ble peripheral(nordic52832) use static passkey ,at same time i have one nordic52840(central ) ,how to use static passkey?
when ble  central set BLE_GAP_IO_CAPS_DISPLAY_ONLY ,i find ble central no need to send the static passkey  or send one wrong static passkey,ble central can also connect ble peripheral .
so why ?
please help me!
 * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup ble_sdk_uart_over_ble_main main.c
 * @ingroup  ble_sdk_app_nus_eval
 * @brief    UART over BLE application main file.
 * This file contains the source code for a sample application that uses the Nordic UART service.
 * This application uses the @ref srvlib_conn_params module.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "app_timer.h"
#include "peer_manager.h"
#include "ble_nus.h"
#include "ble_acc.h"
#include "ble_ecg.h"
#include "ble_spo2.h"
#include "ble_cmd.h"
#include "nrf_pwr_mgmt.h"
#include "app_error.h"
#include "ble.h"
#include "ble_srv_common.h"
#include "fds.h"
#include "nrf_drv_clock.h"
#include "ble_dfu.h"
#include "nrf_power.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_bootloader_info.h"
#include "SEGGER_RTT.h"
#include "avc_bluetooth.h"
#include "aco_common.h"
#include "nrf_delay.h"
#include "aco_cache.h"
#define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
#define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_DURATION                0                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY                   0                                           /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
//about bounded
#define SEC_PARAM_BOND                  0                                          /**< Perform bonding. */
#define SEC_PARAM_MITM                  1                                           /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC                  1                                           /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS              0                                           /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_DISPLAY_ONLY                        /**< No I/O capabilities. */
#define SEC_PARAM_OOB                   0                                           /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE          7                                           /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE          16
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
static ble_opt_t m_static_pin_option;
TiAppCacheService* ble_cache=NULL;
BLE_CMD_DEF(m_cmd, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                 /**< BLE SPO2 service instance. */
NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
#pragma diag_suppress 177
static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
    {BLE_UUID_ECG_SERVICE, NUS_SERVICE_UUID_TYPE}
TiBleService* m_ble=NULL;
static void advertising_start(bool erase_bonds);
/**@brief Handler for shutdown preparation.
 * @details During shutdown procedures, this function will be called at a 1 second interval
 *          untill the function returns true. When the function returns true, it means that the
 *          app is ready to reset to DFU mode.
 * @param[in]   event   Power manager event.
 * @retval  True if shutdown is allowed by this power manager handler, otherwise false.
static bool app_shutdown_handler(nrf_pwr_mgmt_evt_t event)
    switch (event)
        case NRF_PWR_MGMT_EVT_PREPARE_DFU:
            SEGGER_RTT_printf(0,"Power management wants to reset to DFU mode.");
            // YOUR_JOB: Get ready to reset into DFU mode
            // If you aren't finished with any ongoing tasks, return "false" to
            // signal to the system that reset is impossible at this stage.
            // Here is an example using a variable to delay resetting the device.
            // if (!m_ready_for_reset)
            //      return false;
            // else
            //    // Device ready to enter
            //    uint32_t err_code;
            //    err_code = sd_softdevice_disable();
            //    APP_ERROR_CHECK(err_code);
            //    err_code = app_timer_stop_all();
            // YOUR_JOB: Implement any of the other events available from the power management module:
            //      -NRF_PWR_MGMT_EVT_PREPARE_SYSOFF
            //      -NRF_PWR_MGMT_EVT_PREPARE_WAKEUP
            //      -NRF_PWR_MGMT_EVT_PREPARE_RESET
            return true;
    SEGGER_RTT_printf(0,"Power management allowed to reset to DFU mode.");
    return true;
//lint -esym(528, m_app_shutdown_handler)
/**@brief Register application shutdown handler with priority 0.
NRF_PWR_MGMT_HANDLER_REGISTER(app_shutdown_handler, 0);
static void buttonless_dfu_sdh_state_observer(nrf_sdh_state_evt_t state, void * p_context)
    if (state == NRF_SDH_EVT_STATE_DISABLED)
        // Softdevice was disabled before going into reset. Inform bootloader to skip CRC on next boot.
        nrf_power_gpregret2_set(BOOTLOADER_DFU_SKIP_CRC);
        //Go to system off.
        nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
/* nrf_sdh state observer. */
NRF_SDH_STATE_OBSERVER(m_buttonless_dfu_state_obs, 0) =
    .handler = buttonless_dfu_sdh_state_observer,
// YOUR_JOB: Update this code if you want to do anything given a DFU event (optional).
/**@brief Function for handling dfu events from the Buttonless Secure DFU service
 * @param[in]   event   Event from the Buttonless Secure DFU service.
static void ble_dfu_evt_handler(ble_dfu_buttonless_evt_type_t event)
    switch (event)
        case BLE_DFU_EVT_BOOTLOADER_ENTER_PREPARE:
            SEGGER_RTT_printf(0,"Device is preparing to enter bootloader mode.");
            // YOUR_JOB: Disconnect all bonded devices that currently are connected.
            //           This is required to receive a service changed indication
            //           on bootup after a successful (or aborted) Device Firmware Update.
        case BLE_DFU_EVT_BOOTLOADER_ENTER:
            // YOUR_JOB: Write app-specific unwritten data to FLASH, control finalization of this
            //           by delaying reset by reporting false in app_shutdown_handler
            SEGGER_RTT_printf(0,"Device will enter bootloader mode.");
        case BLE_DFU_EVT_BOOTLOADER_ENTER_FAILED:
            NRF_LOG_ERROR("Request to enter bootloader mode failed asynchroneously.");
            // YOUR_JOB: Take corrective measures to resolve the issue
            //           like calling APP_ERROR_CHECK to reset the device.
        case BLE_DFU_EVT_RESPONSE_SEND_ERROR:
            NRF_LOG_ERROR("Request to send a response to client failed.");
            APP_ERROR_CHECK(false);
            NRF_LOG_ERROR("Unknown event from ble_dfu_buttonless.");
/**@brief Function for assert macro callback.
 * @warning This handler is an example only and does not fit a final product. You need to analyse
 * @param[in] line_num    Line number of the failing ASSERT call.
 * @param[in] p_file_name File name of the failing ASSERT call.
/**@brief Function for initializing the timer module.
static void timers_init(void)
 *          the device. It also sets the permissions and appearance.
static void gap_params_init(NamePair* name_pairkey)
    uint32_t                err_code;
                                          (const uint8_t *) name_pairkey->name,
                                          strlen((char*)name_pairkey->name));
		m_static_pin_option.gap_opt.passkey.p_passkey = name_pairkey->pairkey;
		err_code =  sd_ble_opt_set(BLE_GAP_OPT_PASSKEY, &m_static_pin_option);
    APP_ERROR_HANDLER(nrf_error);
/**@snippet [Handling the data received over BLE] */
/**@brief Function for handling the data from the Nordic UART Service.
 * @details This function will process the data received from the Nordic UART BLE Service and send
 *          it to the UART module.
 * @param[in] p_nus    Nordic UART Service structure.
 * @param[in] p_data   Data to be send to UART module.
 * @param[in] length   Length of the data.
static void cmd_data_handler(ble_cmd_evt_t * p_cmd)
	ble_data tem;
	if (p_cmd->type == BLE_CMD_EVT_RX_DATA)
		if(p_cmd->params.rx_data.length<=240)
			tem.data_len=p_cmd->params.rx_data.length;
			tem.ble_id=SERVICE_CMD;
			memcpy(tem.data,p_cmd->params.rx_data.p_data,tem.data_len);
			cache_put(ble_cache,&tem,1);
    uint32_t           err_code;
    ble_cmd_init_t     cmd_init;
		ble_dfu_buttonless_init_t dfus_init = {0};
		#ifdef IsNeedDfu
		 err_code = ble_dfu_buttonless_async_svci_init();
    dfus_init.evt_handler = ble_dfu_evt_handler;
    err_code = ble_dfu_buttonless_init(&dfus_init);
    // Initialize NUS.
    memset(&cmd_init, 0, sizeof(cmd_init));
    cmd_init.data_handler = cmd_data_handler;
    err_code = ble_cmd_init(&m_cmd, &cmd_init);
/**@brief Function for handling an event from the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module
 *          which are passed to the application.
 * @note All this function does is to disconnect. This could have been done by simply setting
 *       the disconnect_on_fail config parameter, but instead we use the event handler
 *       mechanism to demonstrate its use.
    uint32_t err_code;
/**@brief Function for handling errors from the Connection Parameters module.
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
						SEGGER_RTT_printf(0,"BLE_ADV_EVT_FAST.\n");
        case BLE_ADV_EVT_IDLE:
void resp_pair_request(){
    ble_gap_sec_params_t sec_params;
    uint32_t                    err_code;
    memset(&sec_params,0,sizeof(ble_gap_sec_params_t));
    sec_params.bond = SEC_PARAM_BOND;
    sec_params.io_caps = SEC_PARAM_IO_CAPABILITIES;
    sec_params.max_key_size = 16;
    sec_params.min_key_size = 7;
    sec_params.oob = 1;
    sec_params.mitm = SEC_PARAM_MITM;
	  sec_params.kdist_own.enc  = 1;
    sec_params.kdist_own.id   = 1;
    sec_params.kdist_peer.enc = 1;
    sec_params.kdist_peer.id  = 1;
		err_code=sd_ble_gap_sec_params_reply(m_conn_handle,BLE_GAP_SEC_STATUS_SUCCESS,&sec_params,NULL);
    uint32_t err_code;
        case BLE_GAP_EVT_CONNECTED:
            SEGGER_RTT_printf(0,"Connected");
						ble_gap_sec_params_t params;
						params.io_caps = BLE_GAP_IO_CAPS_NONE;
						params.oob = 1;
						sd_ble_gap_authenticate(m_conn_handle,&params);
						if(m_ble!=NULL && m_ble->callBack!=NULL) m_ble->callBack(BleConnect);
						m_ble->ble_connect_state = BleConnect;
            SEGGER_RTT_printf(0,"Disconnected");
						if(m_ble!=NULL && m_ble->callBack!=NULL) m_ble->callBack(BleNoConnect);
						m_ble->ble_connect_state = BleNoConnect;
            SEGGER_RTT_printf(0,"PHY update request.");
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
						SEGGER_RTT_printf(0,"BLE_GAP_EVT_SEC_PARAMS_REQUEST\n");
						resp_pair_request();
        case BLE_GATTC_EVT_TIMEOUT:
						 SEGGER_RTT_printf(0,"BLE_GATTC_EVT_TIMEOUT.");
        case BLE_GATTS_EVT_TIMEOUT:
			 case BLE_GAP_EVT_AUTH_STATUS:
          if(p_ble_evt->evt.gap_evt.params.auth_status.auth_status == BLE_GAP_SEC_STATUS_SUCCESS){
						m_ble->ble_connect_state = BlePairSuc;
						if(m_ble!=NULL && m_ble->callBack!=NULL) m_ble->callBack(BlePairSuc);
						SEGGER_RTT_printf(0,"pair is suc\n");
          }else{
						if(m_ble!=NULL && m_ble->callBack!=NULL) m_ble->callBack(BlePairFaild);
            sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
						m_ble->ble_connect_state = BlePairFaild;
						SEGGER_RTT_printf(0,"pair is faild\n");
            // No implementation needed.
/**@brief Function for the SoftDevice initialization.
 * @details This function initializes the SoftDevice and the BLE event interrupt.
    ret_code_t err_code;
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
        m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
        SEGGER_RTT_printf(0,"Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
    SEGGER_RTT_printf(0,"ATT MTU exchange completed. central 0x%x peripheral 0x%x\n",
                  p_gatt->att_mtu_desired_central,
                  p_gatt->att_mtu_desired_periph);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
    err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
    ble_advertising_init_t init;
    init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
    init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
 void idle_state_handle(void)
//    UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
//    nrf_pwr_mgmt_run();
		SEGGER_RTT_printf(0,"advertising is started\n");
int nodic_ble_send(uint8_t *data,uint16_t data_len,uint8_t service_id)
	int value=-1;
	uint8_t tem_state=0;
	switch(service_id)
		case SERVICE_CMD:
				tem_state=ble_cmd_data_send(&m_cmd,data,&data_len,m_conn_handle);
				if(tem_state==NRF_SUCCESS)
					value=1;
				else if(tem_state==NRF_ERROR_RESOURCES||tem_state==NRF_ERROR_BUSY || tem_state==NRF_ERROR_INVALID_STATE)
					value=0;
					value=-1;
	return value;
static void BleInit(TiBleService* ble,NamePair* name_pairkey)
	timers_init();
	power_management_init();
	ble_stack_init();
	gap_params_init(name_pairkey);
	gatt_init();
	services_init();
	advertising_init();
	conn_params_init();
	advertising_start(true);
/**@brief Application main function.
TiBleService* ble_open(uint8_t ble_id,BleCallBack callBack,IiTimeAdapter* aco_timer,NamePair* name_pairkey)
	nrf_delay_ms(100);
	TiBleService* ble=malloc(sizeof(TiBleService));
	if(ble)
		ble->cache_ble = cache_open(100,sizeof(ble_data));
		ble->callBack = callBack;
		ble->aco_timer = aco_timer;
		ble_cache = ble->cache_ble;
		ble->ble_id = ble_id;
		BleInit(ble,name_pairkey);
		m_ble=ble;
	return ble;
void ble_close(TiBleService* ble)
	if(ble)
		cache_close(ble->cache_ble);
		free(ble);
		ble=NULL;
void ble_evolve(TiBleService* ble)
	if(ble == NULL) return ;
	if(ble->ble_connect_state == BleConnect)
		ble->aco_timer->read(ble->aco_timer->owner,&ble->BlePairCurTime);
		(aco_timer_pre_sub_cur(ble->aco_timer,ble->BlePairPreTime,ble->BlePairCurTime)> BlePairTime) ? sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION):0;
		ble->BlePairPreTime = ble->BlePairCurTime;
 * Author: shenyancheng
 * Date: 2017-09-08
 * @brief Function for ble recv.
 * @param[out] sdata     recv (reference ble_data structure).
 * @param[in] ble     		reference TiBleService structure.
 * @param[in] length     recv length(ble_data num).
 * @return uint8_t  real length(ble_data num)
uint8_t  nordic_ble_recv(TiBleService* ble,ble_data* sdata,uint8_t length)//RECV
	return cache_get(ble->cache_ble,sdata,length);
 * Date: 2017-09-08
 * @brief Function for ble mac addr.
 * @param[out] addr     reference  ble_gap_addr_t.
 * @return void  none.
void nordic_ble_get_addr(ble_gap_addr_t* addr)
	sd_ble_gap_addr_get(addr);
bool BleUpdatePairKey(uint8_t* PairKey,uint8_t PairKeyLength)
	if(PairKey == NULL) return false;
	uint32_t err_code=NRF_SUCCESS;
  m_static_pin_option.gap_opt.passkey.p_passkey = PairKey;
	err_code =  sd_ble_opt_set(BLE_GAP_KP_NOT_TYPE_PASSKEY_CLEAR, &m_static_pin_option);
	return err_code == NRF_SUCCESS ? true:false;
bool BleUpdateName(uint8_t* name,uint8_t nameLength)
	uint32_t err_code = NRF_SUCCESS;
	if(name == NULL ) return false;
	sd_ble_gap_adv_stop( m_advertising.adv_handle);
	err_code = sd_ble_gap_device_name_set(&sec_mode,(const uint8_t *)name, nameLength);
	advertising_init();
 * Date: 2017-09-08
 * @brief Function for disconnect ble.
 * @param[in] ble     reference  TiBleService.
void nordic_ble_disconnect(TiBleService* ble)
	if(ble == NULL || m_conn_handle ==BLE_CONN_HANDLE_INVALID) return ;
