Device popup menu in Wireshark not working
I've got Wireshark running with nRF Sniffer, but it is not really working for me.
I'm using a PCA10040 board as the sniffer hardware.
I'm running on a Mac with MacOS 10.14.4.
I'm running Python 2.7.10 and I installed PySerial 2.7.
I downloaded nrfsniffer200beta312oct20181c2a221.zip.
I installed the hex file for PCA10040 onto the board.
I installed the nRF profile into Wireshark and installed the python scripts into the extcap folder.
Note that I first installed Wireshark 3.0.2 and then downgraded to 2.6.9, which did not affect my issue.
When I run Wireshark, I can select the nRF sniffer profile and I can select the interface to my sniffer board. I see all of the advertising data for all devices, but when I select a specific device from the Device popup menu, it does not affect the output. I still see all of the advertising data. If I select my device and connect to it from my iPad then I see the advertising stop for my device, but I continue to see the advertising packet for all of the other devices in my area. Also, I only see advertising data. It does not show any other packet types from my device.
Here is the log window contents after selecting my device.
INFO: Log started at Fri May 31 15:37:30 2019
INFO: args: ()
INFO: kwargs: {'callbacks': [('*', <bound method Sniffer.passOnNotification of <Sniffer(Thread-2, initial)>>)]}
INFO: board ID (random): 156
INFO: starting scan
INFO: starting scan
INFO: Sent key value to sniffer: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]
INFO: Sniffing device 13 - ""Sm""
INFO: Following "Sm" f7:73:bf:4a:a6:c3 random
It says it is following my device, but it is still following all devices.
Any help is appreciated.
  • Which J-Link version do you have?
    Are you able to do a J-Link reset?
    [iMaci9:/Applications/SEGGER/JLink_V634b] john% JLinkExe
    SEGGER J-Link Commander V6.34b (Compiled Aug 13 2018 16:38:25)
    DLL version V6.34b, compiled Aug 13 2018 16:38:14
    Connecting to J-Link via USB...FAILED: Cannot connect to J-Link via USB.
    J-Link>connect
    J-Link connection not established yet but required for command.
    Connecting to J-Link via USB...O.K.
    Firmware: J-Link OB-SAM3U128-V2-NordicSemi compiled Jul 12 2018 11:44:41
    Hardware version: V1.00
    S/N: 682485235
    VTref=3.300V
    Please specify device / core. <Default>: NRF52
    Type '?' for selection dialog
    Device>nRF52832_XXAA
    Please specify target interface:
      J) JTAG (Default)
      S) SWD
      T) cJTAG
    TIF>s
    Specify target interface speed [kHz]. <Default>: 4000 kHz
    Speed>1000
    Device "NRF52832_XXAA" selected.
    Connecting to target via SWD
    Found SW-DP with ID 0x2BA01477
    Scanning AP map to find all available APs
    AP[2]: Stopped AP scan as end of AP map has been reached
    AP[0]: AHB-AP (IDR: 0x24770011)
    AP[1]: JTAG-AP (IDR: 0x02880000)
    Iterating through AP map to find AHB-AP to use
    AP[0]: Core found
    AP[0]: AHB-AP ROM base: 0xE00FF000
    CPUID register: 0x410FC241. Implementer code: 0x41 (ARM)
    Found Cortex-M4 r0p1, Little endian.
    FPUnit: 6 code (BP) slots and 2 literal slots
    CoreSight components:
    ROMTbl[0] @ E00FF000
    ROMTbl[0][0]: E000E000, CID: B105E00D, PID: 000BB00C SCS-M7
    ROMTbl[0][1]: E0001000, CID: B105E00D, PID: 003BB002 DWT
    ROMTbl[0][2]: E0002000, CID: B105E00D, PID: 002BB003 FPB
    ROMTbl[0][3]: E0000000, CID: B105E00D, PID: 003BB001 ITM
    ROMTbl[0][4]: E0040000, CID: B105900D, PID: 000BB9A1 TPIU
    ROMTbl[0][5]: E0041000, CID: B105900D, PID: 000BB925 ETM
    Cortex-M4 identified.
    J-Link>loadfile /Applications/Wireshark.app/Contents/MacOS/extcap/nrfsniffer200beta312oct20181c2a221/hex/sniffer_pca10040_1c2a221.hex
    Downloading file [/Applications/Wireshark.app/Contents/MacOS/extcap/nrfsniffer200beta312oct20181c2a221/hex/sniffer_pca10040_1c2a221.hex]...
    Comparing flash   [100%] Done.
    Verifying flash   [100%] Done.
    J-Link: Flash download: Bank 0 @ 0x00000000: Skipped. Contents already match
    O.K.
    J-Link>r
    Reset delay: 0 ms
    Reset type NORMAL: Resets core & peripherals via SYSRESETREQ & VECTRESET bit.
    Reset: Halt core after reset via DEMCR.VC_CORERESET.
    Reset: Reset device via AIRCR.SYSRESETREQ.
    What version is your DK?
    I'm confused. Do you mean my application? Does that matter? Does the sniffer only work with devices running Nordic chips or softdevices? This is the softdevice hex file I have installed on my board:
    s132_nrf52_3.0.0_softdevice.hex
    It should also be noted that there are issues with odd numbers of Wireshark, that is x.y.<odd number> .
    Maybe you could elaborate?
    From my OP, on my Mac:
    The Windows version I just installed this week is 3.0.2.
  • Hi again.
     I was thinking about the version number printed on the development kit (DK), looks like you have v1.0.0 from the logs above (Hardware version: V1.00).
    I was told by our developer that version of Wireshark that are odd number releases tend to have some stability issues.
    Can you try this version of the nRF Sniffer:
    nrf_sniffer_2.0.0_5june2019_c87e17d.zip
    Andreas
