Hi All
I have attached a drafting . should I need to control impedance like that when PCB is manufacturing .
I look forward to receiving your prompt reply.
Hi All
No, the impedance will be 50 Ohm at the output of the matching network for the radio. I believe that would be at the intersection of L3 and C6. Then C5 is used for tuning the antenna input impedance seen from L3 and C6 into 50 Ohm. You check this during development by confirming that the output power is good or the range is fine. You shouldn't need to check this in production.
Also, the impedance inside the red square won't be 100 Ohm, it will be unknown at the different locations. The only place you know you'll have a known impedance is the 50 Ohm place between L3, C6 and C5.
Ok . Thank you so much !
Hi Asbjørn
I have some confusion . For the red square ,is it nacessary that the Q value of L1、L2 and L3 should to be considered ? Is it right that if we do not match the red square ,the outpower loss will increase .
Please see the two following white papers. The first one is for tuning the matching network and will give you information on what the matching network is and what it does. For the most part, this is what you have inside the red rectangle. Although you are using the nRF51 and not the nRF24Lxx, the component values are different, but principal is the same.
The Q value is important, but as long as you use components intended for 2.4 GHz RF with self resonance frequency well above 2.4 GHz you should be fine. For example, we use components from the Murata LQP15 series here.
The output power loss is dependent on how it's working already. That doesn't mean that you will see increase/decrease from tuning it. We recommend customers to test and verify. If it's low, you will probably see some benefit from tuning it. But measure the output power conducted and tune it with component values instead of measuring the impedance between the different components.
Thank you ! Happy new year !
