Error 133 (0x85): GATT ERROR on nRF52840
I am running ble_app_blinky example on nRF5280 custom board, it is giving me Error 133 (0x85): GATT ERROR. Since I have nrf52DK, I tried same example with SD 132 on nrf52832 it works as expected.
I went through devzone and there are many questions with similar issues but  couldn't find a solution.
Could you please let me know what could be reason for the same?
https://devzone.nordicsemi.com/f/nordic-q-a/32590/error-133-0x85-gatt-error-with-htc-u11-life
https://devzone.nordicsemi.com/f/nordic-q-a/33313/android-gatt-133-error
SDK 15.2.0
SD 140
nRF52840
Keil
Tried on Honor 7X (Android 8.0.0), Redmi Note 4 (Android 7.0),
nRF Connect, 2019-04-24
Nordic_Blinky (XX:XX:XX:XX:XX:XX)
V 16:07:10.488 Connecting to XX:XX:XX:XX:XX:XX...
D 16:07:10.488 gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M)
D 16:07:19.253 [Callback] Connection state changed with status: 133 and new state: DISCONNECTED (0)
E 16:07:19.253 Error 133 (0x85): GATT ERROR
I 16:07:19.253 Disconnected
D 16:07:21.850 gatt.close()
D 16:07:21.854 wait(200)
V 16:07:22.056 Connecting to XX:XX:XX:XX:XX:XX...
D 16:07:22.057 gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M)
D 16:07:52.111 [Callback] Connection state changed with status: 133 and new state: DISCONNECTED (0)
E 16:07:52.111 Error 133 (0x85): GATT ERROR
I 16:07:52.111 Disconnected
D 16:07:54.117 gatt.close()
D 16:07:54.120 wait(200)
V 16:07:54.321 Connecting to XX:XX:XX:XX:XX:XX...
D 16:07:54.322 gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M)
D 16:08:09.849 [Callback] Connection state changed with status: 133 and new state: DISCONNECTED (0)
E 16:08:09.850 Error 133 (0x85): GATT ERROR
I 16:08:09.850 Disconnected
D 16:08:14.775 gatt.close()
D 16:08:14.779 wait(200)
V 16:08:14.982 Connecting to XX:XX:XX:XX:XX:XX...
D 16:08:14.982 gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M)
D 16:08:15.541 [Callback] Connection state changed with status: 133 and new state: DISCONNECTED (0)
E 16:08:15.541 Error 133 (0x85): GATT ERROR
I 16:08:15.541 Disconnected
00> <info> app: Template example started.
00> <info> app: Fast advertising.
00> <info> app: Connected.
00> <info> app: Disconnected.
    I forgot to mention that the NRFX_CLOCK_ENABLED should be configured in the sdk_config.h
    Sure, it is in sdk_config.h
    I think what you mean is I should enable clock and set Low Frequency Clock Source to RC right?
    #ifndef NRFX_CLOCK_ENABLED
    #define NRFX_CLOCK_ENABLED 1
    // <o> NRFX_CLOCK_CONFIG_LF_SRC  - LF Clock Source
    // <0=> RC
    // <1=> XTAL
    // <2=> Synth
    // <131073=> External Low Swing
    // <196609=> External Full Swing
    #ifndef NRFX_CLOCK_CONFIG_LF_SRC
    #define NRFX_CLOCK_CONFIG_LF_SRC 0
    I have set the above configuration, still it gives same error.
    Please do let me know if I am wrong.
    Regards
    BL654 does not ship with the external RC oscillator
    Thank you for pointing it out. I don't know how much time I would have taken to figure it out.
    For those who are using Laird’s BL654 module or some custom module please look for clock source and modify SoftDevice clock configuration accordingly for applications using SoftDevce.
    Below is the image grab from Laird document related to clock configuration with nrf5 SDK.
    I would recommend applying the changes in sdk_config.h rather than modifying nrf_sdh.c file.
    Snippet from sdk_config.h:
    // <h> Clock - SoftDevice clock configuration
    // <o> NRF_SDH_CLOCK_LF_SRC  - SoftDevice clock source.
    // <0=> NRF_CLOCK_LF_SRC_RC
    // <1=> NRF_CLOCK_LF_SRC_XTAL
    // <2=> NRF_CLOCK_LF_SRC_SYNTH
    #ifndef NRF_SDH_CLOCK_LF_SRC
    #define NRF_SDH_CLOCK_LF_SRC 0
    // <o> NRF_SDH_CLOCK_LF_RC_CTIV - SoftDevice calibration timer interval.
    #ifndef NRF_SDH_CLOCK_LF_RC_CTIV
    #define NRF_SDH_CLOCK_LF_RC_CTIV 16
    // <o> NRF_SDH_CLOCK_LF_RC_TEMP_CTIV - SoftDevice calibration timer interval under constant temperature.
    // <i> How often (in number of calibration intervals) the RC oscillator shall be calibrated
    // <i>  if the temperature has not changed.
    #ifndef NRF_SDH_CLOCK_LF_RC_TEMP_CTIV
    #define NRF_SDH_CLOCK_LF_RC_TEMP_CTIV 2
    // <o> NRF_SDH_CLOCK_LF_ACCURACY  - External clock accuracy used in the LL to compute timing.
    // <0=> NRF_CLOCK_LF_ACCURACY_250_PPM
    // <1=> NRF_CLOCK_LF_ACCURACY_500_PPM
    // <2=> NRF_CLOCK_LF_ACCURACY_150_PPM
    // <3=> NRF_CLOCK_LF_ACCURACY_100_PPM
    // <4=> NRF_CLOCK_LF_ACCURACY_75_PPM
    // <5=> NRF_CLOCK_LF_ACCURACY_50_PPM
    // <6=> NRF_CLOCK_LF_ACCURACY_30_PPM
    // <7=> NRF_CLOCK_LF_ACCURACY_20_PPM
    // <8=> NRF_CLOCK_LF_ACCURACY_10_PPM
    // <9=> NRF_CLOCK_LF_ACCURACY_5_PPM
    // <10=> NRF_CLOCK_LF_ACCURACY_2_PPM
    // <11=> NRF_CLOCK_LF_ACCURACY_1_PPM
    #ifndef NRF_SDH_CLOCK_LF_ACCURACY
    #define NRF_SDH_CLOCK_LF_ACCURACY 1
    // </h>
    Thank you   &
    Regards
  • It does seem to be a very common thing with many modules - not just Laird - leading to many threads here.
    Perhaps Nordic could do better to highlight the issue ?
  • Glad you were able to figure it out Ali!
    As for your request Andrew, most modules mention in their data sheets what clocks are included and not. But I'll suggest internally to make this more clear from our side.
    Simon
    I think if someone mentions custom board or module it is better to ask about clock settings first, it would help a lot.
    Regards
