nRF9160 DK Connecting problems with nRF Cloud
Hello, I tried to set up my nRF9160 with this tutorial and there is a problem:
https://www.youtube.com/watch?v=jZQcmU3KIMY&t=216s
According to the tutorial, LED 3 and the LED 4 should be blinking after 3 minutes, what means that the board is connected to the nRF Cloud.
However on my nRF9160, the LED 4  never starts blinking, even if I wait 10 minutes longer than required.
I tried to push the reset button a few times, I turned the nRF9160 on and off a few times and I also started the "Add LTE Device" on nRF Cloud a few times.
But LED 4 still remains dark.
There were 2 things different compared to the tutorial video:
1) The Sim Card Registration worked fine, but when I came to the window in the picture below, I had an IMEI, but I found no PIN. So, I tried the option without a pin (Red mark in the picture).
Maybe I need a PIN, but where do I get it? I tried to insert every possible number I found on my nRF9160, but none of them worked.
I have already installed the latest firmware update for the nRF9160 successfully. So what did I do wrong? Or how can I finally connect the nRF9160 to the nRF Cloud?
- Thanks for your answers
- Bergmann
  • Hi, in the last time, i talked a bit with my local Sim Card provider about the problem and he said the Sim Card is provided with 2 APNs: alliot.nbiot.at and m2m.nbiot.t-mobile.at. The alliot.nbiot.at is the default one and goes over an iot-gateway, which needs to be configurated. The second m2m.nbiot.t-mobile.at is an public APN and doesn't go over the iot-gateway. When I opened the AT client in the LTE Monitor, i was able to connect to the second APN with the command AT+CGDCONT=0,"IP","m2m.nbiot.t-mobile.at".
    Is there a command, that I can add to the prj.conf file of my asset_tracker project, so that it takes the second APN? When I use the asset_tracker, it always takes the first APN.
    Thanks for your answers!
  • Hi!
    As this question does not directly relate to the original issue, please make a new ticket. This will make it easier for other users to find questions similar to theirs.
    Heidi
  • Hi, I was now finally able to send data from the nRF with a Sim Card from a local provider to my TCP Server. This was the goal, I wanted to accomplish with this ticket and I want to close it now. I wasn't able to connect to nRF Cloud, but for my use-case, that is now not important anymore.
    To set up the connection with a TCP Server, I opened a new ticket here, which includes a test project to connect to the Google server:
    https://devzone.nordicsemi.com/f/nordic-q-a/53940/connection-problems-to-a-tcp-server
    I want to thank you Heidi and bjorn-spockeli for your big help and persistence with me. The Devzone Forum has the best admins I have ever seen!
    Thanks for your help and your time! You really helped me a lot with my project!
