG_TAG. */
#define APP_BLE_OBSERVER_PRIO     3                                     /**< BLE observer priority of the application. There is no need to modify this value. */
#define UART_TX_BUF_SIZE        256                                     /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE        256                                     /**< UART RX buffer size. */
#define NUS_SERVICE_UUID_TYPE   BLE_UUID_TYPE_VENDOR_BEGIN              /**< UUID type for the Nordic UART Service (vendor specific). */
#define ECHOBACK_BLE_UART_DATA  1                                       /**< Echo the UART data that is received over the Nordic UART Service (NUS) back to the sender. */
BLE_NUS_C_ARRAY_DEF(m_ble_nus_c,NRF_SDH_BLE_CENTRAL_LINK_COUNT);        /**< BLE Nordic UART Service (NUS) client instance. */
NRF_BLE_GATT_DEF(m_gatt);                                               /**< GATT module instance. */
BLE_DB_DISCOVERY_ARRAY_DEF(m_db_disc, NRF_SDH_BLE_CENTRAL_LINK_COUNT);  /**< Database discovery module instances. */
NRF_BLE_SCAN_DEF(m_scan);                                               /**< Scanning Module instance. */
static bool retry_operation_tx_notif_enable = false;
static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - OPCODE_LENGTH - HANDLE_LENGTH; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
#define CENTRAL_SCANNING_LED      BSP_BOARD_LED_0
#define CENTRAL_CONNECTED_LED     BSP_BOARD_LED_1
#define LEDBUTTON_LED             BSP_BOARD_LED_2                       /**< LED to indicate a change of state of the Button characteristic on the peer. */
//#define LEDBUTTON_BUTTON          BSP_BUTTON_0                          /**< Button that writes to the LED characteristic of the peer. */
//#define BUTTON_DETECTION_DELAY    APP_TIMER_TICKS(50)                   /**< Delay from a GPIOTE event until a button is reported as pushed (in number of timer ticks). */
static char const m_target_periph_name[] = "Nordic_Blinky";             /**< Name of the device to try to connect to. This name is searched for in the scanning report data. */
/**@brief NUS UUID. */
static ble_uuid_t const m_nus_uuid =
    .uuid = BLE_UUID_NUS_SERVICE,
    .type = NUS_SERVICE_UUID_TYPE
/**@brief Function for handling asserts in the SoftDevice.
 * @details This function is called in case of an assert in the SoftDevice.
 * @warning This handler is only an example and is not meant for the final product. You need to analyze
 *          how your product is supposed to react in case of an assert.
 * @param[in] line_num     Line number of the failing assert call.
 * @param[in] p_file_name  File name of the failing assert call.
    app_error_handler(0xDEADBEEF, line_num, p_file_name);
/**@brief Function for initializing the LEDs.
 * @details Initializes all LEDs used by the application.
static void leds_init(void)
/**@brief Function for starting scanning. */
static void scan_start(void)
    ret_code_t ret;
    NRF_LOG_INFO("Start scanning for device...");
    ret = nrf_ble_scan_start(&m_scan);
    APP_ERROR_CHECK(ret);
    // Turn on the LED to signal scanning.
    bsp_board_led_on(CENTRAL_SCANNING_LED);
static void scan_evt_handler(scan_evt_t const * p_scan_evt)
    ret_code_t err_code;
    switch(p_scan_evt->scan_evt_id)
        case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
            err_code = p_scan_evt->params.connecting_err.err_code;
        } break;
				case NRF_BLE_SCAN_EVT_CONNECTED:
            ble_gap_evt_connected_t const * p_connected =
                             p_scan_evt->params.connected.p_connected;
            // Scan is automatically stopped by the connection.
            NRF_LOG_INFO("Connecting to target %02x%02x%02x%02x%02x%02x",
                    p_connected->peer_addr.addr[0],
                    p_connected->peer_addr.addr[1],
                    p_connected->peer_addr.addr[2],
                    p_connected->peer_addr.addr[3],
                    p_connected->peer_addr.addr[4],
                    p_connected->peer_addr.addr[5]
        } break;
        case NRF_BLE_SCAN_EVT_SCAN_TIMEOUT:
            NRF_LOG_INFO("Scan timed out.");
            scan_start();
        } break;
/**@brief Function for initializing the scanning and setting the filters.
static void scan_init(void)
    nrf_ble_scan_init_t init_scan;
    memset(&init_scan, 0, sizeof(init_scan));
    init_scan.connect_if_match = true;
    init_scan.conn_cfg_tag     = APP_BLE_CONN_CFG_TAG;
    err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
    err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_UUID_FILTER, &m_nus_uuid);
    err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_UUID_FILTER, false);
/**@brief Function for handling characters received by the Nordic UART Service (NUS).
 * @details This function takes a list of characters of length data_len and prints the characters out on UART.
 *          If @ref ECHOBACK_BLE_UART_DATA is set, the data is sent back to sender.
static void ble_nus_chars_received_uart_print(uint8_t * p_data, uint16_t data_len)
    ret_code_t ret_val;
    NRF_LOG_DEBUG("Receiving data.");
    NRF_LOG_HEXDUMP_DEBUG(p_data, data_len);
    for (uint32_t i = 0; i < data_len; i++)
        do
            ret_val = app_uart_put(p_data[i]);
            if ((ret_val != NRF_SUCCESS) && (ret_val != NRF_ERROR_BUSY))
                NRF_LOG_ERROR("app_uart_put failed for index 0x%04x.", i);
                APP_ERROR_CHECK(ret_val);
        } while (ret_val == NRF_ERROR_BUSY);
    if (p_data[data_len-1] == '\r')
        while (app_uart_put('\n') == NRF_ERROR_BUSY);
    if (ECHOBACK_BLE_UART_DATA)
			for (uint32_t i = 0; i< NRF_SDH_BLE_CENTRAL_LINK_COUNT; i++)
				// Send data back to peripheral.
				do
					ret_val = ble_nus_c_string_send(&m_ble_nus_c[i], p_data, data_len);
						NRF_LOG_ERROR("Failed sending NUS message. Error 0x%x. ", ret_val);
 * @details This function receives a single character from the app_uart module and appends it to
 *          a string. The string is sent over BLE when the last character received is a
 *          'new line' '\n' (hex 0x0A) or if the string reaches the maximum data length.
    static uint16_t index = 0;
    uint32_t ret_val;
    switch (p_event->evt_type)
        /**@snippet [Handling data from UART] */
        case APP_UART_DATA_READY:
            index++;
            if ((data_array[index - 1] == '\n') || (index >= (m_ble_nus_max_data_len)))
									do
										ret_val = ble_nus_c_string_send(&m_ble_nus_c[i], data_array, index);
										if ( (ret_val != NRF_ERROR_INVALID_STATE) && (ret_val != NRF_ERROR_BUSY) )
                index = 0;
            NRF_LOG_ERROR("Communication error occurred while handling UART.");
        case APP_UART_FIFO_ERROR:
            NRF_LOG_ERROR("Error occurred in FIFO module used by UART.");
/**@brief Callback handling Nordic UART Service (NUS) client events.
 * @details This function is called to notify the application of NUS client events.
 * @param[in]   p_ble_nus_c   NUS client handle. This identifies the NUS client.
 * @param[in]   p_ble_nus_evt Pointer to the NUS client event.
/**@snippet [Handling events from the ble_nus_c module] */
static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, ble_nus_c_evt_t const * p_ble_nus_evt)
    switch (p_ble_nus_evt->evt_type)
        case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
            NRF_LOG_INFO("Discovery complete.");
            err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
            err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
            if(err_code == NRF_ERROR_BUSY)
              retry_operation_tx_notif_enable = true;
            NRF_LOG_INFO("Connected to device with Nordic UART Service.");
        case BLE_GATTC_EVT_WRITE_RSP:
            if(retry_operation_tx_notif_enable == true)
                if(err_code != NRF_ERROR_BUSY)
         }  break;
        case BLE_NUS_C_EVT_NUS_TX_EVT:
            ble_nus_chars_received_uart_print(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
        case BLE_NUS_C_EVT_DISCONNECTED:
            NRF_LOG_INFO("Disconnected.");
            scan_start();
    // For readability.
    ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
        // Upon connection, check which peripheral is connected, initiate DB
        // discovery, update LEDs status, and resume scanning, if necessary.
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connection 0x%x established, starting DB discovery.",
                         p_gap_evt->conn_handle);
            APP_ERROR_CHECK_BOOL(p_gap_evt->conn_handle < NRF_SDH_BLE_CENTRAL_LINK_COUNT);
            err_code = ble_nus_c_handles_assign(&m_ble_nus_c[p_gap_evt->conn_handle],
																								p_ble_evt->evt.gap_evt.conn_handle,
																								NULL);
            err_code = ble_db_discovery_start(&m_db_disc[p_gap_evt->conn_handle],
            if (err_code != NRF_ERROR_BUSY)
            // Update LEDs status and check whether it is needed to look for more
            // peripherals to connect to.
            bsp_board_led_on(CENTRAL_CONNECTED_LED);
            if (ble_conn_state_central_conn_count() == NRF_SDH_BLE_CENTRAL_LINK_COUNT)
                bsp_board_led_off(CENTRAL_SCANNING_LED);
                // Resume scanning.
                scan_start();
        } break; // BLE_GAP_EVT_CONNECTED
        // Upon disconnection, reset the connection handle of the peer that disconnected, update
        // the LEDs status and start scanning again.
            NRF_LOG_INFO("NUS central link 0x%x disconnected (reason: 0x%x)",
                         p_gap_evt->conn_handle,
                         p_gap_evt->params.disconnected.reason);
            if (ble_conn_state_central_conn_count() == 0)
                err_code = app_button_disable();
                // Turn off the LED that indicates the connection.
                bsp_board_led_off(CENTRAL_CONNECTED_LED);
            // Start scanning.
            scan_start();
            // Turn on the LED for indicating scanning.
        } break;
				/* Need this???? What is it for??
        case BLE_GAP_EVT_ADV_REPORT:
            on_adv_report(&p_gap_evt->params.adv_report);
        case BLE_GAP_EVT_TIMEOUT:
            // Timeout for scanning is not specified, so only the connection requests can time out.
            if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
                NRF_LOG_DEBUG("Connection request timed out.");
        } break;
        case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
            NRF_LOG_DEBUG("BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST.");
            // Accept parameters requested by peer.
            err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                        &p_gap_evt->params.conn_param_update_request.conn_params);
        } break;
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
            // Disconnect on GATT client timeout event.
            NRF_LOG_DEBUG("GATT client timeout.");
        } break;
        case BLE_GATTS_EVT_TIMEOUT:
            // Disconnect on GATT server timeout event.
            NRF_LOG_DEBUG("GATT server timeout.");
        } break;
            // No implementation needed.
/**@brief Function for initializing the Nordic UART Service (NUS) client. */
static void nus_c_init(void)
    ble_nus_c_init_t init;
    init.evt_handler = ble_nus_c_evt_handler;
	  for (uint32_t i = 0; i < NRF_SDH_BLE_CENTRAL_LINK_COUNT; i++)
			err_code = ble_nus_c_init(&m_ble_nus_c[i], &init);
 * @details Initializes the SoftDevice and the BLE event interrupts.
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for handling database discovery events.
 * @details This function is a callback function to handle events from the database discovery module.
 *          Depending on the UUIDs that are discovered, this function forwards the events
 *          to their respective services.
 * @param[in] p_event  Pointer to the database discovery event.
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
    NRF_LOG_DEBUG("call to ble_nus_on_db_disc_evt for instance %d and link 0x%x!",
                  p_evt->conn_handle,
    ble_nus_c_on_db_disc_evt(&m_ble_nus_c[p_evt->conn_handle], p_evt);
/** @brief Database discovery initialization.
static void db_discovery_init(void)
    ret_code_t err_code = ble_db_discovery_init(db_disc_handler);
/**@brief Function for initializing the UART. */
static void uart_init(void)
        .rx_pin_no    = RX_PIN_NUMBER,
        .tx_pin_no    = TX_PIN_NUMBER,
        .use_parity   = false,
        .baud_rate    = UART_BAUDRATE_BAUDRATE_Baud115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOWEST,
                       err_code);
 * @details This function handles any pending log operations, then sleeps until the next event occurs.
        nrf_pwr_mgmt_run();
/** @brief Function for initializing the log module.
static void log_init(void)
/** @brief Function for initializing the timer.
static void timer_init(void)
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)
        NRF_LOG_INFO("ATT MTU exchange completed.");
        m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
        NRF_LOG_INFO("Ble NUS max data length set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
    err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    err_code = nrf_ble_gatt_att_mtu_central_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
    // Initialize.
    log_init();
    timer_init();
    leds_init();
    power_management_init();
    ble_stack_init();
    gatt_init();
    db_discovery_init();
    ble_conn_state_init();
		uart_init();
    nus_c_init();
    scan_init();
    // Start execution.
    NRF_LOG_INFO("Multilink example started.");
    scan_start();
    for (;;)
        idle_state_handle();
