nRF52 - Irregular delay between data packets
Hi there,
In my application I use a hardware timer to capture and transmit sensor data with a sample time of 10ms (after corresponding notification is enabled). The connection interval is set up to 7.5ms.
As the TX queue is filled with slower rate than the data is (or should) be transmitted, I would expect that there are "empty" (or no) packets between the sensor data packets, but not that multiple data packets are transmitted during one connection interval. However, that seems to be the case: I use a nRF DK52 board in combination with nRF Connect using a PC to enable notification of the bluetooth characteristic which should send packets with sensor data every 7.5ms. However, examining the timestamps of the incoming packets,
1) the delay times between the packets seem to vary and are never 7.5ms (s. Screenshot)
2) it seems as if during some connection intervals multiple packets are received
The data packets contain an index which is incremented by the sensor application with every new data set. Apparently, no packets seem to miss. Only the time in between the incoming packets is what troubles me (as for the real application the sensor data is transmitted to a second device which performs real time processing of the data, where the time difference of the packets is of importance).
I am using an nRF52832 with SD s132 5.0.0 and have activated DLE.
The log file gained by nRF Connect is attached.
Thanks in advance for any help!
