Connecting an nRF9160 to AWS
I'm attempting to connect the nRF9160 DK to our AWS IoT account. I've been following the information in this question: https://devzone.nordicsemi.com/f/nordic-q-a/44528/switch-cloud-endpoint-from-nordic-aws-to-our-own-aws-account but I'm having an issue establishing the connection.
So far I have been able to call the certificates from a replica of 'certificates.h' and flash these onto the nRF91 using the nrf_inbuilt_key commands and have been able to establish a broker connection but receive a time out error when connecting to AWS with MQTT. I am currently modifying mqtt_simple to acheve this connection.
So far I have updated 'pj.conf' with:
# General config
CONFIG_TEST_RANDOM_GENERATOR=y
# Networking
CONFIG_NETWORKING=y
CONFIG_NET_SOCKETS_OFFLOAD=y
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_POSIX_NAMES=y
# LTE link control
CONFIG_LTE_LINK_CONTROL=y
CONFIG_LTE_AUTO_INIT_AND_CONNECT=n
CONFIG_NRF_CLOUD_PROVISION_CERTIFICATES=y
# BSD library
CONFIG_BSD_LIBRARY=y
# AT Host
CONFIG_AT_HOST_LIBRARY=y
# MQTT
CONFIG_MQTT_LIB=y
CONFIG_MQTT_LIB_TLS=y
# Appliaction
CONFIG_MQTT_PUB_TOPIC="my/publish/topic"
CONFIG_MQTT_SUB_TOPIC="my/subscribe/topic"
CONFIG_MQTT_CLIENT_ID="MQTT_TEST"
CONFIG_MQTT_BROKER_HOSTNAME="xxxxxxxxxxx.iot.eu-west-1.amazonaws.com" (redacted)
CONFIG_MQTT_BROKER_PORT=8883
CONFIG_NRF_CLOUD_SEC_TAG=1234
# Main thread
CONFIG_MAIN_THREAD_PRIORITY=7
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_HEAP_MEM_POOL_SIZE=1024
I have added the following additional functions to mqtt_simple:
#include "certificates.h"
#define NRF_CLOUD_HOSTNAME CONFIG_MQTT_BROKER_HOSTNAME
#define NRF_CLOUD_SEC_TAG CONFIG_NRF_CLOUD_SEC_TAG
static struct nct {
	struct mqtt_sec_config tls_config;
	struct mqtt_client client;
	struct sockaddr_storage broker;
	struct mqtt_utf8 dc_tx_endp;
	struct mqtt_utf8 dc_rx_endp;
	u32_t message_id;
} nct;
static void client_init(struct mqtt_client *client)
	mqtt_client_init(client);
	broker_init();
	/* MQTT client configuration */
	client->broker = &broker;
	client->evt_cb = mqtt_evt_handler;
	client->client_id.utf8 = (u8_t *)CONFIG_MQTT_CLIENT_ID;
	client->client_id.size = strlen(CONFIG_MQTT_CLIENT_ID);
	client->password = NULL;
	client->user_name = NULL;
	client->protocol_version = MQTT_VERSION_3_1_1;
	/* MQTT buffers configuration */
	client->rx_buf = rx_buffer;
	client->rx_buf_size = sizeof(rx_buffer);
	client->tx_buf = tx_buffer;
	client->tx_buf_size = sizeof(tx_buffer);
	nct.client.transport.type = MQTT_TRANSPORT_SECURE;
	struct mqtt_sec_config *tls_config = &nct.client.transport.tls.config;
	memcpy(tls_config, &nct.tls_config, sizeof(struct mqtt_sec_config));
static int nct_provision(void)
    printk("nct provisions active\n");
    static sec_tag_t sec_tag_list[] = {NRF_CLOUD_SEC_TAG};
    nct.tls_config.peer_verify = 2;
    nct.tls_config.cipher_count = 0;
    nct.tls_config.cipher_list = NULL;
    nct.tls_config.sec_tag_count = ARRAY_SIZE(sec_tag_list);
    nct.tls_config.sec_tag_list = sec_tag_list;
    nct.tls_config.hostname = CONFIG_MQTT_BROKER_HOSTNAME;
    int err;
    printk("BSD and Cloud provisions defined\n");
    /* Delete certificates */
    nrf_sec_tag_t sec_tag = NRF_CLOUD_SEC_TAG;
    for (nrf_key_mgnt_cred_type_t type = 0; type < 5; type++) {
    	err = nrf_inbuilt_key_delete(sec_tag, type);
    	printk("nrf_inbuilt_key_delete(%d, %d) => result=%d\n",
    		sec_tag, type, err);
    err = nrf_inbuilt_key_delete(0,0);
    printk("nrf_inbuilt_key_delete(0, 0) => result=%d\n",
    	err);
    /* Provision CA Certificate. */
    err = nrf_inbuilt_key_write(NRF_CLOUD_SEC_TAG,
    			NRF_KEY_MGMT_CRED_TYPE_CA_CHAIN,
    			NRF_CLOUD_CA_CERTIFICATE,
    			strlen(NRF_CLOUD_CA_CERTIFICATE));
    printk("nrf_inbuilt_key_write(%d, root-CA => result=%d)\n",
    	NRF_CLOUD_SEC_TAG, err);
    if (err) {
    	printk("NRF_CLOUD_CA_CERTIFICATE err: %d", err);
    	return err;
    /* Provision Private Certificate. */
    	NRF_CLOUD_SEC_TAG,
    	NRF_KEY_MGMT_CRED_TYPE_PRIVATE_CERT,
    	NRF_CLOUD_CLIENT_PRIVATE_KEY,
    	strlen(NRF_CLOUD_CLIENT_PRIVATE_KEY));
    	printk("nrf_inbuilt_key_write(%d, Private Key => result=%d)\n",
    if (err) {
    	printk("NRF_CLOUD_CLIENT_PRIVATE_KEY err: %d", err);
    	return err;
    /* Provision Public Certificate. */
    	NRF_CLOUD_SEC_TAG,
    	NRF_KEY_MGMT_CRED_TYPE_PUBLIC_CERT,
    	NRF_CLOUD_CLIENT_PUBLIC_CERTIFICATE,
    	strlen(NRF_CLOUD_CLIENT_PUBLIC_CERTIFICATE));
    	printk("nrf_inbuilt_key_write(%d, Public Cert => result=%d)\n",
    if (err) {
    	printk("NRF_CLOUD_CLIENT_PUBLIC_CERTIFICATE err: %d",
    		err);
    	return err;
    return 0;
void main(void)
	int err;
	int err_provision;
	printk("The MQTT simple sample started\n");
 	err_provision = nct_provision();
	if (err_provision != 0) {
		printk("ERROR: nct_provision failure %d\n", err_provision);
		return;
	printk("err_provision = %d\n", err_provision);
	modem_configure();
	client_init(&client);
I have changed the following in Kconfig:
menu "MQTT simple sample"
config MQTT_PUB_TOPIC
	string "MQTT publish topic"
	default "my/publish/topic"
config MQTT_SUB_TOPIC
	string "MQTT subscribe topic"
	default "my/subscribe/topic"
config MQTT_CLIENT_ID
	string "MQTT Client ID"
	default "MQTT_TEST"
config MQTT_BROKER_HOSTNAME
	string "MQTT broker hostname"
	default "xxxxxxxxx.iot.eu-west-1.amazonaws.com" (redacted)
config MQTT_BROKER_PORT
	int "MQTT broker port"
	default 8883
config MQTT_MESSAGE_BUFFER_SIZE
	int ""
	default 128
config MQTT_PAYLOAD_BUFFER_SIZE
	int ""
	default 128
config NRF_CLOUD_SEC_TAG
	int ""
	default 1234
Finally, the certs are inside certificates.h:
 * Copyright (c) 2018 Nordic Semiconductor ASA
 * SPDX-License-Identifier: BSD-5-Clause-Nordic
#define NRF_CLOUD_CLIENT_ID "MQTT_TEST"
#define NRF_CLOUD_CLIENT_PRIVATE_KEY \
	"-----BEGIN RSA PRIVATE KEY-----\r\n" \
	"xxxxxxx\r\n" \
	"xxxxxxx\r\n" \
	"xxxxxxx\r\n" \
	"xxxxxxx\r\n" \
	"xxxxxxx\r\n" \
	"xxxxxxx\r\n" \
	"-----END RSA PRIVATE KEY-----\r\n"
#define NRF_CLOUD_CLIENT_PUBLIC_CERTIFICATE \
	"-----BEGIN CERTIFICATE-----\r\n" \
	"xxxxxxx\r\n" \
	"xxxxxxx\r\n" \
	"xxxxxxx\r\n" \
	"xxxxxxx\r\n" \
	"xxxxxxx\r\n" \
	"xxxxxxx\r\n" \
	"-----END CERTIFICATE-----\r\n"
#define NRF_CLOUD_CA_CERTIFICATE \
	"xxxxxxx\r\n" \
	"xxxxxxx\r\n" \
	"xxxxxxx\r\n" \
	"xxxxxxx\r\n" \
	"xxxxxxx\r\n" \
	"xxxxxxx\r\n" \
I'm not sure what is still left to change in order to make the connection to AWS.
    I tried the ftp example, both as it is in the repo and edited. The code doesn't make it past boot up. The printk() line for the application start does not get sent to the link monitor, program just hard faults again. Error fault address at 0x0
    You are correct, my provider does not support anything other than a whitelisted IP address given to them in advance.
    I have gone back to my original program that was giving back the errno 134. Taking what you said, I have removed all <net/socket> commands and used only the nrf_socket library. The code now reports an errno of 22 which I believe is EINVAL (invalid argument) so at least it's not erroring an unknown value for errno.
    ***** Booting Zephyr OS v1.14.99-ncs1-3-g3c4f27282002 *****
    UDP_Test Application started
    Socket ID: 2
    Modem enabled
    Socket created for init
    Socket ID: 2
    Attempting to establish connection to EC2
    Connect Error: -1:22
    Arguments passed to blocking_connect():
    	int err;
    	int UDP_Socket;
    	ssize_t bytes_sent;
    	struct nrf_sockaddr_in my_sockaddr; // memset if not populating everything
    	struct nrf_sockaddr_in *UDP_sockaddr = &my_sockaddr;
    	UDP_sockaddr->sin_len 					=		sizeof(struct nrf_sockaddr_in);			/**< Length of this data structure */
    	UDP_sockaddr->sin_port					=		NRF_HTONS(xxxxx);              	        /**< Port, in network byte order */
    	UDP_sockaddr->sin_family 				=		NRF_AF_INET;            				/**< Socket family, IPv4 socket */
    	UDP_sockaddr->sin_addr.s_addr	  = 	0xXXXXXXXX;							    /**< IPv4 address, in hex format */
    	UDP_Socket = nrf_socket(NRF_AF_INET, NRF_SOCK_DGRAM, 0);
    	printk("Socket ID: %d\n", UDP_Socket);
    	if (UDP_Socket == -1)
    		printk("Socket failed to open\n");
    		return -EFAULT;
    		printk("Socket created for transfer\n");
    	err = blocking_connect(UDP_Socket, (struct nrf_sockaddr *)&UDP_sockaddr, sizeof(struct nrf_sockaddr_in));
    I also want to check the required prj.conf in case this is also causing issues; apologises if this is all wrong, never used this kind of file structure before and I'm piecing it together with what I learn from the other examples. Unlike the other examples, I'm not calling Link Control as the code should manually init the modem (it needs to be able to do this to change between NB-IoT and GPS later). The one I'm currently using is:
    # Use the development test RNG (not for production)
    # Networking, enable networking APIs
    CONFIG_NETWORKING=y
    # Allow Socket APIs to use POSIX names like socket(), send(), etc
    # Careful with close(), close() only works on sockets when enabled
    # BSD library
    # Main thread, reuse init stack
    # Available memory for k_malloc
    # Enable stdout for printfs
    CONFIG_STDOUT_CONSOLE=y
    # Logging
    CONFIG_LOG=y
    CONFIG_LOG_DEFAULT_LEVEL=4
    # Build with newlib c library
    CONFIG_NEWLIB_LIBC=y
    # Enable non-secure firmware as Normal mode
    CONFIG_TRUSTED_EXECUTION_NONSECURE=y
    Also, a question about the ftp code. In that code there is a converter for IP to Hex, inet_addr(). I implimented this into my code and printed the result to find that the IP address was backwards from what I expected it to be using manual conversion or something like https://www.browserling.com/tools/ip-to-hex . I have amended the function to put the bytes in the order I would expect but just want to check, is it supposed to be that way or is that an oversight in this checkout?
    Michael
    EDIT:
    I made a seperate version of the code that uses only the net/sockets.h library (like all examples of the nRF9160's data transfer capablities), it is doing the same as before, errno is 134 again. I'm not sure what else needs to be done to make this code block until connection.
     Sorry, this is an issue with the newer code base, where it requires a higher stack size for the main thread. Could you try to add this line to the prj.conf and see if it helps?
    Have you removed all the socket APIs, and used the nrf_* prefixed function calls?
     This is due to byte ordering on ARM vs. x86. The function in firmware is correct for ARM LE arch.
     No nrf_* prefixed structs or function calls? I am very unsure what this errno is, as there's nothing that should set it to this value. How are you printing the errno?
    Håkon
  • CONFIG_MAIN_STACK_SIZE=4096
    Ok so that solved the hard fault error but the main program still doesn't seem to load into the main loop. Device boots up Zephyr and then, nothing. Link Monitor just ends there. No printk for the application starting nor any other printks for errors or ones added to check liveness.
    10 NRF_EGU2		Non-Secure	OK
    11 NRF_TWIM2		Non-Secure	OK
    12 NRF_SPIM3		Non-Secure	OK
    13 NRF_TIMER0		Non-Secure	OK
    14 NRF_TIMER1		Non-Secure	OK
    15 NRF_TIMER2		Non-Secure	OK
    16 NRF_SAADC		Non-Secure	OK
    17 NRF_GPIOTE1		Non-Secure	OK
    SPM: NS image at 0x8000
    SPM: NS MSP at 0x20023688
    SPM: NS reset vector at 0xd8fd
    SPM: prepare to jump to Non-Secure image.
    I believe so yes, I have edited all socket commands to use the nrf_* prefixed versions found in nrf_socket.h. <net/sockets> has been removed and should flag errors if I try to call any non-nrf_* socket commands.
    I have been doing some reading into the Socket API and in any example, this is the way the connect API is called and its arguments are set. Not sure why it would return EINVAL.
    Ok, I have returned that function back to the way it is set in the ftp example.
    None. As mentioned before, in this example I no longer include nrf_socket.h so all references to nrf_* prefixed commands cause compilation errors.
    Unless I'm mistaken, errno is just an int value that is defined in errno.h to represent different error types. So I have just been printing err and errno as:
    	printk("Attempting to establish connection to EC2\n");
    	do {
    		err = connect(UDP_Socket, (struct sockaddr *)&UDP_sockaddr, sizeof(UDP_sockaddr));
    	} while (err < 0 && errno == EAGAIN);
    		printk("Connect Error: %d:%d\n", err, errno);
    When in the code for the nrf_* prefixed version, it returns this value, err = -1 and errno = 22:
    Timer trigger for UDPSend!
    Socket ID: 2
    Failure to establish connection via nrf_connect, closing socket
    When in the code for the non-nrf_* version, it returns this value, err = -1 and errno = 134:
    Socket ID: 2
    Connect Error: -1:134
    EDIT:
    I think I got the error. This is UDP and connect() is supposed to auto return immediately under DGRAM. It's not supposed to take any time to connect so blocking isn't necessary as all connect() does for UDP is assign a destination address to the socket without attempting to request a connection and receive an ACK back. Blocking makes sense from the examples as they used TCP Sockets.
    As for the connect() failing with err = -1, I believe it was the line:
    struct sockaddr_in *UDP_sockaddr = &my_sockaddr;
    Removing the * and making a sole struct with [struct sockaddr_in UDP_sockaddr] seems to let err = 0 and errno = 0.
    	int err;
    	int UDP_Socket;
    	// Sets up UDP Socket information
    	struct sockaddr_in UDP_sockaddr;
    	UDP_sockaddr.sin_port						=		htons(xxxx);              	/**< Port, in network byte order */
    	UDP_sockaddr.sin_family 				=		AF_INET;            				/**< Socket family, IPv4 socket */
    	UDP_sockaddr.sin_addr.s_addr	  = 	inet_addr(xx,xx,xxx,xx);		/**< IPv4 address, in hex format */
    	printk("IP address: %x\n", UDP_sockaddr.sin_addr.s_addr);
    	UDP_Socket = socket(AF_INET, SOCK_DGRAM, 0); //Opens UDP socket using UDP protocols
    I am also curious if errno is actually cleared between functions as send() will fail on my test kit as it can't actually attach to a network to execute the send() command. As send() fails it reports errno as 114 which then appears for the connect() function's errno when it is called again, Setting errno = 0 after the send() function errors out shows that errno still is 0 (and not 114) when connect is called during the next timer trigger.
    The new Link Monitor output is:
    SPM: NS MSP at 0x200232e8
    SPM: NS reset vector at 0xd97d
    Socket ID: 2
    Sending AT command: AT+CFUN=4
    Modem response: OK
    Sending AT command: AT%XSYSTEMMODE=0,1,0,0
    Modem response: OK
    Sending AT command: AT%XMAGPIO
    Modem response: OK
    Sending AT command: AT+CFUN=1
    Modem response: OK
    Modem enabled
    IP address: XXXXXXXX
    Socket ID: 2
    Connect Error: 0:0
    Config and Connect Successful
    Socket ID: 2
    Connect Error: 0:0
    Send socket connected
    Error sending Hello AWS
     to IP XXXXXXXX
    Send Error: -1:114
    Dropping into main while loop
    Socket ID: 2
    Connect Error: 0:0
    Error sending Timer Trigger
     to IP XXXXXXXX
    Send Error: -1:114
    Happily, this has also solved the issue where sockets would start to fail to be created (even though the sockets were closing after failing out) after about 7 timer calls. I hope to be able to test this bit of code soon when the remote kit in an NB-IoT area is available tomorrow. Will update when I test it.
  • Thanks Håkon
    I can confirm that the nRF9160 is sending data to our AWS EC2 instance via the NB-IoT network.
    Many thanks for your support.
    Michael
