nRF light switch Mesh example testing issue
Our setup:
IDE: Segger Embedded Studio for ARM V4.12, nRFgo studio
SDK: nRF5_SDK_15.2.0_9412b96 + SDK for Mesh3.1.0,
Softdevice: 6.1.1
Computer Platform: Windows 8 64 Bit
Hardwares: 1 NRF52 Development Board,  2 BT840E modules
RTT viewer:J-link RTT Viewer V6.40
We have prepared a customize circuit using BT840E module and we have used very limited pins which we required in our application...
To test with light mesh code we require LEDs to be turned on/off and the LEDs must be connected to pins same as in DK board..
We used two GPIOs  of BT840E modules  for LED and that are P1.00(pin 12) P0.13(pin 13)... but now with our setup there is no chance to connect extra LEDs externally...
But with above setup we have tried light switch mesh example...
Steps we performed to test light switch mesh example:
We have flashed soft device hex + light switch server hex to BT840E modules which is soldered on our customized hw board ... And Flashed soft device hex + light switch client hex to nRF52840 DK board ...  (note: we have erased all before flashing light mesh example hex)
Then we have performed mesh provisioning process from Android nrf mesh mobile app.. One by One we we set bind key, publish address(for client), and subscribe address(for server) etc (Note : provisioning (from mobile mesh app) one board other two are off )... Then we hit on connect tab on nrf mesh mobile app...
we have not observed as mentioned below (link reference: https://infocenter.nordicsemi.com/index.jsp?topic=%2Fcom.nordic.infocenter.meshsdk.v3.1.0%2Fmd_doc_getting_started_mesh_quick_start.html)
  • Server:
    • During provisioning process:
      • LED 3 and 4 blinking: Device identification active.
      • LED 1 to 4: Blink four times to indicate provisioning process is completed.
    • After provisioning and configuration is over:
      • LED 1: Reflects the value of OnOff state on the server.
        • LED ON: Value of the OnOff state is 1 (true).
        • LED OFF: Value of the OnOff state is 0 (false).
  • Client:
    • After provisioning and configuration is over, buttons on the client are used to send OnOff Set messages to the servers:
      • Button 1: Send a message to the odd group (address: 0xC003) to turn on LED 1.
      • Button 2: Send a message to the odd group (address: 0xC003) to turn off LED 1.
      • Button 3: Send a message to the even group (address: 0xC002) to turn on LED 1.
      • Button 4: Send a message to the even group (address: 0xC002) to turn off LED 1.
  • Provisioner:
    • Button 1: Start provisioning.
    • LED 1: Reflects the state of the provisioning.
      • LED ON: Provisioning of the node is in progress.
      • LED OFF: No ongoing provisioning process.
    • LED 2: Reflects the state of the configuration.
      • LED ON: Configuration of the node is in progress.
      • LED OFF: No ongoing configuration process.
We also tried to see logs in RTT viewer but nothing is so clear, what exactly is going on ...
But we observed when we press 0 key from keyboard LED 1 on DK board turns on, And when we press 1 key on keyboard LED 1 turns off.. But nothing happens,no LED turns on/off, on server board(BT840E modules) when we press any Button 1,2,3,4 on client board(nRF52840 DK board) ...
log from "Log" tab on J-link RTT Viewer V6.40:-->
LOG: J-Link RTT Viewer V6.40: Logging started.
LOG: Terminal 0 added.
LOG: Device "NRF52840_XXAA" selected.
LOG: Found SW-DP with ID 0x2BA01477
LOG: Scanning AP map to find all available APs
LOG: AP[2]: Stopped AP scan as end of AP map has been reached
LOG: AP[0]: AHB-AP (IDR: 0x24770011)
LOG: AP[1]: JTAG-AP (IDR: 0x02880000)
LOG: Iterating through AP map to find AHB-AP to use
LOG: AP[0]: Core found
LOG: AP[0]: AHB-AP ROM base: 0xE00FF000
LOG: CPUID register: 0x410FC241. Implementer code: 0x41 (ARM)
LOG: Found Cortex-M4 r0p1, Little endian.
LOG: FPUnit: 6 code (BP) slots and 2 literal slots
LOG: CoreSight components:
LOG: ROMTbl[0] @ E00FF000
LOG: ROMTbl[0][0]: E000E000, CID: B105E00D, PID: 000BB00C SCS-M7
LOG: ROMTbl[0][1]: E0001000, CID: B105E00D, PID: 003BB002 DWT
LOG: ROMTbl[0][2]: E0002000, CID: B105E00D, PID: 002BB003 FPB
LOG: ROMTbl[0][3]: E0000000, CID: B105E00D, PID: 003BB001 ITM
LOG: ROMTbl[0][4]: E0040000, CID: B105900D, PID: 000BB9A1 TPIU
LOG: ROMTbl[0][5]: E0041000, CID: B105900D, PID: 000BB925 ETM
LOG: RTT Viewer connected.
LOG: Sent 1 bytes.
LOG: Sent 1 bytes.
LOG: Sent 1 bytes.
LOG: RTT Viewer disonnected.
LOG: Sent 1 bytes.
LOG: Sent 1 bytes.
log from "All terminals" tab on J-link RTT Viewer V6.40:-->
And this continues log:
Sending msg: ONOFF SET 1
00> <t: 164945>, main.c, 373, ----- Timer handler -----
00> <t: 2491475>, main.c, 200, Button 2 pressed
00> <t: 2491477>, main.c, 227, Sending msg: ONOFF SET 1<t: 2524241>, main.c, 373, ----- Timer handler -----
00> <t: 2524243>, main.c, 200, Button 3 pressed
00> <t: 2524245>, main.c, 227, Sending msg: ONOFF SET 0<t: 2557009>, main.c, 373, ----- Timer handler -----
00> <t: 2557011>, main.c, 200, Button 2 pressed
00> <t: 2557013>, main.c, 227, Sending msg: ONOFF SET 1<t: 2589777>, main.c, 373, ----- Timer handler -----
00> <t: 2589779>, main.c, 200, Button 3 pressed
00> <t: 2589781>, main.c, 227, Sending msg: ONOFF SET 0<t: 2622545>, main.c, 373, ----- Timer handler -----
00> <t: 2622547>, main.c, 200, Button 2 pressed
00> <t: 2622549>, main.c, 227, Sending msg: ONOFF SET 1<t: 2655313>, main.c, 373, ----- Timer handler -----
00> <t: 2655315>, main.c, 200, Button 3 pressed
00> <t: 2655317>, main.c, 227, Sending msg: ONOFF SET 0
log from  "Termonal 0"   tab on J-link RTT Viewer V6.40:-->
<t: 3540049>, main.c, 373, ----- Timer handler -----
<t: 3540051>, main.c, 200, Button 2 pressed
<t: 3540053>, main.c, 227, Sending msg: ONOFF SET 1
<t: 3572817>, main.c, 373, ----- Timer handler -----
<t: 3572819>, main.c, 200, Button 3 pressed
<t: 3572821>, main.c, 227, Sending msg: ONOFF SET 0
<t: 3605585>, main.c, 373, ----- Timer handler -----
<t: 3605587>, main.c, 200, Button 2 pressed
<t: 3605589>, main.c, 227, Sending msg: ONOFF SET 1
<t: 3613713>, proxy.c, 579, Connected
<t: 3623959>, proxy.c, 606, TX ready
<t: 3625579>, proxy.c, 619, TX complete
<t: 3627225>, proxy.c, 611, RX
<t: 3627229>, proxy.c, 553, RX GATT PDU type 0x2, len 19
<t: 3630494>, proxy.c, 619, TX complete
<t: 3630504>, ble_softdevice_support.c, 104, Successfully updated connection parameters
<t: 3638353>, main.c, 373, ----- Timer handler -----
<t: 3638355>, main.c, 200, Button 3 pressed
<t: 3638357>, main.c, 227, Sending msg: ONOFF SET 0
<t: 3671121>, main.c, 373, ----- Timer handler -----
<t: 3671123>, main.c, 200, Button 2 pressed
<t: 3671125>, main.c, 227, Sending msg: ONOFF SET 1
Kindly Help... With some proper PDF documents if available...
  • Hi.
     So the provisioning of the nodes works as expected?
     Maybe you could elaborate a little bit on this point?
    You are saying that when pressing 0 key from keyboard LED 1 on DK board turns on. So the DK is running the light switch client example and when you press key 0 (What is key 0?) then LED 1 on the server turns on?
    "But nothing happens,no LED turns on/off, on server board(BT840E modules) when we press any Button 1,2,3,4 on client board(nRF52840 DK board) ..."
    Isn't that the exact opposite of what you said in the first sentence?
    Joakim
    We designed a customized controller board and embed a bt840E module to communicate over bluetooth using UART... And purchased a nrf52DK board..
     What I meant to say here  is We have used 3 devices, for mesh network devices,given different roles, i.e. 1 client node(DK Board - mesh switch) and 2 server nodes (BT840E modules(embed to controller boards) - mesh Light )
    Now we want to check the internal communication between these 3 devices....
    nrf52 DK board has 4 buttons and 4 LEDs... BT840E module has one LED connected to the GPIO pin same as LED1 on DK board..
    According to Mesh set up,light switch example when we press a Button 1 from DK board(mesh switch in our case ) it should reflect to its other nodes  BT840E modules(mesh light in our case) by turning ON the LED....
    For testing:
    1) case: When I try to check the communication log on to RTT viewer to understand what logs generated when any activity done on DK baord loaded with light mesh example code,  DK board has usb interface so connected it with PC ... So when i press numeric key 0/1 from keyboard(PC keyboard) the DK board LED turns ON/OFF on DK  board LED1...
    2) case: Now we want to check what if we press Button 1 on DK board (As per light switch example when we press button 1 on dk board LED should be turned ON on BT840E module) what will happen on other nodes connected in mesh network.... but no activity observed on bt modules.... And here we observed that when we press Button 0/1 on DK board the RTT viewer shows the log that"Publication not configured for client 0" and "Publication not configured for client 1" respectively (with pc keyboard numeric key 0 and 1)..
     yes, we have followed one document reference, and its as below:
    Erase all before programming the Light Mesh example.
    Programming 1-30 server(Light). 1 or more client(Switch).
    1 provisioner. In this case, use nRF Mesh APP as provisioner
    Use nRF Mesh link to Client. Press ID then provision
    Elements-> Generic On Off client
    Select bind key and input the publish address. In this case, Input 0xC000
    Press APPLY after done.
    Now connect to server and setup the ID,provision,Key as above. In the server. Please setup the Subscribe. The address is the same 0xC000 Please setup all the server you want to test.
     Change to automatic toggle the LED  for test radio distance(190124)
    Above image is to show after provisioning we can see these device names...
