nrf24l01+, pcb mifa antenna design
Hello guys,
I tried to design a pcb antenna for a nrf24l01+, since my company doesnt allow to buy cheap smd breakout board version from china anymore
The pcb stats of the producer:
  • 2-layer FR4 1.55mm (61.023mil)  thickness, εr = 4.6
  • Copper thickness, 35μm (1.378mil)
What I used:
This results into following desgin block:
The antenna area is clear of any signals aswell as ground on top or bottom layer.
Since I have absolutly zero experience with RF antenna design I would like to have some opinions regarding my design.
Thanks so far,
Joe
  • I can not move the 10 pin part at the moment. Anyway I could make the ground free plane bigger, so there are only this 4 lines on the left side of the 10 pin SMT part. This should improve the performance right?
    Regarding the mounting holes: Im not using metall screws or any metal parts for the housing. I could remove the hole on left, since it is not that important for mounting anyway. By doing this, I could replace the the complete antenna/nrf package and could move it out of the 10 pin part.
    Furthermore I only have to transmit data to a receiver within 3 meters range , so I dont need some extraordinary long range connection. I guess this will work out even though the pcb design has some weaknesses.
  • If your goal is 3 meters then you should just use a chip antenna.  Both TDK and Johanson have multiple 2.4 GHz antennae that have reference designs to give a 50 ohm input. They will have several versions and each has a different ground plane and feed orientation.  Just choose something that looks right with your design.  Instead of your massive monopole, a chip antenna might occupy 4mm x 6mm. In this manner suddenly your screws and 10 pin smt aren't an issue since they will be very far away from the antenna.
    Regarding your comment above on free ground plane, just increasing the size of a ground plane doesn't necessarily improve an antenna.  All antennae are designed with a particular size and orientation of ground plane in mind.  The ground plane both serves to load the antenna to get it to match better and also controls the radiation pattern. So if a design shows no ground plane on 3 sides and a 30x40mm ground on the feedpoint side then ideally yours should look the same.  What makes most of the chip antennae nice to design around is that many are created for designs that have ground on 3 of 4 sides and the ground size often conforms to many common requirements.  On the TDK site they even have a tool that will let you estimate your antenna response when you change the ground shape to accommodate your design needs.
  • Okay I will try to design a second version with a chip antenna. Anyway Im going to test both.
    Regarding the chip antenna, I still dont understand how to correctly choose the width and lengh for feeding line. When Im using calculators I get width of 3mm, using the parameters mentioned in my initial post. That feels so wrong and is way to big. And in every datasheet is writen that you have to design the feeding line to provied 50 Ohm impedance.
    For example: Johanson 2450AT18B100 (www.johansontechnology.com/.../2450AT18B100.pdf)
  • Generally the approach is to make everything 50 ohm characterized from the nRF to the antenna. On the antenna you follow the placement guidelines for its match components and on the nRF side you follow their placement guidelines for the nRF's match components.  In this manner the absolute length of the strip doesn't matter since both ends are ideally matched to 50ohms. So you understand if something is matched to 50 ohms and you put it on a 50 ohm microstrip then it will always look like a 50 ohm device no matter how long that strip is. The only thing that happens with the length is you get a loss of power being transferred through strip.  Thus you don't want it unnecessarily long. During transmit this would mean less power radiated out the antenna and during receive less power brought in from the antenna and poorer receive sensitivity.
    The most popular microstrip design for small boards is as a coplanar waveguide with ground.  Essentially you bring the ground pour as close as you can to the strip it then capacitively loads the strip along with the ground plane below it.  Between the two you can get a fairly narrow strip that is characterized. Though I would say that most RF engineers just lay down the most compact design possible and just match the final solution.  Characterized lines are not really necessary, but they are convenient when you are just lumping two solutions together.
    The most popular app for calculating the CPW is AppCAD.  It looks like broadcomm bought it from Avago (now keysight) so you can find it here: https://www.broadcom.com/appcad
  • Okay, that coplanar waveguide with ground results into realistic dimensions. Anyway could you please check my following designs regarding the feeding line. Im not sure about the correct positioning of the antenna components and about the calculation of the feeding line width.
    I copied the basic desgin from the datasheet of chip antenna Johanson 2450AT18B100
    The dimensions are not really very precise since its not  clear to which edge of the components or SMD pads the dimensions are referring to. The position of the chip antenna is unclear aswell.
    1. Design: 4 layer pcb
    As you can see I guessed that the given dimensions referred to the middle of the smd pads. Im not sure if thats right.
    Same dimensions for my second design, but different width of feeding line.
    2.Design: 2 layer pcb
    I calculated the feeding line with this calculator ( can not install new software on this computer since IT is making problems :( )
    https://chemandy.com/calculators/coplanar-waveguide-with-ground-calculator.htm
    My pcb supplier is giving this pcb dimensions:
    This results into following settings:
    2 layer pcb:
    Dieelectric thickness matches core ("Kern") thickness (1200um)
    4 layer pcb:
    Dieelectric thicknes matches prepreg (140um) with layer 2-4 used as GND layers.
    Do you think that these designs will work out?
    By the way: Thank you very much for putting all the time into helping me
