Enabling softdevice with freertos
  Currently, I am using NRF52832 and nRF5_SDK_15.2.0. Also, I am using FreeRTOS.
   I disabled softdevice by calling nrf_sdh_disable_request() before goes to sleep mode.
   I like to enable softdevice after wake up from sleep mode.
   I tried to configure softdevice again refer to ble_app_gzll example.
   But, Because of FreeRTOS is used, there is issue on timer related code in ble_conn_params_init().
   My problem is All RTCs are already occupied( RTC0-> softdevcie, RTC1-> FreeRTOS, RTC2-> time tracking).
   I can't replace timer for app_timer from FreeRTOS timer to RTC.
   I have no idea how to handle that situation.
  Do you have any example for this? or Could you help me out to resolve this situation?
  Thanks in advance.
  Chongchun Moon
  • Hi Moon,
    you should not use app_timer.c when using freertos. Instead you should use app_timer_freertos.c (the header file is the same for both, app_timer.h)
    app_timer_freertos.c does not use RTC, but instead uses the internal timer features of the RTOS itself. So you have no problem using that.
  • Yes, I use app_timer_freertos.c
    Is there any reference to enable and disable softdevice when FreeRTOS is used?
    Or Could you tell me proper way to enable and disable softdevice with FreeRTOS?
      Chongchun Moon
      I like to change the direction. Because, It looks possible to archive sleep mode without disable softdevice.
      But, I met another issue. So I will start conversation in other thread.
    Thanks for support.
  • So to use app_timer_freertos.c what should I do? I have already disabled APP_TIMER but getting the following errors:
    "Building ‘ble_app_uart_pca10040_s132’ from solution ‘ble_app_uart_pca10040_s132’ in configuration ‘Release’
    Linking ble_app_uart_pca10040_s132.elf
    "C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 3.52a/gcc/arm-none-eabi/bin/ld" -X --omagic -eReset_Handler --defsym=__vfprintf=__vfprintf_long --defsym=__vfscanf=__vfscanf_long -EL --gc-sections "-TD:/nRF5_SDK_15.3.0_59ac345/examples/ble_peripheral/ble_app_uart/pca10040/s132/ses/Output/ble_app_uart_pca10040_s132 Release/Obj/ble_app_uart_pca10040_s132.ld" -Map Output/Release/Exe/ble_app_uart_pca10040_s132.map -u_vectors -o Output/Release/Exe/ble_app_uart_pca10040_s132.elf --emit-relocs "@D:/nRF5_SDK_15.3.0_59ac345/examples/ble_peripheral/ble_app_uart/pca10040/s132/ses/Output/ble_app_uart_pca10040_s132 Release/Obj/ble_app_uart_pca10040_s132.ind"
    Output/ble_app_uart_pca10040_s132 Release/Obj/app_button.o: In function `gpiote_event_handler':
    undefined reference to `app_timer_stop'
    undefined reference to `app_timer_start'
    Output/ble_app_uart_pca10040_s132 Release/Obj/app_button.o: In function `app_button_init':
    undefined reference to `app_timer_create'
    Output/ble_app_uart_pca10040_s132 Release/Obj/bsp.o: In function `bsp_button_event_handler':
    Output/ble_app_uart_pca10040_s132 Release/Obj/bsp.o: In function `bsp_led_indication':
    Output/ble_app_uart_pca10040_s132 Release/Obj/bsp.o: In function `bsp_init':
    Output/ble_app_uart_pca10040_s132 Release/Obj/main.o: In function `saadc_sampling_event_init':
    undefined reference to `nrfx_timer_init'
    undefined reference to `nrfx_timer_extended_compare'
    undefined reference to `nrfx_timer_enable'
    undefined reference to `nrf_drv_saadc_task_address_get'
    Output/ble_app_uart_pca10040_s132 Release/Obj/main.o: In function `timers_init':
    undefined reference to `app_timer_init'
    Output/ble_app_uart_pca10040_s132 Release/Obj/ble_conn_params.o: In function `conn_params_negotiation':
    Output/ble_app_uart_pca10040_s132 Release/Obj/ble_conn_params.o: In function `on_write':
    Output/ble_app_uart_pca10040_s132 Release/Obj/ble_conn_params.o: In function `on_disconnect':
    Output/ble_app_uart_pca10040_s132 Release/Obj/ble_conn_params.o: In function `ble_conn_params_init':
    Build failed,
    So please tell me how to use app_timer_freertos.c in this situation. And also how to solve nrfx_timer error.
